Hi there!
I am using manjaro mate. The system was up to date until 2021 06 21, today (2021 08 02) I have updated the system and restarted, then tried to see a video file and suddenly realized that the builtin speaker DO NOT work anymore… I have no sound at all…
Yesterday I was using the kernel 4.19.198 LTS, so I thought “well maybe something went wrong in the middle (old kernel)”, and installed 5.10.53 LTS, restarted… nothing, the same behavior… D-:
Then installed pavucontrol (as the mate sound system do not offer some info), and realized that it says “speaker unavailable” and “headphones plugged in”… but there are no headphones plugged in at all!?
I have checked with alsamixer, and all is unmutted, etc…
Any advice? what to check? what to do?
here some info, hope it helps, pacman.log at last:
$ lspci | grep -i audio
00:1b.0 Audio device: Intel Corporation Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller (rev 0e)
$ pacmd list-cards
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x90810000 irq 94"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "0f04"
device.product.name = "Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller"
device.string = "0"
device.description = "Audio Interno"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Entrada Estéreo analógico (priority 65, available: unknown)
output:analog-stereo: Salida Estéreo analógico (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Estéreo analógico dúplex (priority 6565, available: unknown)
output:hdmi-stereo: Salida Digital Stereo (HDMI) (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Salida Digital Stereo (HDMI) + Entrada Estéreo analógico (priority 5965, available: no)
output:hdmi-surround: Salida Digital Surround 5.1 (HDMI) (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Salida Digital Surround 5.1 (HDMI) + Entrada Estéreo analógico (priority 865, available: no)
output:hdmi-surround71: Salida Digital Surround 7.1 (HDMI) (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Salida Digital Surround 7.1 (HDMI) + Entrada Estéreo analógico (priority 865, available: no)
off: Apagado (priority 0, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Audio Interno Estéreo analógico
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Audio Interno Estéreo analógico
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
$ pacmd list-sinks
1 sink(s) available.
* index: 0
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 55705 / 85% / -4,24 dB, front-right: 55705 / 85% / -4,24 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Estéreo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
card: 0 <alsa_card.pci-0000_00_1b.0>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC283 Analog"
alsa.id = "ALC283 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Estéreo analógico"
device.description = "Audio Interno Estéreo analógico"
ports:
properties:
properties:
active port: <analog-output-speaker>
[2021-08-02T12:59:33-0300] [PAMAC] synchronizing package lists
[2021-08-02T13:00:59-0300] [ALPM] transaction started
[2021-08-02T13:00:59-0300] [ALPM] upgraded archlinux-keyring (20210110-1 -> 20210616-1)
[2021-08-02T13:01:00-0300] [ALPM-SCRIPTLET] ==> Añadiendo las claves de archlinux.gpg...
[2021-08-02T13:01:06-0300] [ALPM-SCRIPTLET] ==> Firmando localmente las claves de confianza en el depósito...
[2021-08-02T13:01:06-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave AB19265E5D7D20687D303246BA1DFB64FFF979E7...
[2021-08-02T13:01:06-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave DDB867B92AA789C165EEFA799B729B06A680C281...
[2021-08-02T13:01:06-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 2AC0A42EFB0B5CBC7A0402ED4DC95B6D7BE9892E...
[2021-08-02T13:01:06-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
[2021-08-02T13:01:07-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
[2021-08-02T13:01:07-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 91FFE0700E80619CEB73235CA88E23E377514E00...
[2021-08-02T13:01:07-0300] [ALPM-SCRIPTLET] ==> Importando los valores de los propietarios de confianza...
[2021-08-02T13:01:07-0300] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2021-08-02T13:01:07-0300] [ALPM-SCRIPTLET] ==> Desactivando las claves revocadas en el depósito...
[2021-08-02T13:01:07-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 684148BB25B49E986A4944C55184252D824B18E8...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5357F3B111688D88C1D88119FCF2CB179205AC90...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 40440DC037C05620984379A6761FAD69BA06C6A9...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave FB871F0131FEA4FB5A9192B4C8880A6406361833...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 487EACC08557AD082088DABA1EB2638FF56C0C53...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 76B4192E902C0A52642C63C273B8ED52F1D357C1...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave B1F2C889CB2CCB2ADA36D963097D629E437520BD...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 44D4A033AC140143927397D47EFD567D4C7EA887...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5E7585ADFF106BFFBBA319DC654B877A0864983E...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave E7210A59715F6940CF9A4E36A001876699AD6E84...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave F3691687D867B81B51CE07D9BBE43771487328A9...
[2021-08-02T13:01:08-0300] [ALPM-SCRIPTLET] -> Desactivando la clave BFA1ECFEF1524EE4099CDE971F0CD4921ECAA030...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 4D913AECD81726D9A6C74F0ADA6426DD215B37AD...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 779CD2942629B7FA04AB8F172E89012331361F01...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave D921CABED130A5690EF1896E81AF739EC0711BF1...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5696C003B0854206450C8E5BE613C09CB4440678...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave A5CA9D5515DC2CA73DF748CA5C2E46A0F53A76ED...
[2021-08-02T13:01:09-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 81D7F8241DB38BC759C80FCE3A726C6170E80477...
[2021-08-02T13:01:10-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 63F395DE2D6398BBE458F281F2DBB4931985A992...
[2021-08-02T13:01:10-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
[2021-08-02T13:01:10-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 66BD74A036D522F51DD70A3C7F2A16726521E06D...
[2021-08-02T13:01:10-0300] [ALPM-SCRIPTLET] ==> Actualizando la base de datos de claves de confianza...
[2021-08-02T13:01:10-0300] [ALPM-SCRIPTLET] gpg: siguiente comprobación de base de datos de confianza el: 2021-08-12
[2021-08-02T13:01:10-0300] [ALPM] upgraded manjaro-keyring (20201216-1 -> 20210622-1)
[2021-08-02T13:01:10-0300] [ALPM-SCRIPTLET] ==> Añadiendo las claves de manjaro.gpg...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] ==> Firmando localmente las claves de confianza en el depósito...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 7C89F4D439B2BFACF425107B62443D89B35859F8...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 16DC688DF3EECC72323954237EC47C82A42D53A2...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 688E8F82879D0E25CE541426150C200743ED46D8...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 5A97ED6B72418199F0C22B23137C934B5DCB998E...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 76C6E477042BFE985CC220BD9C08A255442FAFF0...
