Hello, I selected the Show unconnected pins but there were no 0x14 pin in the list.
Output from
cat /proc/asound/card*/codec#*
yeilds
Codec: Conexant CX8200
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x14f12008
Subsystem Id: 0x103c82b7
Revision Id: 0x100101
No Modem Function Group found
Default PCM:
rates [0x140]: 48000 96000
bits [0xa]: 16 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold S3D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=7, o=0, i=0, unsolicited=1, wake=1
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x10 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name=“Headphone Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Control: name=“Headphone Playback Switch”, index=0, device=0
Device: name=“CX8200 Analog”, type=“Audio”, device=0
Amp-Out caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Amp-Out vals: [0x80 0x80]
Converter: stream=0, channel=0
PCM:
rates [0x540]: 48000 96000 192000
bits [0xa]: 16 24
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x11 [Audio Output] wcaps 0xc1d: Stereo Amp-Out R/L
Control: name=“Speaker Playback Volume”, index=0, device=0
Control: name=“Speaker Playback Switch”, index=0, device=0
Amp-Out vals: [0x4a 0x4a]
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Node 0x12 [Beep Generator Widget] wcaps 0x70000c: Mono Amp-Out
Control: name=“Beep Playback Volume”, index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name=“Beep Playback Switch”, index=0, device=0
Amp-Out caps: ofs=0x07, nsteps=0x07, stepsize=0x0f, mute=0
Amp-Out vals: [0x03]
Node 0x13 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Control: name=“Capture Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name=“Capture Switch”, index=0, device=0
Amp-In caps: ofs=0x4a, nsteps=0x50, stepsize=0x03, mute=1
Amp-In vals: [0x80 0x80] [0x50 0x50] [0x50 0x50] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 7
0x18 0x19 0x1a* 0x15 0x1d 0x1e 0x1f
Node 0x14 [Audio Input] wcaps 0x100d1b: Stereo Amp-In R/L
Amp-In vals: [0x4a 0x4a] [0x4a 0x4a] [0x4a 0x4a]
SDI-Select: 0
PCM:
bits [0xa]: 16 24
formats [0x1]: PCM
Connection: 3
0x1a* 0x15 0x1f
Node 0x15 [Vendor Defined Widget] wcaps 0xf0050b: Stereo Amp-In
Amp-In caps: ofs=0x4a, nsteps=0x4a, stepsize=0x03, mute=1
Connection: 2
0x10* 0x11
Node 0x16 [Pin Complex] wcaps 0x400581: Stereo
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x04211040: [Jack] HP Out at Ext Right
Conn = 1/8, Color = Black
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP
Unsolicited: tag=01, enabled=1
Connection: 2
0x10* 0x11
Node 0x17 [Pin Complex] wcaps 0x400501: Stereo
Pincap 0x00010010: OUT EAPD
EAPD 0x2: EAPD
Pin Default 0x91170110: [Fixed] Speaker at Int Rear
Conn = Analog, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 2
0x10 0x11*
Node 0x18 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x2f, mute=0
Amp-In vals: [0x00 0x00]
Pincap 0x00001324: IN Detect
Vref caps: HIZ 50 80
Pin Default 0x40f001f0: [N/A] Other at Ext N/A
Conn = Unknown, Color = Unknown
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00: VREF_HIZ
Unsolicited: tag=00, enabled=0
Node 0x19 [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Control: name=“Mic Boost Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Pin Default 0x04a11030: [Jack] Mic at Ext Right
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Node 0x1a [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Control: name=“Internal Mic Boost Volume”, index=0, device=0
Amp-In vals: [0x01 0x01]
Pincap 0x00000020: IN
Pin Default 0x95a60120: [Fixed] Mic at Int Top
Conn = Digital, Color = Unknown
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1b [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x40058b: Stereo Amp-In
Pincap 0x00011334: IN OUT EAPD Detect
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT VREF_HIZ
Connection: 2
0x10* 0x11
Node 0x1e [Pin Complex] wcaps 0x40048b: Stereo Amp-In
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x1f [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x20 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
bits [0xe]: 16 20 24
formats [0x5]: PCM AC3
Node 0x21 [Pin Complex] wcaps 0x400701: Stereo Digital
Pincap 0x00000010: OUT
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 1
0x20
Node 0x22 [Pin Complex] wcaps 0x400501: Stereo
EAPD 0x2: EAPD
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Connection: 2
0x10* 0x11
Codec: Intel Kabylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280b
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
What might be the problem?
