Hi all,
After boot I dont have a sound, it is muted.
I got them working only after running pulseaudio from terminal.
Also got this :
[marko@Hpenvy13 ~]$ pulseaudio
W: [pulseaudio] module.c: module-combine is deprecated: Please use module-combine-sink instead of module-combine!
W: [pulseaudio] module-combine.c: We will now load module-combine-sink. Please make sure to remove module-combine from your configuration.
I don’t know what I did wrong.
I installed pulseaudio-git
from AUR.
Some more infos :
inxi -Fxxxz
output:
> [marko@Hpenvy13 ~]$ inxi -Fxxxz > System: > Kernel: 5.10.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 > Desktop: KDE Plasma 5.20.2 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM > Distro: Manjaro Linux > Machine: > Type: Convertible System: HP > product: HP ENVY x360 Convertible 13-ar0xxx v: N/A serial: <filter> > Chassis: type: 31 serial: <filter> > Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.19 > date: 12/26/2019 > Battery: > ID-1: BAT0 charge: 53.4 Wh condition: 53.4/53.4 Wh (100%) > volts: 16.9/15.4 model: 333-2B-49-A KC04053XL type: Li-ion > serial: <filter> status: Discharging > Device-1: hid-0018:04F3:23B9.0001-battery model: ELAN2514:00 04F3:23B9 > serial: N/A charge: N/A status: N/A > CPU: > Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx > bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB > flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm > bogomips: 33551 > Speed: 1221 MHz min/max: 1400/2100 MHz boost: enabled > Core speeds (MHz): 1: 1374 2: 1359 3: 1223 4: 1222 5: 1222 6: 1222 > 7: 1397 8: 1309 > Graphics: > Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel > bus ID: 04:00.0 chip ID: 1002:15d8 > Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo > bus ID: 3-1:2 chip ID: 04ca:709d > Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu > FAILED: ati unloaded: modesetting alternate: fbdev,vesa > resolution: 1920x1080~60Hz s-dpi: 96 > OpenGL: renderer: AMD RAVEN (DRM 3.40.0 5.10.0-1-MANJARO LLVM 10.0.1) > v: 4.6 Mesa 20.2.1 direct render: Yes > Audio: > Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio > vendor: Hewlett-Packard driver: snd_hda_intel v: kernel > bus ID: 04:00.1 chip ID: 1002:15de > Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor > vendor: Hewlett-Packard driver: N/A bus ID: 04:00.5 chip ID: 1022:15e2 > Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard > driver: snd_hda_intel v: kernel bus ID: 04:00.6 chip ID: 1022:15e3 > Sound Server: ALSA v: k5.10.0-1-MANJARO > Network: > Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter > vendor: Hewlett-Packard driver: rtw_8822be v: N/A port: f000 > bus ID: 02:00.0 chip ID: 10ec:b822 > IF: wlo1 state: up mac: <filter> > Drives: > Local Storage: total: 476.94 GiB used: 10.48 GiB (2.2%) > ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H > size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0 > scheme: GPT > Partition: > ID-1: / size: 247.08 GiB used: 9.70 GiB (3.9%) fs: ext4 > dev: /dev/nvme0n1p2 > ID-2: /home size: 220.09 GiB used: 798.2 MiB (0.4%) fs: ext4 > dev: /dev/nvme0n1p3 > Swap: > Alert: No Swap data was found. > Sensors: > System Temperatures: cpu: 38.4 C mobo: 35.0 C > Fan Speeds (RPM): N/A > Info: > Processes: 253 Uptime: 18m Memory: 5.74 GiB used: 2.04 GiB (35.6%) > Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1237 > Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
aplay --list-pcms
output:
> [marko@Hpenvy13 ~]$ aplay --list-pcms > null > Discard all samples (playback) or generate zero samples (capture) > samplerate > Rate Converter Plugin Using Samplerate Library > speexrate > Rate Converter Plugin Using Speex Resampler > jack > JACK Audio Connection Kit > oss > Open Sound System > pipewire > PipeWire Sound Server > pulse > PulseAudio Sound Server > speex > Plugin using Speex DSP (resample, agc, denoise, echo, dereverb) > upmix > Plugin for channel upmix (4,6,8) > vdownmix > Plugin for channel downmix (stereo) with a simple spacialization > default > Default ALSA Output (currently PulseAudio Sound Server) > hdmi:CARD=Generic,DEV=0 > HD-Audio Generic, HDMI 0 > HDMI Audio Output > usbstream:CARD=Generic > HD-Audio Generic > USB Stream Output > sysdefault:CARD=Generic_1 > HD-Audio Generic, ALC285 Analog > Default Audio Device > front:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > Front output / input > surround21:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > 2.1 Surround output to Front and Subwoofer speakers > surround40:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > 4.0 Surround output to Front and Rear speakers > surround41:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > 4.1 Surround output to Front, Rear and Subwoofer speakers > surround50:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > 5.0 Surround output to Front, Center and Rear speakers > surround51:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > 5.1 Surround output to Front, Center, Rear and Subwoofer speakers > surround71:CARD=Generic_1,DEV=0 > HD-Audio Generic, ALC285 Analog > 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers > usbstream:CARD=Generic_1 > HD-Audio Generic > USB Stream Output
`amixer --card= output:
> [marko@Hpenvy13 ~]$ amixer --card=0 > Simple mixer control 'IEC958',0 > Capabilities: pswitch pswitch-joined > Playback channels: Mono > Mono: Playback [on] > [marko@Hpenvy13 ~]$ amixer --card=1 > Simple mixer control 'Master',0 > Capabilities: pvolume pvolume-joined pswitch pswitch-joined > Playback channels: Mono > Limits: Playback 0 - 87 > Mono: Playback 0 [0%] [-65.25dB] [on] > Simple mixer control 'Headphone',0 > Capabilities: pvolume pswitch > Playback channels: Front Left - Front Right > Limits: Playback 0 - 87 > Mono: > Front Left: Playback 0 [0%] [-65.25dB] [off] > Front Right: Playback 0 [0%] [-65.25dB] [off] > Simple mixer control 'Speaker',0 > Capabilities: pvolume pswitch > Playback channels: Front Left - Front Right > Limits: Playback 0 - 87 > Mono: > Front Left: Playback 76 [87%] [-8.25dB] [on] > Front Right: Playback 76 [87%] [-8.25dB] [on] > Simple mixer control 'Bass Speaker',0 > Capabilities: pswitch > Playback channels: Front Left - Front Right > Mono: > Front Left: Playback [on] > Front Right: Playback [on] > Simple mixer control 'PCM',0 > Capabilities: pvolume > Playback channels: Front Left - Front Right > Limits: Playback 0 - 255 > Mono: > Front Left: Playback 255 [100%] [0.00dB] > Front Right: Playback 255 [100%] [0.00dB] > Simple mixer control 'Mic Boost',0 > Capabilities: volume > Playback channels: Front Left - Front Right > Capture channels: Front Left - Front Right > Limits: 0 - 3 > Front Left: 0 [0%] [0.00dB] > Front Right: 0 [0%] [0.00dB] > Simple mixer control 'Capture',0 > Capabilities: cvolume cswitch > Capture channels: Front Left - Front Right > Limits: Capture 0 - 63 > Front Left: Capture 63 [100%] [30.00dB] [on] > Front Right: Capture 63 [100%] [30.00dB] [on] > Simple mixer control 'Auto-Mute Mode',0 > Capabilities: enum > Items: 'Disabled' 'Enabled' > Item0: 'Enabled' > Simple mixer control 'Internal Mic Boost',0 > Capabilities: volume > Playback channels: Front Left - Front Right > Capture channels: Front Left - Front Right > Limits: 0 - 3 > Front Left: 1 [33%] [10.00dB] > Front Right: 1 [33%] [10.00dB]