[2021-08-02T13:01:12-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 2D14560CDCE6A75BB186DB758238651DDF5E0594...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 74C2F2CC05A0AB7D859839938934292D604F8BA2...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 7A443CEE69B6B3777740E258084A7FC0035B1D49...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 0037505D6C3F595C37F5626AFD847358FF20E35C...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 1E7908935AAB9A00D6B47503363DFFFD59152F77...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave F66AD0FF0E57C561615A0901CEE477135C5872B0...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 77DC01C9971AC3C39A0626F72C089F09AC97B894...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 22C903DE964E6FE321656E318DB9F8C18DF53602...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave B4663188A692DB1E45A98EE95BD96CC4247B52CC...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] ==> Importando los valores de los propietarios de confianza...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] ==> Desactivando las claves revocadas en el depósito...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] -> Desactivando la clave FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] ==> Actualizando la base de datos de claves de confianza...
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] gpg: marginals needed: 3 completes needed: 1 trust model: pgp
[2021-08-02T13:01:13-0300] [ALPM-SCRIPTLET] gpg: nivel: 0 validez: 1 firmada: 26 confianza: 0-, 0q, 0n, 0m, 0f, 1u
[2021-08-02T13:01:14-0300] [ALPM-SCRIPTLET] gpg: nivel: 1 validez: 26 firmada: 81 confianza: 0-, 0q, 0n, 26m, 0f, 0u
[2021-08-02T13:01:14-0300] [ALPM-SCRIPTLET] gpg: nivel: 2 validez: 75 firmada: 25 confianza: 75-, 0q, 0n, 0m, 0f, 0u
[2021-08-02T13:01:14-0300] [ALPM-SCRIPTLET] gpg: siguiente comprobación de base de datos de confianza el: 2021-08-12
[2021-08-02T13:01:15-0300] [ALPM] transaction completed
[2021-08-02T13:01:15-0300] [ALPM] running '30-systemd-update.hook'...
[2021-08-02T13:19:34-0300] [PAMAC] synchronizing package lists
[2021-08-02T13:38:34-0300] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-08-02T13:38:35-0300] [ALPM] running 'firefox-pre.hook'...
[2021-08-02T13:38:35-0300] [ALPM] running 'kernel-alive-pre.hook'...
[2021-08-02T13:38:52-0300] [ALPM] running 'thunderbird-pre.hook'...
[2021-08-02T13:38:52-0300] [ALPM] transaction started
[2021-08-02T13:38:52-0300] [ALPM] warning: /etc/pamac.conf saved as /etc/pamac.conf.pacsave
[2021-08-02T13:38:52-0300] [ALPM] removed pamac-common (10.0.6-2)
[2021-08-02T13:38:52-0300] [ALPM] removed lib32-jack (0.125.0-3)
[2021-08-02T13:38:52-0300] [ALPM] upgraded alsa-card-profiles (1:0.3.30-1 -> 1:0.3.32-1)
[2021-08-02T13:38:52-0300] [ALPM] upgraded alsa-topology-conf (1.2.5-1 -> 1.2.5.1-1)
[2021-08-02T13:38:52-0300] [ALPM] upgraded alsa-ucm-conf (1.2.5-1 -> 1.2.5.1-1)
[2021-08-02T13:38:53-0300] [ALPM] upgraded iana-etc (20210202-1 -> 20210624-1)
[2021-08-02T13:38:53-0300] [ALPM] upgraded alsa-lib (1.2.5-2 -> 1.2.5.1-3)
[2021-08-02T13:38:53-0300] [ALPM] upgraded hwids (20201207-1 -> 20210613-1)
[2021-08-02T13:38:53-0300] [ALPM] upgraded alsa-utils (1.2.5-3 -> 1.2.5.1-1)
[2021-08-02T13:38:53-0300] [ALPM] upgraded aom (3.1.0-1 -> 3.1.2-1)
[2021-08-02T13:38:53-0300] [ALPM] upgraded pcre (8.44-1 -> 8.45-1)
[2021-08-02T13:38:53-0300] [ALPM] upgraded util-linux-libs (2.37-3 -> 2.37.1-1)
[2021-08-02T13:38:54-0300] [ALPM] upgraded glib2 (2.68.2-1 -> 2.68.3-1)
[2021-08-02T13:38:54-0300] [ALPM] upgraded gdk-pixbuf2 (2.42.6-1 -> 2.42.6-2)
[2021-08-02T13:38:54-0300] [ALPM] upgraded harfbuzz (2.8.1-1 -> 2.8.2-1)
[2021-08-02T13:38:54-0300] [ALPM] upgraded fontconfig (2:2.13.93-4 -> 2:2.13.94-1)
[2021-08-02T13:38:54-0300] [ALPM-SCRIPTLET] Rebuilding fontconfig cache...
[2021-08-02T13:39:02-0300] [ALPM] upgraded pango (1:1.48.5-1 -> 1:1.48.7-1)
[2021-08-02T13:39:02-0300] [ALPM] upgraded libdrm (2.4.106-1 -> 2.4.107-1)
[2021-08-02T13:39:03-0300] [ALPM] upgraded llvm-libs (12.0.0-1 -> 12.0.1-2)
[2021-08-02T13:39:03-0300] [ALPM] upgraded vulkan-icd-loader (1.2.176-1 -> 1.2.185-1)
[2021-08-02T13:39:03-0300] [ALPM] upgraded libp11-kit (0.23.22-1 -> 0.24.0-1)
[2021-08-02T13:39:04-0300] [ALPM] upgraded libxcrypt (4.4.22-4 -> 4.4.23-1)
[2021-08-02T13:39:04-0300] [ALPM] upgraded libldap (2.4.58-3 -> 2.4.59-2)
[2021-08-02T13:39:08-0300] [ALPM] warning: directory permissions differ on /var/log/audit/
filesystem: 755 package: 700
[2021-08-02T13:39:08-0300] [ALPM] upgraded audit (3.0.1-1 -> 3.0.2-1)
[2021-08-02T13:39:08-0300] [ALPM] upgraded libcap (2.50-1 -> 2.51-1)
[2021-08-02T13:39:08-0300] [ALPM] upgraded systemd-libs (248.3-3 -> 248.6-1)
[2021-08-02T13:39:09-0300] [ALPM] upgraded p11-kit (0.23.22-1 -> 0.24.0-1)
[2021-08-02T13:39:09-0300] [ALPM-SCRIPTLET] > /etc/ca-certificates/trust-source/blacklist has been renamed to
[2021-08-02T13:39:09-0300] [ALPM-SCRIPTLET] /etc/ca-certificates/trust-source/blocklist
[2021-08-02T13:39:09-0300] [ALPM] upgraded ca-certificates-utils (20210529-1 -> 20210603-1)
[2021-08-02T13:39:09-0300] [ALPM] upgraded ca-certificates-mozilla (3.66-1 -> 3.68-1)
[2021-08-02T13:39:09-0300] [ALPM] upgraded ca-certificates (20210529-1 -> 20210603-1)
[2021-08-02T13:39:09-0300] [ALPM] upgraded libnghttp2 (1.43.0-1 -> 1.44.0-1)
[2021-08-02T13:39:09-0300] [ALPM] upgraded curl (7.77.0-1 -> 7.78.0-1)
[2021-08-02T13:39:11-0300] [ALPM] upgraded mesa (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:39:11-0300] [ALPM] upgraded tdb (1.4.3-4 -> 1.4.5-1)
