After latest update i get a black screen after login (KDE Plasma/Nvidia)
The current theme cannot be loaded due to errors below, Please select another theme.
file:///usr/share/sddm/themes/breath/Main.qml: No such file or directory
Running from USB, checking /home/trygve/local/share/sddm/xorg-session.log:
/usr/bin/ksplashqml: symbol lookup error: /usr/lib/libKF6KIOWidgets.so.6: undefined symbol: _ZN11KJobWidgets12windowHandleEP7QObjec
How to fix this ?
Hello,
did you try switching between X11/Wayland yet?
You may know, you can do that with the login screen, there is a button at the bottom left of your screen.
Well, we ship a lot of updates to many branches of Manjaro. Are you on the Stable branch? Maybe check the /var/log/pacman.log
to see which packages got updated on your end and let us know.
OK, will try that.
Thanks.
I’m on the stable branch.
Not very good at Linux yet, the log does not tell me much.
[2024-08-11T23:08:39+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -Sy nvidia-utils nvidia-settings libxnvctrl lib32-nvidia-utils linux69-nvidia'
[2024-08-11T23:08:39+0000] [PACMAN] synchronizing package lists
[2024-08-11T23:08:48+0000] [ALPM] transaction started
[2024-08-11T23:08:48+0000] [ALPM] installed eglexternalplatform (1.1-3)
[2024-08-11T23:08:48+0000] [ALPM] installed egl-wayland (3:1.1.13-1)
[2024-08-11T23:08:49+0000] [ALPM] installed nvidia-utils (550.100-1)
[2024-08-11T23:08:49+0000] [ALPM-SCRIPTLET] If you run into trouble with CUDA not being available, run nvidia-modprobe first.
[2024-08-11T23:08:49+0000] [ALPM-SCRIPTLET] If you use GDM on Wayland, you might have to run systemctl enable --now nvidia-resume.service
[2024-08-11T23:08:49+0000] [ALPM] installed libxnvctrl (550.100-1)
[2024-08-11T23:08:49+0000] [ALPM] installed nvidia-settings (550.100-1)
[2024-08-11T23:08:50+0000] [ALPM] installed lib32-nvidia-utils (550.100-1)
[2024-08-11T23:08:50+0000] [ALPM] installed linux69-nvidia (550.100-2)
[2024-08-11T23:08:55+0000] [ALPM] transaction completed
[2024-08-11T23:08:55+0000] [ALPM] running '20-systemd-sysusers.hook'...
[2024-08-11T23:08:55+0000] [ALPM-SCRIPTLET] Creating group 'nvidia-persistenced' with GID 143.
[2024-08-11T23:08:55+0000] [ALPM-SCRIPTLET] Creating user 'nvidia-persistenced' (NVIDIA Persistence Daemon) with UID 143 and GID 143.
[2024-08-11T23:08:55+0000] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-08-11T23:08:55+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-08-11T23:08:55+0000] [ALPM] running '30-systemd-update.hook'...
[2024-08-11T23:08:55+0000] [ALPM] running '60-depmod.hook'...
[2024-08-11T23:09:00+0000] [ALPM] running '90-mkinitcpio-install.hook'...
[2024-08-11T23:09:00+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'default'
[2024-08-11T23:09:00+0000] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-08-11T23:09:00+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64.img
[2024-08-11T23:09:00+0000] [ALPM-SCRIPTLET] ==> Starting build: '6.9.10-1-MANJARO'
[2024-08-11T23:09:00+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2024-08-11T23:09:01+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2024-08-11T23:09:01+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2024-08-11T23:09:01+0000] [ALPM-SCRIPTLET] ==> WARNING: cannot detect type of overlayfs root filesystem
[2024-08-11T23:09:01+0000] [ALPM-SCRIPTLET] -> Running build hook: [microcode]
[2024-08-11T23:09:01+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2024-08-11T23:09:01+0000] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2024-08-11T23:09:04+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2024-08-11T23:09:04+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-08-11T23:09:04+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2024-08-11T23:09:04+0000] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2024-08-11T23:09:04+0000] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2024-08-11T23:09:04+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2024-08-11T23:09:05+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2024-08-11T23:09:05+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2024-08-11T23:09:06+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-08-11T23:09:06+0000] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64.img'
[2024-08-11T23:09:06+0000] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'fallback'
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64-fallback.img -S autodetect
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] ==> Starting build: '6.9.10-1-MANJARO'
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [microcode]
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2024-08-11T23:09:07+0000] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2024-08-11T23:09:10+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2024-08-11T23:09:17+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2024-08-11T23:09:17+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-08-11T23:09:18+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2024-08-11T23:09:18+0000] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2024-08-11T23:09:18+0000] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2024-08-11T23:09:18+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2024-08-11T23:09:18+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2024-08-11T23:09:18+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2024-08-11T23:09:19+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2024-08-11T23:09:19+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2024-08-11T23:09:19+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2024-08-11T23:09:19+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2024-08-11T23:09:20+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2024-08-11T23:09:22+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2024-08-11T23:09:28+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-08-11T23:09:28+0000] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64-fallback.img'
[2024-08-11T23:09:31+0000] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2024-08-11T23:09:32+0000] [ALPM] running '90-nvidia-utils.hook'...
