No sound after today's update on Lenovo Legion 7i
Hello, after today’s global update, I lost sound on my laptop Lenovo Legion 7i. I thought something broke the fix on the kernel that was provided in https://bugzilla.kernel.org/show_bug.cgi?id=208555, but even after upgrading the kernel to the newest one 5.16.2-1 I still got no sound from speakers. I get the sound if I use headphones which reminded me of the issue that I had before the fix above came in.
I think that the last update of manjaro-pulse has physically damaged my speakers because when switching to my other systems windows and Ubuntu there was no audio neither.
I got the same issue. How to solve this?
same issue here, but speakers working fine in windows
  Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=676f1d37-1626-4a91-a3ea-738e27e6572e rw apparmor=1
    security=apparmor resume=UUID=ffe5cc5e-ee24-4f35-994e-1a48208a36a1
    udev.log_priority=7
  Desktop: KDE Plasma 5.24.80 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 81YT v: Lenovo Legion 7 15IMH05
    serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 7 15IMH05
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
    serial: <superuser required> UEFI: LENOVO v: E9CN63WW(V4.08)
    date: 05/25/2021
  ID-1: BAT1 charge: 74.1 Wh (100.0%) condition: 74.1/80.0 Wh (92.7%)
    volts: 17.3 min: 15.4 model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31 0x39
    0x43 0x34 0x50 0x8000
    type: Li-ion serial: <filter> status: Full cycles: 53
  Info: model: Intel Core i9-10980HK bits: 64 type: MT MCP arch: Comet Lake
    family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3981 high: 4507 min/max: 800/5300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4507 2: 4058 3: 4305
    4: 3899 5: 4249 6: 3242 7: 3768 8: 3335 9: 4006 10: 3930 11: 4017 12: 4001
    13: 4035 14: 4310 15: 4001 16: 4034 bogomips: 99237
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU104BM [GeForce RTX 2080 SUPER Mobile / Max-Q]
    vendor: Lenovo driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm
    bus-ID: 01:00.0 chip-ID: 10de:1ed3 class-ID: 0300
  Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-6:3 chip-ID: 174f:2435 class-ID: 0e02
  Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
    loaded: modesetting display-ID: :0 screens: 1
    s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 240 dpi: 142
    size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.4
    direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
    chip-ID: 8086:06c8 class-ID: 0403
  Device-2: NVIDIA TU104 HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0-176-g4b996e running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 42:00.0
  IF: enp66s0 state: down mac: <filter>
  IF-ID-1: CloudflareWARP state: unknown speed: 10 Mbps duplex: full
    mac: N/A
    bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 1.4 TiB used: 122.84 GiB (8.6%)
    model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
    rev: 3L1QEXF7 temp: 40.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
    model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
    rev: 3L1QEXF7 temp: 46.9 C scheme: GPT
  ID-1: / raw-size: 919.39 GiB size: 903.89 GiB (98.31%)
    used: 122.83 GiB (13.6%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
    used: 12.3 MiB (4.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
  ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:8
  Message: No sensor data found. Is lm-sensors configured?
  Processes: 419 Uptime: 5m wakeups: 4 Memory: 31.06 GiB
  used: 6.49 GiB (20.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: 1735 pacman: 1725 lib: 486 flatpak: 10
  Shell: Zsh v: 5.8 default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.12
Jan 27 14:38:24 machine systemd-udevd[351]: snd_timer: Device is queued (SEQNUM=4520, ACTION=add)
Jan 27 14:38:24 machine systemd-udevd[351]: snd_pcm: Device is queued (SEQNUM=4567, ACTION=add)
Jan 27 14:38:24 machine systemd-udevd[351]: snd_hwdep: Device is queued (SEQNUM=4652, ACTION=add)
Jan 27 14:38:24 machine systemd-udevd[351]: snd_hda_core: Device is queued (SEQNUM=4688, ACTION=add)
Jan 27 14:38:24 machine kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
Jan 27 14:38:24 machine kernel: snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
Jan 27 14:38:24 machine kernel: snd_hda_intel 0000:00:1f.3: Applying patch firmware 'legion-alc287.patch'
Jan 27 14:38:24 machine kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
Jan 27 14:38:24 machine kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
Jan 27 14:38:24 machine kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
Jan 27 14:38:25 machine kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC287: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
Jan 27 14:38:25 machine kernel: snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x12
Hello again. So after trying many solutions like switching to pipewire, resetting the bios setting, nothing worked. I made sure that it is not a software issue by running my other systems Windows and PopOS that were installed next to Manjaro and that had working speaker audio beforehand. They was no sound coming from speakers as well even though I didn’t touch and they also had drivers working properly. So I just contacted Lenovo to send the device to a repair center and probably replace the faulty speakers.