[2021-08-02T13:39:14-0300] [ALPM] upgraded util-linux (2.37-3 -> 2.37.1-1)
[2021-08-02T13:39:14-0300] [ALPM] upgraded libpcap (1.10.0-1 -> 1.10.1-1)
[2021-08-02T13:39:24-0300] [ALPM] upgraded systemd (248.3-3 -> 248.6-1)
[2021-08-02T13:39:30-0300] [ALPM] upgraded libcanberra (0.30+2+gc0620e4-4 -> 0.30+2+gc0620e4-5)
[2021-08-02T13:39:31-0300] [ALPM] upgraded at-spi2-core (2.40.2-1 -> 2.40.3-1)
[2021-08-02T13:39:32-0300] [ALPM] upgraded gnutls (3.7.2-1 -> 3.7.2-2)
[2021-08-02T13:39:32-0300] [ALPM] upgraded gdbm (1.19-2 -> 1.20-1)
[2021-08-02T13:39:33-0300] [ALPM] upgraded xkeyboard-config (2.32-1 -> 2.33-1)
[2021-08-02T13:39:35-0300] [ALPM] upgraded sqlite (3.35.5-1 -> 3.36.0-1)
[2021-08-02T13:39:41-0300] [ALPM] upgraded gtk3 (1:3.24.29-2 -> 1:3.24.30-1)
[2021-08-02T13:39:48-0300] [ALPM] upgraded perl (5.34.0-1 -> 5.34.0-2)
[2021-08-02T13:39:48-0300] [ALPM] upgraded libksba (1.4.0-2 -> 1.6.0-1)
[2021-08-02T13:39:50-0300] [ALPM] upgraded gnupg (2.2.27-1 -> 2.2.29-1)
[2021-08-02T13:39:51-0300] [ALPM] upgraded gpgme (1.15.1-1 -> 1.16.0-1)
[2021-08-02T13:39:57-0300] [ALPM] upgraded python (3.9.5-3 -> 3.9.6-1)
[2021-08-02T13:39:58-0300] [ALPM] upgraded python-urllib3 (1.26.5-1 -> 1.26.6-1)
[2021-08-02T13:39:58-0300] [ALPM] upgraded python-requests (2.25.1-1 -> 2.26.0-1)
[2021-08-02T13:39:58-0300] [ALPM] installed python-certifi (2020.12.5-1)
[2021-08-02T13:39:59-0300] [ALPM] upgraded pacman-mirrors (4.21.3-2 -> 4.21.5-1)
[2021-08-02T13:39:59-0300] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2021-08-02T13:40:00-0300] [ALPM] upgraded pacman (5.2.2-6 -> 6.0.0-2)
[2021-08-02T13:40:01-0300] [ALPM] upgraded appstream-glib (0.7.18-2 -> 0.7.18-3)
[2021-08-02T13:40:07-0300] [ALPM] upgraded archlinux-appstream-data (20210423-1 -> 20210723-1)
[2021-08-02T13:40:08-0300] [ALPM] upgraded libwacom (1.10-1 -> 1.11-1)
[2021-08-02T13:40:16-0300] [ALPM] upgraded qt5-base (5.15.2+kde+r196-1 -> 5.15.2+kde+r210-1)
[2021-08-02T13:40:16-0300] [ALPM] upgraded attica (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:17-0300] [ALPM] upgraded blas (3.9.1-1 -> 3.10.0-1)
[2021-08-02T13:40:17-0300] [ALPM] upgraded bluez (5.58-1 -> 5.60-1)
[2021-08-02T13:40:18-0300] [ALPM] upgraded bluez-libs (5.58-1 -> 5.60-1)
[2021-08-02T13:40:18-0300] [ALPM] upgraded nspr (4.31-1 -> 4.32-1)
[2021-08-02T13:40:20-0300] [ALPM] upgraded nss (3.66-1 -> 3.68-1)
[2021-08-02T13:40:21-0300] [ALPM] upgraded libnm (1.30.4-3 -> 1.32.4-1)
[2021-08-02T13:40:25-0300] [ALPM] upgraded blueman (2.1.4-1 -> 2.2.1-1)
[2021-08-02T13:40:27-0300] [ALPM] upgraded boost-libs (1.75.0-5 -> 1.76.0-1)
[2021-08-02T13:40:28-0300] [ALPM] upgraded btrfs-progs (5.12.1-1 -> 5.13-1)
[2021-08-02T13:40:28-0300] [ALPM] upgraded upower (0.99.11-3 -> 0.99.12-2)
[2021-08-02T13:40:37-0300] [ALPM] upgraded js78 (78.11.0-1 -> 78.12.0-1)
[2021-08-02T13:40:37-0300] [ALPM] upgraded gptfdisk (1.0.7-1 -> 1.0.8-1)
[2021-08-02T13:40:37-0300] [ALPM] upgraded libbytesize (2.5-1 -> 2.6-1)
[2021-08-02T13:40:38-0300] [ALPM] upgraded xfsprogs (5.11.0-2 -> 5.12.0-1)
[2021-08-02T13:40:39-0300] [ALPM] upgraded solid (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:41-0300] [ALPM] upgraded kcoreaddons (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:43-0300] [ALPM] upgraded kwidgetsaddons (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:44-0300] [ALPM] upgraded kjobwidgets (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:44-0300] [ALPM] upgraded kdbusaddons (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:47-0300] [ALPM] upgraded kconfig (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:48-0300] [ALPM] upgraded kwindowsystem (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:48-0300] [ALPM] upgraded kcrash (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:50-0300] [ALPM] upgraded kglobalaccel (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:51-0300] [ALPM] upgraded polkit-qt5 (0.113.0-2 -> 0.114.0-1)
[2021-08-02T13:40:52-0300] [ALPM] upgraded kauth (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:52-0300] [ALPM] upgraded kcodecs (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:55-0300] [ALPM] upgraded qt5-declarative (5.15.2+kde+r28-1 -> 5.15.2+kde+r29-1)
[2021-08-02T13:40:57-0300] [ALPM] upgraded qt5-wayland (5.15.2+kde+r23-1 -> 5.15.2+kde+r29-1)
[2021-08-02T13:40:57-0300] [ALPM] upgraded kguiaddons (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:40:59-0300] [ALPM] upgraded ki18n (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:03-0300] [ALPM] upgraded kconfigwidgets (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:04-0300] [ALPM] upgraded kitemviews (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:04-0300] [ALPM] upgraded karchive (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:04-0300] [ALPM] upgraded kiconthemes (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:05-0300] [ALPM] upgraded kxmlgui (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:06-0300] [ALPM] upgraded kbookmarks (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:07-0300] [ALPM] upgraded knotifications (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:08-0300] [ALPM] upgraded kservice (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:08-0300] [ALPM] upgraded kwallet (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:09-0300] [ALPM] upgraded kcompletion (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:10-0300] [ALPM] upgraded sonnet (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:10-0300] [ALPM] upgraded ktextwidgets (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:11-0300] [ALPM] upgraded kded (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:16-0300] [ALPM] upgraded kio (5.82.0-1 -> 5.84.0-2)
[2021-08-02T13:41:16-0300] [ALPM] upgraded kpackage (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:17-0300] [ALPM] upgraded kdeclarative (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:18-0300] [ALPM] upgraded kcmutils (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:18-0300] [ALPM] upgraded knotifyconfig (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:18-0300] [ALPM] upgraded kparts (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:20-0300] [ALPM] upgraded qt5-script (5.15.2-1 -> 5.15.5-2)
[2021-08-02T13:41:21-0300] [ALPM] upgraded kross (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:21-0300] [ALPM] upgraded kactivities (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:22-0300] [ALPM] upgraded kunitconversion (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:23-0300] [ALPM] upgraded kitemmodels (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:24-0300] [ALPM] upgraded kemoticons (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:26-0300] [ALPM] upgraded kdelibs4support (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:27-0300] [ALPM] upgraded imath (3.0.4-1 -> 3.1.1-1)
[2021-08-02T13:41:28-0300] [ALPM] upgraded openexr (3.0.4-1 -> 3.0.5-2)
[2021-08-02T13:41:29-0300] [ALPM] upgraded kcontacts (1:5.82.0-1 -> 1:5.84.0-1)
[2021-08-02T13:41:30-0300] [ALPM] upgraded poppler (21.06.1-1 -> 21.07.0-3)
[2021-08-02T13:41:30-0300] [ALPM] upgraded poppler-qt5 (21.06.1-1 -> 21.07.0-3)
[2021-08-02T13:41:31-0300] [ALPM] upgraded kjs (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:31-0300] [ALPM] upgraded libva (2.11.0-1 -> 2.12.0-1)
[2021-08-02T13:41:34-0300] [ALPM] upgraded jack2 (1.9.18-1 -> 1.9.19-2)
[2021-08-02T13:41:34-0300] [ALPM] upgraded libmfx (21.1.3-2 -> 21.2.3-1)
[2021-08-02T13:41:34-0300] [ALPM] upgraded zimg (3.0.1-2 -> 3.0.2-1)
[2021-08-02T13:41:37-0300] [ALPM] upgraded ffmpeg (2:4.4-3 -> 2:4.4-4)
[2021-08-02T13:41:38-0300] [ALPM] upgraded libidn (1.37-1 -> 1.38-1)
[2021-08-02T13:41:39-0300] [ALPM] upgraded glslang (11.4.0-1 -> 11.5.0-1)
[2021-08-02T13:41:39-0300] [ALPM] upgraded shaderc (2021.0-1 -> 2021.1-1)
[2021-08-02T13:41:40-0300] [ALPM] upgraded libplacebo (3.120.3-1 -> 3.120.3-2)
[2021-08-02T13:41:46-0300] [ALPM] upgraded vlc (3.0.14-1 -> 3.0.16-2)
[2021-08-02T13:41:49-0300] [ALPM] upgraded khtml (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:41:50-0300] [ALPM] upgraded kinit (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:42:19-0300] [ALPM] upgraded calligra (3.2.1-15 -> 3.2.1-17)
[2021-08-02T13:42:20-0300] [ALPM] upgraded cblas (3.9.1-1 -> 3.10.0-1)
[2021-08-02T13:42:22-0300] [ALPM] upgraded cdrtools (3.02a09-4 -> 3.02a09-5)
[2021-08-02T13:42:48-0300] [ALPM] upgraded chromium (91.0.4472.114-1 -> 92.0.4515.107-3)
[2021-08-02T13:42:49-0300] [ALPM] upgraded ckbcomp (1.194-1 -> 1.204-1)
[2021-08-02T13:42:49-0300] [ALPM] upgraded cpupower (5.12-1 -> 5.13-1)
[2021-08-02T13:42:52-0300] [ALPM] upgraded imagemagick (7.0.11.14-1 -> 7.1.0.4-1)
[2021-08-02T13:42:53-0300] [ALPM] upgraded cups-filters (1.28.8-1 -> 1.28.9-1)
[2021-08-02T13:42:54-0300] [ALPM] upgraded dbus-python (1.2.16-4 -> 1.2.18-1)
[2021-08-02T13:42:54-0300] [ALPM] upgraded editorconfig-core-c (0.12.4-1 -> 0.12.5-1)
[2021-08-02T13:42:55-0300] [ALPM] upgraded enchant (2.2.15-2 -> 2.3.0-1)
[2021-08-02T13:42:57-0300] [ALPM] upgraded protobuf (3.16.0-1 -> 3.17.3-1)
[2021-08-02T13:42:58-0300] [ALPM] upgraded libphonenumber (8.12.23-1 -> 8.12.25-1)
[2021-08-02T13:42:58-0300] [ALPM] upgraded harfbuzz-icu (2.8.1-1 -> 2.8.2-1)
[2021-08-02T13:42:59-0300] [ALPM] upgraded libwpe (1.10.0-1 -> 1.10.1-1)
[2021-08-02T13:42:59-0300] [ALPM] upgraded wpebackend-fdo (1.9.92-1 -> 1.10.0-1)
[2021-08-02T13:43:06-0300] [ALPM] upgraded webkit2gtk (2.32.1-1 -> 2.32.3-1)
[2021-08-02T13:43:09-0300] [ALPM] upgraded evolution-data-server (3.40.2-1 -> 3.40.3-1)
[2021-08-02T13:43:10-0300] [ALPM] upgraded exiv2 (0.27.3-1 -> 0.27.4-2)
[2021-08-02T13:43:11-0300] [ALPM] upgraded expac (10-2 -> 10-3)
[2021-08-02T13:43:11-0300] [ALPM] upgraded f2fs-tools (1.14.0-1 -> 1.14.0-2)
[2021-08-02T13:43:13-0300] [ALPM] upgraded filelight (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:43:27-0300] [ALPM] upgraded firefox (89.0.1-1 -> 90.0.2-1)
[2021-08-02T13:43:27-0300] [ALPM] upgraded firefox-i18n-es-ar (89.0.1-1 -> 90.0.2-1)
[2021-08-02T13:43:27-0300] [ALPM] upgraded fuse-common (3.10.3-1 -> 3.10.4-1)
[2021-08-02T13:43:27-0300] [ALPM] upgraded fuse3 (3.10.3-1 -> 3.10.4-1)
[2021-08-02T13:43:27-0300] [ALPM] upgraded game-devices-udev (0.13-1 -> 0.14-1)
[2021-08-02T13:43:28-0300] [ALPM] upgraded libavif (0.9.0-2 -> 0.9.2-1)
[2021-08-02T13:43:28-0300] [ALPM] upgraded gd (2.3.2-2 -> 2.3.2-4)
[2021-08-02T13:43:28-0300] [ALPM] upgraded jasper (2.0.28-1 -> 2.0.32-1)
[2021-08-02T13:43:28-0300] [ALPM] upgraded poppler-glib (21.06.1-1 -> 21.07.0-3)
[2021-08-02T13:43:28-0300] [ALPM] upgraded lapack (3.9.1-1 -> 3.10.0-1)
[2021-08-02T13:43:29-0300] [ALPM] upgraded gegl (0.4.30-3 -> 0.4.30-5)
[2021-08-02T13:43:29-0300] [ALPM] upgraded netpbm (10.73.33-1 -> 10.73.34-1)
[2021-08-02T13:43:31-0300] [ALPM] upgraded graphviz (2.47.2-1 -> 2.48.0-2)
[2021-08-02T13:43:39-0300] [ALPM] upgraded gimp (2.10.24-4 -> 2.10.24-5)
