Hello, I just installed manjaro kde plasma on my huawei Matebook D14 and I can’t point out why there is no sound. I tried to :
- install pipewire instead of pulseaudio
- install sof-firmware
- update all the drivers and bios
Nothing of the above tries succeed.
Here is the information of my laptop :
inxi -Fxxxx
Host: rico-laptop Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.2.0 Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HUAWEI product: NBD-WXX9 v: M1010
serial: <superuser required>
Mobo: HUAWEI model: NBD-WXX9-PCB-B3 v: M1010 serial: <superuser required>
UEFI: HUAWEI v: 2.30 date: 07/04/2022
ID-1: BAT1 charge: 25.7 Wh (46.0%) condition: 55.9/54.9 Wh (101.8%)
volts: 7.6 min: 7.6 model: Sunwoda-H HB4692Z9ECW-22T type: Li-ion
serial: 24875 status: discharging cycles: 2
Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake level: v4 rev: 1 cache: L1: 320 KiB L2: 5 MiB
L3: 8 MiB
Speed (MHz): avg: 880 high: 1050 min/max: 400/4200 cores: 1: 936 2: 504
3: 958 4: 1016 5: 913 6: 995 7: 1050 8: 670 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: QUANTA
driver: i915 v: kernel arch: Gen-12.1 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 1-6:3
chip-ID: 13d3:5476 class-ID: fe01 serial: 0001
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0877 res: 1920x1080 hz: 60 dpi: 158
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: QUANTA
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.57 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: up mac: a4:6b:b6:9c:a7:02
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 11.26 GiB (2.4%)
ID-1: /dev/nvme0n1 model: 311CD0512GB size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 type: SSD serial: 511211007078075835 rev: EDFOB0.7 temp: 35.9 C
scheme: GPT
ID-1: / size: 97.87 GiB used: 11.22 GiB (11.5%) fs: ext4
dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 196 MiB used: 46.2 MiB (23.6%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 242 Uptime: 3m wakeups: 595 Memory: 15.43 GiB used: 2.93 GiB
(19.0%) Init: systemd v: 251 default: graphical Compilers: gcc: 12.2.0
clang: 14.0.6 Packages: pm: pacman pkgs: 1199 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.21
Thanks in advance for your help !!
