Fresh installation
journalctl -x -p3 -b1
-- Logs begin at Sun 2020-11-22 10:42:28 IST, end at Sun 2020-11-22 15:40:19 IST. --
Nov 22 10:42:28 manjaro kernel: platform MSFT0101:00: failed to claim resource 1: [mem 0xfed40000-0xfed40fff]
Nov 22 10:42:28 manjaro kernel: acpi MSFT0101:00: platform device creation failed: -16
Nov 22 10:42:31 manjaro kernel: snd_hda_intel 0000:01:00.1: no codecs found!
Nov 22 10:43:09 manjaro kwin_x11[931]: kwin_xkbcommon: XKB: couldn't find a Compose file for locale "en_IN"
Nov 22 10:43:13 manjaro pulseaudio[992]: Failed to find a working profile.
Nov 22 10:43:13 manjaro pulseaudio[992]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1">
Nov 22 11:16:09 manjaro systemd-coredump[7045]: Failed to send coredump datagram: Connection reset by peer
Nov 22 11:16:09 manjaro kglobalaccel5[7072]: This application failed to start because no Qt platform plugin could be initialized. R>
Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb, minimal, min>
Nov 22 11:16:09 manjaro systemd-coredump[7086]: Failed to connect to coredump service: Connection refused
Nov 22 11:16:09 manjaro systemd[869]: Failed to start KDE Global Shortcuts Server.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 407 and the job result is failed.
Nov 22 11:16:09 manjaro pulseaudio[7073]: Failed to find a working profile.
Nov 22 11:16:09 manjaro pulseaudio[7073]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1>
Nov 22 11:16:10 manjaro pulseaudio[7073]: Unable to contact D-Bus session bus: org.freedesktop.DBus.Error.NoReply: Did not receive >
Nov 22 11:16:10 manjaro pulseaudio[7073]: Failed to load module "module-jackdbus-detect" (argument: "channels=2"): initialization f>
Nov 22 11:16:10 manjaro pulseaudio[7073]: Failed to find a working profile.
Nov 22 11:16:10 manjaro pulseaudio[7073]: Failed to load module "module-alsa-card" (argument: "device_id="1" name="pci-0000_01_00.1>
Nov 22 11:16:16 manjaro kernel: watchdog: watchdog0: watchdog did not stop!