[2021-08-02T13:43:46-0300] [ALPM] upgraded gimp-help-es (2.10.0-3 -> 2.10.0-4)
[2021-08-02T13:43:46-0300] [ALPM] upgraded glu (9.0.1-2 -> 9.0.2-1)
[2021-08-02T13:43:47-0300] [ALPM] upgraded gnome-desktop (1:40.1-2 -> 1:40.3-1)
[2021-08-02T13:43:47-0300] [ALPM] upgraded libhandy (1.2.2-1 -> 1.2.3-1)
[2021-08-02T13:43:47-0300] [ALPM] upgraded gnome-disk-utility (40.1-2 -> 40.2-1)
[2021-08-02T13:43:48-0300] [ALPM] upgraded gparted (1.3.0-4 -> 1.3.1-1)
[2021-08-02T13:43:50-0300] [ALPM] upgraded groff (1.22.4-5 -> 1.22.4-6)
[2021-08-02T13:43:51-0300] [ALPM] upgraded gst-plugins-bad-libs (1.18.4-7 -> 1.18.4-9)
[2021-08-02T13:43:51-0300] [ALPM] upgraded mpg123 (1.28.0-1 -> 1.28.2-1)
[2021-08-02T13:43:53-0300] [ALPM] upgraded hwloc (2.4.1-1 -> 2.5.0-1)
[2021-08-02T13:43:56-0300] [ALPM] upgraded openmpi (4.1.1-1 -> 4.1.1-2)
[2021-08-02T13:43:57-0300] [ALPM] upgraded gst-plugins-bad (1.18.4-7 -> 1.18.4-9)
[2021-08-02T13:43:57-0300] [ALPM] upgraded gtest (1.10.0-6 -> 1.11.0-1)
[2021-08-02T13:44:11-0300] [ALPM] upgraded gucharmap (13.0.6-1 -> 13.0.8-1)
[2021-08-02T13:44:13-0300] [ALPM] upgraded hdparm (9.61-1 -> 9.62-1)
[2021-08-02T13:44:15-0300] [ALPM] upgraded hexchat (2.14.3-8 -> 2.14.3-9)
[2021-08-02T13:44:21-0300] [ALPM] upgraded perl-alien-build (2.40-3 -> 2.41-1)
[2021-08-02T13:44:21-0300] [ALPM] upgraded python-more-itertools (8.7.0-1 -> 8.8.0-1)
[2021-08-02T13:44:23-0300] [ALPM] upgraded python-setuptools (1:57.0.0-2 -> 1:57.4.0-1)
[2021-08-02T13:44:26-0300] [ALPM] warning: directory permissions differ on /usr/share/hplip/base/__pycache__/
filesystem: 700 package: 755
[2021-08-02T13:44:26-0300] [ALPM] warning: directory permissions differ on /usr/share/hplip/base/pexpect/__pycache__/
filesystem: 777 package: 755
[2021-08-02T13:44:27-0300] [ALPM] warning: directory permissions differ on /usr/share/hplip/prnt/__pycache__/
[2021-08-02T13:44:32-0300] [ALPM] upgraded hplip (1:3.21.4-1 -> 1:3.21.6-1)
[2021-08-02T13:44:32-0300] [ALPM] upgraded perl-http-message (6.32-2 -> 6.33-1)
[2021-08-02T13:44:34-0300] [ALPM] upgraded perl-libwww (6.54-2 -> 6.55-1)
[2021-08-02T13:44:35-0300] [ALPM] upgraded hwinfo (21.74-1 -> 21.75-1)
[2021-08-02T13:44:42-0300] [ALPM] upgraded inkscape (1.1-3 -> 1.1-4)
[2021-08-02T13:44:44-0300] [ALPM] upgraded intel-gmmlib (21.1.3-1 -> 21.2.1-1)
[2021-08-02T13:44:46-0300] [ALPM] upgraded intel-media-driver (21.2.1-1 -> 21.2.3-1)
[2021-08-02T13:44:48-0300] [ALPM] upgraded intel-media-sdk (21.1.3-2 -> 21.2.3-1)
[2021-08-02T13:44:50-0300] [ALPM] upgraded intel-ucode (20210216-1 -> 20210608-1)
[2021-08-02T13:44:51-0300] [ALPM] upgraded inxi (3.3.04.1-1 -> 3.3.06.1-1)
[2021-08-02T13:44:52-0300] [ALPM] upgraded iproute2 (5.12.0-1 -> 5.13.0-1)
[2021-08-02T13:44:52-0300] [ALPM] upgraded signon-kwallet-extension (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:12-0300] [ALPM] upgraded qt5-webengine (5.15.4-3 -> 5.15.5-1)
[2021-08-02T13:45:13-0300] [ALPM] upgraded kaccounts-integration (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:13-0300] [ALPM] installed syndication (5.84.0-1)
[2021-08-02T13:45:15-0300] [ALPM] upgraded knewstuff (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:45:16-0300] [ALPM] upgraded syntax-highlighting (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:45:16-0300] [ALPM] upgraded libgit2 (1:1.1.0-1 -> 1:1.1.1-1)
[2021-08-02T13:45:16-0300] [ALPM] upgraded ktexteditor (5.82.0-2 -> 5.84.0-1)
[2021-08-02T13:45:17-0300] [ALPM] upgraded kate (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:17-0300] [ALPM] upgraded kdegraphics-mobipocket (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:18-0300] [ALPM] upgraded kdialog (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:18-0300] [ALPM] upgraded kdoctools (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded kirigami2 (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded kpty (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded konsole (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded kvantum-qt5 (0.19.0-1 -> 0.20.1-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded kwrite (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded talloc (2.3.2-1 -> 2.3.3-1)
[2021-08-02T13:45:19-0300] [ALPM] upgraded tevent (1:0.10.2-3 -> 1:0.11.0-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded ldb (1:2.3.0-1 -> 1:2.4.0-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded less (1:581.2-1 -> 1:590-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-alsa-lib (1.2.5-2 -> 1.2.5.1-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-libxcrypt (4.4.22-2 -> 4.4.23-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-util-linux (2.37-1 -> 2.37.1-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-glib2 (2.68.2-1 -> 2.68.3-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-libldap (2.4.58-1 -> 2.4.59-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-libcap (2.50-1 -> 2.51-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-systemd (248.3-1 -> 248.6-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-libxfixes (5.0.3-2 -> 6.0.0-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-at-spi2-core (2.40.2-1 -> 2.40.3-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-curl (7.77.0-1 -> 7.78.0-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-harfbuzz (2.8.1-1 -> 2.8.2-1)
[2021-08-02T13:45:20-0300] [ALPM] upgraded lib32-fontconfig (2:2.13.93-4 -> 2:2.13.94-1)
[2021-08-02T13:45:20-0300] [ALPM-SCRIPTLET] Rebuilding 32-bit fontconfig cache...
