I have an Asus V221ID and the audio doesn’t work on ALL linux distributions. Idk what to do
Here the specs:
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ab4b6ea3-339e-4e12-aaa6-61a6db8857a6 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm4 vt: 7
Type: Desktop System: ASUSTeK product: V221ID v: 0501 serial: <filter>
Chassis: type: 13 v: 1.0 serial: <filter>
Mobo: ASUSTeK model: V221ID v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0501 date: 01/12/2017
Info: Dual Core model: Intel Celeron J3355 bits: 64 type: MCP arch: Goldmont
family: 6 model-id: 5C (92) stepping: 9 microcode: 40 cache: L2: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 7990
Speed: 799 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 799 2: 799
Type: spec_store_bypass status: Not affected
Device-1: Intel HD Graphics 500 vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5a85 class-ID: 0300
Device-2: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:7 chip-ID: 0bda:57f6 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60
OpenGL: renderer: Mesa Intel HD Graphics 500 (APL 2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:0e.0 chip-ID: 8086:5a98
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus-ID: 03:00.0
chip-ID: 168c:0036 class-ID: 0280
Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-5:9
chip-ID: 13d3:3472 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 946.06 GiB used: 6.84 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
rotation: 5400 rpm serial: <filter> rev: 5J scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 14.54 GiB block-size: physical: 512 B
logical: 512 B serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 234.53 GiB size: 229.79 GiB (97.98%) used: 6.82 GiB (3.0%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 174 Uptime: 45m wakeups: 0 Memory: 3.67 GiB
used: 1.64 GiB (44.7%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1059 lib: 298 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.04
