I have tried multiple kernels, the last one i ended up on was linux-lts. I have tried messing withe the volume levels in alsamixer.
inxi -Fxzc0, and lspci -vnn selected.
Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Type: Laptop System: Micro-Star product: GE75 Raider 10SFS v: REV:1.0
serial: <filter>
Mobo: Micro-Star model: MS-17E9 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E17E9IMS.10C date: 09/21/2020
ID-1: BAT1 charge: 40.7 Wh condition: 44.3/53.4 Wh (83%)
model: MSI BIF0_9 status: Unknown
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: N/A L2 cache: 12.0 MiB
bogomips: 62431
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 801 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800
12: 800
Device-1: Intel UHD Graphics vendor: Micro-Star MSI driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q]
vendor: Micro-Star MSI driver: N/A bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: modesetting
resolution: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.80-2-MANJARO
Device-1: Intel Wireless-AC 9462/9560 vendor: Bigfoot Networks
driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel port: 3000
bus ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Local Storage: total: 1.84 TiB used: 16.87 GiB (0.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB
ID-2: /dev/nvme1n1 vendor: Western Digital
model: PC SN730 SDBPNTY-1T00-1032 size: 953.87 GiB
ID-1: / size: 491.15 GiB used: 16.84 GiB (3.4%) fs: ext4
dev: /dev/nvme1n1p5
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 308 Uptime: 2h 01m Memory: 31.19 GiB used: 3.61 GiB (11.6%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1337
Shell: Bash v: 5.0.18 inxi: 3.1.08
lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers [8086:9b54] (rev 02)
DeviceName: Onboard - Other
Subsystem: Micro-Star International Co., Ltd. [MSI] Device [1462:12bc]
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 02) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: c4000000-c50fffff [size=17M]
Prefetchable memory behind bridge: 00000000b0000000-00000000c20fffff [size=289M]
Kernel driver in use: pcieport
00:02.0 VGA compatible controller [0300]: Intel Corporation UHD Graphics [8086:9bc4] (rev 05) (prog-if 00 [VGA controller])
DeviceName: Onboard - Video
Flags: bus master, fast devsel, latency 0, IRQ 171
Memory at c3000000 (64-bit, non-prefetchable) [size=16M]
Memory at a0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 5000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:12.0 Signal processing controller [1180]: Intel Corporation Comet Lake PCH Thermal Controller [8086:06f9]
Flags: fast devsel, IRQ 255
Memory at c5523000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.0 USB controller [0c03]: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller [8086:06ed] (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 153
Memory at c5500000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation Comet Lake PCH Shared SRAM [8086:06ef]
Subsystem: Intel Corporation Device [8086:7270]
Flags: fast devsel
Memory at c551a000 (64-bit, non-prefetchable) [disabled] [size=8K]
Memory at c5522000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.3 Network controller [0280]: Intel Corporation Wireless-AC 9462/9560 [8086:06f0]
DeviceName: Onboard - Ethernet
Subsystem: Bigfoot Networks, Inc. Device [1a56:1652]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at c5514000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0 [8086:06e8]
Memory at 9fc00000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.2 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #2 [8086:06ea]
Flags: bus master, fast devsel, latency 0, IRQ 18
Memory at 9fc01000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller [0780]: Intel Corporation Comet Lake HECI Controller [8086:06e0]
Flags: bus master, fast devsel, latency 0, IRQ 154
Memory at c551f000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Device [8086:06d3] (prog-if 01 [AHCI 1.0])
DeviceName: Onboard - SATA
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 155
Memory at c5518000 (32-bit, non-prefetchable) [size=8K]
Memory at c551e000 (32-bit, non-prefetchable) [size=256]
I/O ports at 5090 [size=8]
I/O ports at 5080 [size=4]
I/O ports at 5060 [size=32]
Memory at c551d000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation Comet Lake PCI Express Root Port #17 [8086:06c0] (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00006000-00006fff [size=4K]
Memory behind bridge: 9f800000-9f9fffff [size=2M]
Prefetchable memory behind bridge: 000000009fa00000-000000009fbfffff [size=2M]
00:1b.4 PCI bridge [0604]: Intel Corporation Comet Lake PCI Express Root Port #21 [8086:06ac] (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: c5400000-c54fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
00:1d.0 PCI bridge [0604]: Intel Corporation Comet Lake PCI Express Root Port #9 [8086:06b0] (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 125
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: c5300000-c53fffff [size=1M]
00:1d.6 PCI bridge [0604]: Intel Corporation Device [8086:06b6] (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 126
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: c5200000-c52fffff [size=1M]
00:1f.0 ISA bridge [0601]: Intel Corporation Comet Lake LPC Controller [8086:068d]
00:1f.3 Audio device [0403]: Intel Corporation Comet Lake PCH cAVS [8086:06c8]
DeviceName: Onboard - Sound
Flags: bus master, fast devsel, latency 32, IRQ 172
Memory at c5510000 (64-bit, non-prefetchable) [size=16K]
Memory at c5100000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci
00:1f.4 SMBus [0c05]: Intel Corporation Comet Lake PCH SMBus Controller [8086:06a3]
Flags: medium devsel, IRQ 255
Memory at c551c000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller [8086:06a4]
Flags: fast devsel
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU104M [GeForce RTX 2070 SUPER Mobile / Max-Q] [10de:1e91] (rev a1) (prog-if 00 [VGA controller])
Memory at c4000000 (32-bit, non-prefetchable) [disabled] [size=16M]
Memory at b0000000 (64-bit, prefetchable) [disabled] [size=256M]
Memory at c0000000 (64-bit, prefetchable) [disabled] [size=32M]
I/O ports at 4000 [disabled] [size=128]
Expansion ROM at c5000000 [disabled] [size=512K]
Kernel modules: nouveau
03:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808] (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device [144d:a801]
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at c5400000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
04:00.0 Non-Volatile memory controller [0108]: Sandisk Corp Device [15b7:5006] (prog-if 02 [NVM Express])
Subsystem: Sandisk Corp Device [15b7:5006]
Memory at c5300000 (64-bit, non-prefetchable) [size=16K]
Memory at c5304000 (64-bit, non-prefetchable) [size=256]
05:00.0 Ethernet controller [0200]: Qualcomm Atheros Killer E2500 Gigabit Ethernet Controller [1969:e0b1] (rev 10)
Memory at c5200000 (64-bit, non-prefetchable) [size=256K]
I/O ports at 3000 [size=128]
Kernel driver in use: alx
Kernel modules: alx
and here is aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
dmesg | grep snd
gives nothing.
I was going to post journalctl but i dont have enough room here and also do not have permission to post links to my github gist.
Any help would be greatly appreciated!