[2021-08-02T13:45:28-0300] [ALPM] upgraded lib32-gdk-pixbuf2 (2.42.6-1 -> 2.42.6-2)
[2021-08-02T13:45:28-0300] [ALPM] upgraded lib32-libdrm (2.4.106-1 -> 2.4.107-1)
[2021-08-02T13:45:30-0300] [ALPM] upgraded lib32-llvm-libs (12.0.0-1 -> 12.0.1-1)
[2021-08-02T13:45:30-0300] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.176-1 -> 1.2.184-1)
[2021-08-02T13:45:33-0300] [ALPM] upgraded lib32-mesa (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:45:35-0300] [ALPM] upgraded lib32-pango (1:1.48.5-1 -> 1:1.48.7-1)
[2021-08-02T13:45:35-0300] [ALPM] upgraded lib32-tdb (1.4.3-1 -> 1.4.5-1)
[2021-08-02T13:45:36-0300] [ALPM] upgraded lib32-libcanberra (0.30+2+gc0620e4-4 -> 0.30+2+gc0620e4-5)
[2021-08-02T13:45:36-0300] [ALPM] upgraded lib32-libtasn1 (4.16.0-2 -> 4.17.0-1)
[2021-08-02T13:45:37-0300] [ALPM] upgraded lib32-nettle (3.7.2-1 -> 3.7.3-1)
[2021-08-02T13:45:37-0300] [ALPM] upgraded lib32-p11-kit (0.23.22-1 -> 0.24.0-1)
[2021-08-02T13:45:39-0300] [ALPM] upgraded lib32-sqlite (3.35.5-1 -> 3.36.0-1)
[2021-08-02T13:45:39-0300] [ALPM] upgraded lib32-gtk3 (3.24.29-1 -> 3.24.30-1)
[2021-08-02T13:45:40-0300] [ALPM] installed lib32-jack2 (1.9.19-2)
[2021-08-02T13:45:41-0300] [ALPM] upgraded lib32-libidn (1.37-1 -> 1.38-1)
[2021-08-02T13:45:44-0300] [ALPM] upgraded lib32-mesa-vdpau (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:45:45-0300] [ALPM] upgraded lib32-nspr (4.31-1 -> 4.32-1)
[2021-08-02T13:45:46-0300] [ALPM] upgraded lib32-nss (3.66-1 -> 3.68-1)
[2021-08-02T13:45:47-0300] [ALPM] upgraded lib32-vulkan-intel (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:45:48-0300] [ALPM] upgraded lib32-vulkan-radeon (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:45:49-0300] [ALPM] upgraded libcmis (0.5.2-7 -> 0.5.2-8)
[2021-08-02T13:45:50-0300] [ALPM] upgraded libixion (0.16.1-5 -> 0.16.1-6)
[2021-08-02T13:45:51-0300] [ALPM] upgraded libkexiv2 (21.04.1-1 -> 21.04.3-1)
[2021-08-02T13:45:52-0300] [ALPM] upgraded libmm-glib (1.16.6-1 -> 1.16.8-1)
[2021-08-02T13:45:53-0300] [ALPM] upgraded libmp4v2 (4.1.6-1 -> 5.0.1-1)
[2021-08-02T13:45:57-0300] [ALPM] upgraded libmwaw (0.3.19-1 -> 0.3.20-1)
[2021-08-02T13:45:59-0300] [ALPM] upgraded liborcus (0.16.1-6 -> 0.16.1-7)
[2021-08-02T13:46:42-0300] [ALPM] upgraded libreoffice-still (7.0.6-2 -> 7.0.6-3)
[2021-08-02T13:46:42-0300] [ALPM] upgraded libsidplayfp (2.1.2-1 -> 2.2.1-1)
[2021-08-02T13:46:43-0300] [ALPM] upgraded libva-mesa-driver (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:46:43-0300] [ALPM] upgraded lightdm-slick-greeter (1.5.2-1 -> 1.5.4-1)
[2021-08-02T13:46:43-0300] [ALPM] upgraded python-xapp (2.0.2-2 -> 2.2.1-1)
[2021-08-02T13:46:44-0300] [ALPM] upgraded lightdm-settings (1.5.3-1 -> 1.5.5-1)
[2021-08-02T13:46:44-0300] [ALPM-SCRIPTLET] tput: No value for $TERM and no -T specified
[2021-08-02T13:46:47-0300] [ALPM-SCRIPTLET]
[2021-08-02T13:46:47-0300] [ALPM-SCRIPTLET] ==> NOTE: We have enabled autologin for all users.
[2021-08-02T13:46:47-0300] [ALPM-SCRIPTLET] ==> NOTE: Reboot your system the first time, so changes will take affect.
[2021-08-02T13:47:39-0300] [ALPM] upgraded linux-firmware (20210518.r1928.f846292-1 -> 20210719.r1990.168452e-1)
[2021-08-02T13:47:39-0300] [ALPM] upgraded mkinitcpio-busybox (1.32.1-3 -> 1.33.1-1)
[2021-08-02T13:47:57-0300] [ALPM] upgraded linux419 (4.19.193-1 -> 4.19.198-1)
[2021-08-02T13:47:58-0300] [ALPM] upgraded python-pillow (8.2.0-2 -> 8.3.1-1)
[2021-08-02T13:48:02-0300] [ALPM] upgraded totem-pl-parser (3.26.5-1 -> 3.26.6-1)
[2021-08-02T13:48:04-0300] [ALPM] upgraded lollypop (1.4.19-1 -> 1.4.22-1)
[2021-08-02T13:48:05-0300] [ALPM] upgraded m4 (1.4.18-3 -> 1.4.19-1)
[2021-08-02T13:48:11-0300] [ALPM] upgraded man-db (2.9.4-1 -> 2.9.4-2)
[2021-08-02T13:48:16-0300] [ALPM] upgraded man-pages (5.11-1 -> 5.12-2)
[2021-08-02T13:48:23-0300] [ALPM] installed libpamac (11.0.1-3)
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] ==> An authentication agent is required
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] Cinnamon, Deepin, GNOME, GNOME Flashback, KDE, LXDE, LXQt, MATE and Xfce
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] have an authentication agent already.
