No sound at boot.
Hi, I just installed Manjaro i3wm version at my SSD (I had an HDD) and I changed from alsa to pulse audio with the script by default of Manjaro (install_pulse) I log out, restarted and didn't work. I just tried pulseaudio --kill and pulseaudio --start and worked but I have to do it every time I boot. Anyway to fix this? could be a problem with the daemon of pulseaudio?. Thank you for reading and I hope you could help me:)
Try
killall pulseaudio
sudo systemctl enable pulseaudio
Failed to disable unit: Unit file pulseaudio.service does not exist.
Is the output to sudo systemctl disable pulseaudio
Try again
killall pulseaudio
Same output
Failed to enable unit: Unit file pulseaudio.service does not exist.
check pulseaudio systemd units with
systemctl --user status pulseaudio
systemctl --user status pulseaudio.socket
and try
systemctl --user restart pulseaudio