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'default'
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64.img
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] ==> Starting build: '6.9.10-1-MANJARO'
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2024-08-11T23:09:32+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2024-08-11T23:09:33+0000] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2024-08-11T23:09:33+0000] [ALPM-SCRIPTLET] ==> WARNING: cannot detect type of overlayfs root filesystem
[2024-08-11T23:09:33+0000] [ALPM-SCRIPTLET] -> Running build hook: [microcode]
[2024-08-11T23:09:33+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2024-08-11T23:09:33+0000] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2024-08-11T23:09:38+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2024-08-11T23:09:38+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-08-11T23:09:38+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2024-08-11T23:09:38+0000] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2024-08-11T23:09:38+0000] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2024-08-11T23:09:38+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2024-08-11T23:09:39+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2024-08-11T23:09:40+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2024-08-11T23:09:42+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-08-11T23:09:42+0000] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64.img'
[2024-08-11T23:09:43+0000] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'fallback'
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64-fallback.img -S autodetect
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] ==> Starting build: '6.9.10-1-MANJARO'
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2024-08-11T23:09:44+0000] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2024-08-11T23:09:45+0000] [ALPM-SCRIPTLET] -> Running build hook: [microcode]
[2024-08-11T23:09:45+0000] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2024-08-11T23:09:45+0000] [ALPM-SCRIPTLET] -> Running build hook: [kms]
[2024-08-11T23:09:47+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'ast'
[2024-08-11T23:09:54+0000] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2024-08-11T23:09:54+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2024-08-11T23:09:55+0000] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2024-08-11T23:09:55+0000] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2024-08-11T23:09:55+0000] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2024-08-11T23:09:55+0000] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2024-08-11T23:09:56+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2024-08-11T23:09:56+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2024-08-11T23:09:56+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2024-08-11T23:09:56+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2024-08-11T23:09:56+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2024-08-11T23:09:56+0000] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2024-08-11T23:09:57+0000] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2024-08-11T23:09:58+0000] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2024-08-11T23:10:03+0000] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2024-08-11T23:10:04+0000] [ALPM-SCRIPTLET] ==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64-fallback.img'
[2024-08-11T23:10:06+0000] [ALPM-SCRIPTLET] -> Early uncompressed CPIO image generation successful
[2024-08-11T23:10:07+0000] [ALPM-SCRIPTLET] ==> Initcpio image generation successful
[2024-08-11T23:10:07+0000] [ALPM] running '90-packagekit-refresh.hook'...
[2024-08-11T23:10:07+0000] [ALPM] running 'dbus-reload.hook'...
[2024-08-11T23:10:07+0000] [ALPM] running 'update-desktop-database.hook'...
[2024-08-11T23:10:07+0000] [PACMAN] Running 'pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / -D --asexplicit nvidia-utils nvidia-settings libxnvctrl lib32-nvidia-utils linux69-nvidia'
[2024-08-11T23:11:48+0000] [PAMAC] synchronizing package lists
No way to select Wayland under selections.
Its maybe worth to complete forum tutorial… you just replied to yourself above and you didn’t posted the code as Preformatted text.
What you mean with no way to select Wayland? Isn’t the selection button there?
Do you have a Timeshift snapshot before you did the update?
Please edit your post, and add a blank line above and below your pasted Terminal text, putting three backticks ``` or three tildes ~~~ in each newly-created blank line …
… Or, select the pasted Terminal output and click the </> button above the reply window.
Cheers! We’ll all be grateful! It makes Terminal output much easier to read on the Forums, in general.
The selection button is there but the field is blank.
No working Timeshift snapshot.
Will check the tutorial.