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] See https://wiki.archlinux.org/index.php/Polkit#Authentication_agents
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] for other desktop environments.
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m You had an old /etc/pamac.conf.pacsave file. We restore it for you.e[1;0m
[2021-08-02T13:48:24-0300] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m You can find your new pamac.conf saved as `/etc/pamac-new-08024824.conf`e[1;0m
[2021-08-02T13:48:25-0300] [ALPM] upgraded pamac-cli (10.0.6-2 -> 10.1.3-3)
[2021-08-02T13:48:29-0300] [ALPM] upgraded manjaro-application-utility (1.3.3-4.1 -> 1.3.3-5)
[2021-08-02T13:48:29-0300] [ALPM] upgraded pamac-gtk (10.0.6-2 -> 10.1.3-3)
[2021-08-02T13:48:33-0300] [ALPM] upgraded manjaro-hello (0.6.6-5 -> 0.6.6-6)
[2021-08-02T13:48:33-0300] [ALPM] upgraded manjaro-release (21.0.7-1 -> 21.1.0rc3-1)
[2021-08-02T13:48:53-0300] [ALPM] upgraded matcha-gtk-theme (20210602-0.1 -> 20210720-1)
[2021-08-02T13:48:56-0300] [ALPM] upgraded mathjax (3.1.4-1 -> 3.2.0-1)
[2021-08-02T13:48:57-0300] [ALPM] upgraded mbedtls (2.25.0-1 -> 2.27.0-1)
[2021-08-02T13:48:57-0300] [ALPM] upgraded memtest86+ (5.01-4 -> 5.31b-1)
[2021-08-02T13:48:57-0300] [ALPM] upgraded mesa-vdpau (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:48:57-0300] [ALPM] upgraded mhwd-nvidia-390xx (390.143-1 -> 390.144-1)
[2021-08-02T13:48:57-0300] [ALPM] upgraded mhwd-nvidia (465.31-1 -> 470.57.02-1)
[2021-08-02T13:48:58-0300] [ALPM] upgraded mhwd-db (0.6.5-9 -> 0.6.5-14)
[2021-08-02T13:48:58-0300] [ALPM] upgraded modemmanager (1.16.6-1 -> 1.16.8-1)
[2021-08-02T13:48:59-0300] [ALPM] upgraded nano (5.7-1 -> 5.8-1)
[2021-08-02T13:49:00-0300] [ALPM] upgraded networkmanager (1.30.4-3 -> 1.32.4-1)
[2021-08-02T13:49:00-0300] [ALPM] upgraded rpcbind (1.2.5-3 -> 1.2.6-1)
[2021-08-02T13:49:00-0300] [ALPM] upgraded nfsidmap (2.5.3-1 -> 2.5.4-1)
[2021-08-02T13:49:01-0300] [ALPM] upgraded nfs-utils (2.5.3-1 -> 2.5.4-1)
[2021-08-02T13:49:02-0300] [ALPM] upgraded pipewire (1:0.3.30-1 -> 1:0.3.32-1)
[2021-08-02T13:49:03-0300] [ALPM] upgraded obs-studio (27.0.0-2 -> 27.0.1-2)
[2021-08-02T13:49:05-0300] [ALPM] upgraded threadweaver (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:49:06-0300] [ALPM] upgraded purpose (5.82.0-1 -> 5.84.0-1)
[2021-08-02T13:49:17-0300] [ALPM] upgraded okular (21.04.1-1 -> 21.04.3-2)
[2021-08-02T13:49:18-0300] [ALPM] upgraded openvpn (2.5.2-1 -> 2.5.3-1)
[2021-08-02T13:50:06-0300] [ALPM] upgraded papirus-icon-theme (20210601-1 -> 20210701-1)
[2021-08-02T13:50:07-0300] [ALPM] upgraded pulseaudio-ctl (1.67-1 -> 1.70-1)
[2021-08-02T13:50:09-0300] [ALPM] upgraded python2-gobject2 (2.28.7-6.1 -> 2.28.7-7)
[2021-08-02T13:50:09-0300] [ALPM] upgraded pygtk (2.24.0-14 -> 2.24.0-16)
[2021-08-02T13:50:09-0300] [ALPM] upgraded python-cffi (1.14.5-1 -> 1.14.6-1)
[2021-08-02T13:50:09-0300] [ALPM] upgraded python-zipp (3.4.1-1 -> 3.5.0-1)
[2021-08-02T13:50:09-0300] [ALPM] upgraded python-importlib-metadata (4.0.1-1 -> 4.6.1-1)
[2021-08-02T13:50:09-0300] [ALPM] installed python-tomli (1.1.0-2)
[2021-08-02T13:50:10-0300] [ALPM] upgraded python-pep517 (0.10.0-2 -> 0.11.0-1)
[2021-08-02T13:50:10-0300] [ALPM] upgraded python-resolvelib (0.5.4-1 -> 0.5.5-1)
[2021-08-02T13:50:10-0300] [ALPM] upgraded python-pip (20.3.1-1 -> 20.3.4-1)
[2021-08-02T13:50:11-0300] [ALPM] upgraded python-pyzmq (22.0.3-1 -> 22.1.0-1)
[2021-08-02T13:50:13-0300] [ALPM] upgraded python-reportlab (3.5.67-1 -> 3.5.68-2)
[2021-08-02T13:50:15-0300] [ALPM] upgraded python-xlib (0.30-1 -> 0.31-1)
[2021-08-02T13:50:18-0300] [ALPM] upgraded smbclient (4.14.4-1 -> 4.14.6-1)
[2021-08-02T13:50:18-0300] [ALPM] upgraded sof-firmware (1.7-2 -> 1.8-1)
[2021-08-02T13:50:19-0300] [ALPM] upgraded steam-manjaro (1.0.0.70-1 -> 1.0.0.71-1)
[2021-08-02T13:50:21-0300] [ALPM] upgraded sudo (1.9.7-1 -> 1.9.7.p1-1)
[2021-08-02T13:50:22-0300] [ALPM] upgraded systemd-sysvcompat (248.3-3 -> 248.6-1)
[2021-08-02T13:50:24-0300] [ALPM] upgraded texinfo (6.7-3 -> 6.8-1)
[2021-08-02T13:50:36-0300] [ALPM] upgraded thunderbird (78.11.0-1 -> 78.12.0-1)
[2021-08-02T13:50:38-0300] [ALPM] upgraded tracker3 (3.1.1-2 -> 3.1.2-1)
[2021-08-02T13:50:39-0300] [ALPM] upgraded unrar (1:6.0.6-1 -> 1:6.0.7-1)
[2021-08-02T13:50:39-0300] [ALPM] upgraded vpnc (1:0.5.3.r468.r81-2 -> 1:0.5.3.r496.r153-2)
[2021-08-02T13:50:40-0300] [ALPM] upgraded vulkan-intel (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:50:41-0300] [ALPM] upgraded vulkan-radeon (21.1.2-1 -> 21.1.5-1)
[2021-08-02T13:50:41-0300] [ALPM] upgraded wireless-regdb (2020.11.20-1 -> 2021.04.21-1)
[2021-08-02T13:50:44-0300] [ALPM] upgraded xapp (2.0.7-1 -> 2.2.3-1)
[2021-08-02T13:50:44-0300] [ALPM] upgraded xf86-input-libinput (1.0.1-1 -> 1.1.0-1)
[2021-08-02T13:50:47-0300] [ALPM] upgraded yelp (40.2-1 -> 40.3-1)
[2021-08-02T13:51:09-0300] [ALPM] transaction completed
[2021-08-02T13:51:26-0300] [ALPM] running '20-systemd-sysusers.hook'...
