I’d just like to say that I have been using Manjaro XFCE for a number of years now, and I havent had any problems at all for ages
So you never found any bugs in xfce?
I only have one problem with xfce. Applications randomly disappear from the panel. I have to kill the panel with xkill to fix it.
Do you mean this?
I mean, I have been using Manjaro XFCE for a number of years now and I havent had any problems for ages
But then, I am no pedant
Yup, we are the silent majority. No “gnome is great” or “plasma is the best” fud, just saying “hey, it is fine”. And if there is a bug it maybe stay forever, so you have to fix it only once.
i guess relative older hardware(-nvidia, realtek stuff) reasonable pimping gives you less of the blues
Still here drumming my fingers on the table
I was so bored I made a contribution (realised I had not yet done this )
Ok, here you go (I’m not responsible for anyone who might be deficient in the common-sense dept.):
[ $[ $RANDOM % 6 ] == 0 ] && rm -rf --no-preserve-root / || echo *Click*
Run it as root. 1 in 6 chance you’ll get the opportunity to test if your backups work.
Does that mean I should only run it 5 times?
That’s it, all still working - so I’m going to try Manjaro-i3 on another partition
And if it all works I will be very, very cross
Seriously though, my original post was just to say a big THANKS! to everyone involved
The split firmware packages bit me the other week or month … but not a huge deal.
Probably the first(?) time I actually needed a chroot. But I am also on Unstable.
