I am usually a re-installer when it comes to issues but with working from home its time I figured out how to repair some of the minor bugs I keep seeing. I am currently running Xfce 4.14.2. I just updated my system and restarted which seems to have made a reoccurring issue(s) reappear. On start up it seems either the panel doesn’t load properly and/or I do not have wallpaper and context menu, just black desktops. Typically I can still utilize the system with the terminal and get to where I need to be to work. I am looking for information on how to figure out why these items don’t seem to load properly and if there is a fix. If I restart enough times typically both will load but the frequency of the issue has me concerned I may not be able to connect to work in a timely manner. I have seen similar issues addressed in the past but haven’t been able to track them down so far. Thank you for the help in advanced and let me know what other information I may provide.
I receive and error message when I looked to at the panel preferences when the panel doesn’t load:
Failed to show the preferences dialog
GDBus.Error.org.freedesktop.DBus.Error.ServiceUnkown: The name org.xfce.Panel was not provided by any .service files
Kernel: 5.4.58-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.14.2 Distro: Manjaro Linux
Type: Desktop System: Dell product: Precision WorkStation T5500 v: N/A
serial: <superuser/root required>
Mobo: Dell model: 0CRH6C v: A01 serial: <superuser/root required>
BIOS: Dell v: A15 date: 02/06/2013
6-Core: Intel Xeon E5645 type: MCP speed: 1666 MHz
Device-1: NVIDIA GF106GL [Quadro 2000] driver: nouveau v: kernel
Display: x11 server: X.Org 1.20.8 driver: nouveau unloaded: modesetting
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: NVC3 v: 4.3 Mesa 20.1.5
Device-1: Broadcom and subsidiaries NetXtreme BCM5761 Gigabit Ethernet PCIe driver: tg3
Local Storage: total: 3.41 TiB used: 122.03 GiB (3.5%)
Processes: 175 Uptime: 8m Memory: 11.69 GiB used: 1.01 GiB (8.6%)
Shell: Bash inxi: 3.1.05