[2021-08-02T13:51:27-0300] [ALPM] running '30-systemd-catalog.hook'...
[2021-08-02T13:51:27-0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-08-02T13:51:28-0300] [ALPM] running '30-systemd-hwdb.hook'...
[2021-08-02T13:51:30-0300] [ALPM] running '30-systemd-sysctl.hook'...
[2021-08-02T13:51:30-0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-08-02T13:51:30-0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-08-02T13:51:31-0300] [ALPM] running '30-systemd-update.hook'...
[2021-08-02T13:51:31-0300] [ALPM] running '40-update-ca-trust.hook'...
[2021-08-02T13:51:33-0300] [ALPM] running '60-depmod.hook'...
[2021-08-02T13:51:46-0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-08-02T13:51:46-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
[2021-08-02T13:51:46-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
[2021-08-02T13:51:47-0300] [ALPM-SCRIPTLET] ==> Starting build: 4.19.198-1-MANJARO
[2021-08-02T13:51:47-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-08-02T13:51:48-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-08-02T13:51:48-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-08-02T13:51:49-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-08-02T13:51:49-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-08-02T13:51:51-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-08-02T13:51:51-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-08-02T13:51:51-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-08-02T13:51:51-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-08-02T13:51:52-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-08-02T13:51:52-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
[2021-08-02T13:51:55-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-08-02T13:51:55-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
[2021-08-02T13:51:55-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
[2021-08-02T13:51:55-0300] [ALPM-SCRIPTLET] ==> Starting build: 4.19.198-1-MANJARO
[2021-08-02T13:51:55-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-08-02T13:51:56-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-08-02T13:51:56-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-08-02T13:51:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-08-02T13:52:07-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-08-02T13:52:11-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-08-02T13:52:11-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2021-08-02T13:52:11-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-08-02T13:52:17-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-08-02T13:52:17-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
[2021-08-02T13:52:27-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-08-02T13:52:28-0300] [ALPM] running '99-grub.hook'...
[2021-08-02T13:52:31-0300] [ALPM-SCRIPTLET] Generando un fichero de configuración de grub...
[2021-08-02T13:52:35-0300] [ALPM-SCRIPTLET] Encontrado tema: /usr/share/grub/themes/manjaro/theme.txt
[2021-08-02T13:52:39-0300] [ALPM-SCRIPTLET] Encontrada imagen de linux: /boot/vmlinuz-4.19-x86_64
[2021-08-02T13:52:40-0300] [ALPM-SCRIPTLET] Encontrada imagen de memoria inicial: /boot/intel-ucode.img /boot/initramfs-4.19-x86_64.img
[2021-08-02T13:52:43-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
[2021-08-02T13:52:44-0300] [ALPM-SCRIPTLET] Aviso: os-prober will be executed to detect other bootable partitions.
[2021-08-02T13:52:44-0300] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2021-08-02T13:52:51-0300] [ALPM-SCRIPTLET] Encontrado Manjaro Linux (21.1.0) en /dev/sda2
[2021-08-02T13:53:07-0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-08-02T13:53:08-0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-08-02T13:53:09-0300] [ALPM-SCRIPTLET] hecho
[2021-08-02T13:53:09-0300] [ALPM] running 'dbus-reload.hook'...
[2021-08-02T13:53:09-0300] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-08-02T13:53:09-0300] [ALPM] running 'firefox-post.hook'...
[2021-08-02T13:53:09-0300] [ALPM] running 'fontconfig.hook'...
[2021-08-02T13:53:10-0300] [ALPM] running 'fontconfig-32.hook'...
[2021-08-02T13:53:11-0300] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-08-02T13:53:12-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2021-08-02T13:53:13-0300] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2021-08-02T13:53:14-0300] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2021-08-02T13:53:16-0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-08-02T13:53:41-0300] [ALPM] running 'kernel-alive-post.hook'...
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET]
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Warning:
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET] -> at next boot.
[2021-08-02T13:54:03-0300] [ALPM-SCRIPTLET] e[1;0m
[2021-08-02T13:54:03-0300] [ALPM] running 'networkmanager-connectivity.hook'...
[2021-08-02T13:54:03-0300] [ALPM] running 'pacman-mirrors-upgrade.hook'...
[2021-08-02T13:54:17-0300] [ALPM-SCRIPTLET] ::e[1;37mINFOe[1;m Downloading mirrors from Manjaro
[2021-08-02T13:54:17-0300] [ALPM-SCRIPTLET] ::e[1;37mINFOe[1;m => Mirror pool: https://repo.manjaro.org/mirrors.json
[2021-08-02T13:54:17-0300] [ALPM-SCRIPTLET] ::e[1;37mINFOe[1;m => Mirror status: http://repo.manjaro.org/status.json
[2021-08-02T13:54:17-0300] [ALPM-SCRIPTLET] hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
[2021-08-02T13:54:17-0300] [ALPM] running 'texinfo-install.hook'...
[2021-08-02T13:54:20-0300] [ALPM] running 'thunderbird-post.hook'...
[2021-08-02T13:54:20-0300] [ALPM] running 'update-desktop-database.hook'...
[2021-08-02T13:54:21-0300] [ALPM] running 'update-mime-database.hook'...
[2021-08-02T13:54:23-0300] [ALPM] running 'update-vlc-plugin-cache.hook'...
