No plasma deskop after login
Hello together,
I need your help. After login there comes no plasma desktop. Only a black screen and my mouse. But the funktion keys like alt+f2 to start applications as dolphin or firefox are ok. Also I can start yakuake with F12.
please look to this thread into the german part for more details.
[Nach der Anmeldung kein Plasma Desktop](https:
//forum.manjaro.org/t/nach-der-anmeldung-kein-plasma-desktop/82123)
I hope, you can help me
thank you :face_with_head_bandage:
caho
What i saw in that post you pointed out is that you have akonadi running ... but there are a couple of problems with it.
See if this will help
This thread seems to treat a similar problem as yours, a problem with cups _ZN8JobModel9updateJobEiRK8KCupsJob (libkcupslib.so)
The solution on the thread is a bit radical and will keep you unable to print
(sudo -R print-manager) so before trying that, first try deleting queued print jobs
cancel -a -x
as suggested here and explained here
Hello, @saedlar93,
you are right. The problem was, that there were two printers in the config. One printer was installed by cups, the other was installed by ksettings -> printer. Thank you very much for your hint.
I don´t know, how does cups installed the printer without my userhandling.
The solution: I deleted the "cups printer", logged out and logged in and the desktop was shown again :grinning::slightly_smiling_face::upside_down_face:
Hello @bogdancovaciu,
thanks for your hint, too.
How can I deactivate akonadi? I think, I don´t need them.
regards
caho
