No songs in ncmpcpp
#1
I’ve installed mpd and ncmpcpp with no problem but every time I run ncmpcpp, no songs showed up. I’ve tried installing both using the arch wiki twice, using a script to install it, and have use a different guide to install everything. Each time everything installs fine but nothing shows up. The only reason I can thinks it’s not working is when I run mpd in the terminal I get
Jan 10 16:21 : exception: Failed to bind to ‘127.0.0.1:6600’
Jan 10 16:21 : exception: nested: Failed to bind socket: Address already in use
heres my mpd.config file
bind_to_address “127.0.0.1”
#bind_to_address “~/.mpd/socket”
music_directory “~/Music”
playlist_directory “~/.mpd/playlists”
db_file “~/.mpd/mpd.db”
log_file “~/.mpd/mpd.log”
pid_file “~/.mpd/mpd.pid”
state_file “~/.mpd/mpdstate”
audio_output {
type “alsa”
name “Alsa for audio sound card”
mixer_type “software” # optional
audio_output {
type “fifo”
name “my_fifo”
path “/tmp/mpd.fifo”
format “44100:16:2”
and heres my config file for ncmpcpp
Files
mpd_music_dir = “~/Music”
lyrics_directory = ~/.ncmpcpp/lyrics
ncmpcpp_directory = ~/.ncmpcpp
mpd_host = “127.0.0.1”
mpd_port = “6600”
mpd_connection_timeout = “5”
mpd_crossfade_time = “5”
Playlist
playlist_disable_highlight_delay = “0”
playlist_display_mode = “columns”
playlist_show_remaining_time = “yes”
browser_display_mode = “columns”
autocenter_mode = “yes”
fancy_scrolling = “yes”
follow_now_playing_lyrics = “yes”
display_screens_numbers_on_start = “yes”
ignore_leading_the = “yes”
lyrics_database = “1”
song_columns_list_format = “(10)[blue]{l} (30)[green]{a} (30)[magenta]{b} (50)[yellow]{t}”
colors_enabled = “yes”
main_window_color = “white”
main_window_highlight_color = “blue”
header_window_color = “cyan”
volume_color = “red”
progressbar_color = “cyan”
statusbar_color = “white”
active_column_color = “cyan”
active_window_border = “blue”
alternative_header_first_line_format = “$0$aqqu$/a {$7%a - $9}{$5%t$9}|{$8%f$9} $0$atqq$/a$9”
alternative_header_second_line_format = “{{$6%b$9}{ [$6%y$9]}}|{%D}”
song_list_format = “{$3%n │ $9}{$7%a - $9}{$5%t$9}|{$8%f$9}$R{$6 │ %b$9}{$3 │ %l$9}”
user_interface = “alternative”
#user_interface = “classic”
default_place_to_search_in = “database”
visualizer
visualizer_fifo_path = “/tmp/mpd.fifo”
visualizer_output_name = “my_fifo”
visualizer_sync_interval = “12”
#visualizer_type = “wave” (spectrum/wave)
visualizer_type = “spectrum” (spectrum/wave)
visualizer_in_stereo = “yes”
visualizer_look = “+|”
Navigation
cyclic_scrolling = “yes”
header_text_scrolling = “yes”
jump_to_now_playing_song_at_start = “yes”
lines_scrolled = “2”
Other
system_encoding = “utf-8”
regular_expressions = “extended”
Selected tracks
selected_item_prefix = "* "
discard_colors_if_item_is_selected = “no”
Seeking
incremental_seeking = “yes”
seek_time = “1”
Visivility
header_visibility = “yes”
statusbar_visibility = “yes”
titles_visibility = “yes”
progressbar_look = “=>-”
progressbar_boldness = “yes”
progressbar_elapsed_color = “white”
now_playing_prefix = "> "
song_status_format = " $2%a $4⟫$3⟫ $8%t $4⟫$3⟫ $5%b "
centered_cursor = “yes”
Misc
display_bitrate = “yes”
enable_window_title = “no”
empty_tag_marker = “”
#2
Are you running “mpd” before running “ncmpcpp”?
Try this:
-run mpd
-run ncmpcpp
-then press ‘u’ in order to update the database
you gotta start the daemons for ncmpcpp to work :japanese_ogre:
#3
wow that worked :confused: so weird cause I could of sworn I did that before. anyways, thank you sop much for your help :relieved:
