No sound input for headset mic even when plugged in
I’m using a laptop currently and the problem is that there is no sound input at all. My earphones are fine. I can hear sounds from videos and calls just fine but my microphone isn’t working. It works on any other device except my laptop. I can’t figure out what’s wrong.
I tried a couple things. I tried changing kernels to no avail, and I’ve also tried to add a kernel option to the system by adding ‘options snd-intel-dspcfg dsp_driver=1’ to ‘etc/modprobe.d/alsa-hda.conf’. I am only using my earphones for sound input and so my laptop’s the built-in internal mic is basically useless.
Here’s the output of ‘pacmd list-sources’:
2 source(s) available.
  * index: 0
	driver: <module-alsa-card.c>
	flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1030
	volume: front-left: 12451 /  19% / -43.28 dB,   front-right: 12451 /  19% / -43.28 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max rewind: 0 KiB
	sample spec: s16le 2ch 44100Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
	monitor_of: 0
	card: 0 <alsa_card.pci-0000_00_1f.3>
	module: 6
	properties:
		device.description = "Monitor of Built-in Audio Analog Stereo"
		device.class = "monitor"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xb1320000 irq 126"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "9d70"
		device.product.name = "Sunrise Point-LP HD Audio"
		device.string = "0"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
    index: 1
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9039
	volume: front-left: 65540 / 100% / 0.00 dB,   front-right: 65540 / 100% / 0.00 dB
	        balance 0.00
	base volume: 6554 /  10% / -60.00 dB
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	module: 6
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC236 Analog"
		alsa.id = "ALC236 Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "front:0"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Built-in Audio Analog Stereo"
	ports:
		analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
			properties:
		analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: no)
			properties:
	active port: <analog-input-internal-mic>
Here’s ‘inxi -Faxzy’:
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    root=UUID=3bc1d808-60ee-4a6c-9be9-55ab0db33722 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 81H7 v: Lenovo ideapad 130-15IKB
    serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 130-15IKB
  Mobo: LENOVO model: LNVNB161216 v: SDK0K13455 WIN
    serial: <superuser required> UEFI: LENOVO v: 8QCN28WW(V1.16)
    date: 08/19/2021
  ID-1: BAT1 charge: 23.2 Wh (100.0%) condition: 23.2/30.0 Wh (77.4%)
    volts: 8.5 min: 7.6 model: 0x4C 0x47 0x43 0x00 0x31 0x PABAS0241231
    type: Li-ion serial: <filter> status: Full cycles: 1190
  Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
    family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEA
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 500 high: 501 min/max: 400/2000 scaling:
    driver: intel_pstate governor: powersave cores: 1: 500 2: 500 3: 500 4: 501
    bogomips: 16006
  Type: l1tf
  Device-1: Intel HD Graphics 520 vendor: Lenovo driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:1921 class-ID: 0300
  Device-2: Chicony EasyCamera type: USB driver: uvcvideo bus-ID: 1-5:3
    chip-ID: 04f2:b5d7 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
    loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
    s-diag: 414mm (16.3")
  Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
    diag: 395mm (15.5")
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
    chip-ID: 8086:9d70 class-ID: 0403
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
    driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8136
    class-ID: 0200
  IF: enp1s0 state: down mac: <filter>
  Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
    bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-7:4 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 9.91 GiB (1.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    type: HDD rpm: 5400 serial: <filter> rev: 3E scheme: GPT
  ID-1: / raw-size: 439.45 GiB size: 431.48 GiB (98.19%) used: 9.88 GiB (2.3%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4
    used: 29.5 MiB (30.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 51.0 C pch: 45.5 C mobo: N/A
  Processes: 203 Uptime: 15m wakeups: 5486 Memory: 3.7 GiB
  used: 1.7 GiB (45.8%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1089 lib: 316 flatpak: 0
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
I also noticed that on pavucontrol, under Input Devices, the Headset Mic is unplugged even though I’ve plugged my earphones in. Is this normal?
I don’t know what to do. I’ve been trying to fix this since yesterday. Also, I am still a rookie linux user so if somebody could help me that would be great. Thanks in advance!
I’m following this issue because i have it too since the beginning, both PulseAudio and PipeWire
Have you had this microphone working on this computer in the past?
your laptop has a combo audio jack (microphone on same plug as headphones), have you made sure that the plug is pressed full home?
sometimes with these plugs, you need to back them out 1 notch to get them to work correctly.
what does dmesg say just after you plug your headset in
Sorry for the late reply. I solved it. So I was switching kernels when I was trying to fix it and after the third try, I gave up thinking it’s not a kernel problem. Obviously I was wrong. I decided to give it one more shot and turns out I had to revert to a much older kernel (5.4 LTS). And now everything works! The only downside was that my wifi driver is rtw_8821ce and it does not work on the fly. Thankfully I found a solution online which involved installing a dkms and now my system is working.
I guess the issue was due to the patches they made in the kernel. If it wasn’t for my lack of patience I could’ve solved this on the first day lol. Thanks for the reply anyway!
