ago 06 18:34:29 spitocco kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
ago 06 18:34:29 spitocco kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
ago 06 18:34:29 spitocco kernel: #3
ago 06 18:34:29 spitocco kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
ago 06 18:34:29 spitocco kernel: pci 0000:00:14.0: can't derive routing for PCI INT A
ago 06 18:34:29 spitocco kernel: pci 0000:00:14.0: PCI INT A: no GSI
ago 06 18:34:29 spitocco kernel: ata1.00: LPM support broken, forcing max_power
ago 06 18:34:29 spitocco kernel: xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
ago 06 18:34:29 spitocco kernel: xhci_hcd 0000:00:14.0: PCI INT A: no GSI
ago 06 18:34:29 spitocco kernel: usb: port power management may be unreliable
ago 06 18:34:32 spitocco kernel: wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
ago 06 18:34:32 spitocco kernel: r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
ago 06 18:34:32 spitocco kernel: at24 0-0050: supply vcc not found, using dummy regulator
ago 06 18:34:34 spitocco kernel: kauditd_printk_skb: 3 callbacks suppressed
ago 06 18:34:34 spitocco kernel: bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
ago 06 18:34:39 spitocco kernel: kauditd_printk_skb: 13 callbacks suppressed
ago 06 18:34:44 spitocco systemd-xdg-autostart-generator[551]: /home/simone/.config/autostart/auto:1: Assignment outside of section. Ignoring.
ago 06 18:34:45 spitocco systemd-xdg-autostart-generator[551]: /home/simone/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, error parsing Exec= line: No such file or directory
ago 06 18:34:46 spitocco kernel: kauditd_printk_skb: 20 callbacks suppressed
ago 06 18:34:47 spitocco gdm-autologin][520]: gkr-pam: couldn't unlock the login keyring.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (--) Log file renamed from "/home/simone/.local/share/xorg/Xorg.pid-579.log" to "/home/simone/.local/share/xorg/Xorg.0.log"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: X.Org X Server 1.21.1.4
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: X Protocol Version 11, Revision 0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Current Operating System: Linux spitocco 5.15.57-2-MANJARO #1 SMP PREEMPT Mon Jul 25 01:32:51 UTC 2022 x86_64
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=8a85193d-3bb5-427c-88ec-82c778d69107 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Current version of pixman: 0.40.0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Before reporting problems, check http://wiki.x.org
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: to make sure that you have the latest version.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Markers: (--) probed, (**) from config file, (==) default setting,
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (++) from command line, (!!) notice, (II) informational,
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Log file: "/home/simone/.local/share/xorg/Xorg.0.log", Time: Sat Aug 6 18:34:48 2022
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Using config directory: "/etc/X11/xorg.conf.d"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) No Layout section. Using the first Screen section.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) No screen section available. Using defaults.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (**) |-->Screen "Default Screen Section" (0)
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (**) | |-->Monitor "<default monitor>"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) No monitor specified for screen "Default Screen Section".
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Using a default monitor configuration.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Automatically adding devices
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Automatically enabling devices
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Automatically adding GPU devices
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Automatically binding GPU devices
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Max clients allowed: 256, resource mask: 0x1fffff
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) The directory "/usr/share/fonts/misc" does not exist.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Entry deleted from font path.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) FontPath set to:
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: /usr/share/fonts/TTF
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) ModulePath set to "/usr/lib/xorg/modules"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) The server relies on udev to provide the list of input devices.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: If no devices become available, reconfigure udev or disable AutoAddDevices.
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Module ABI versions:
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: X.Org ANSI C Emulation: 0.4
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: X.Org Video Driver: 25.2
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: X.Org XInput driver : 24.4
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: X.Org Server Extension : 10.0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (++) using VT number 2
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) xfree86: Adding drm device (/dev/dri/card0)
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (--) PCI:*(0@0:2:0) 8086:1616:103c:803a rev 9, Mem @ 0xc1000000/16777216, 0xb0000000/268435456, I/O @ 0x00006000/64, BIOS @ 0x????????/131072
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "glx"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Module glx: vendor="X.Org Foundation"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: compiled for 1.21.1.4, module version = 1.0.0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: ABI class: X.Org Server Extension, version 10.0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Matched modesetting as autoconfigured driver 0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Matched fbdev as autoconfigured driver 1
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Matched vesa as autoconfigured driver 2
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) Assigned the driver to the xf86ConfigLayout
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "modesetting"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Module modesetting: vendor="X.Org Foundation"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: compiled for 1.21.1.4, module version = 1.21.1
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: Module class: X.Org Video Driver
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: ABI class: X.Org Video Driver, version 25.2
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "fbdev"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) Warning, couldn't open module fbdev
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (EE) Failed to load module "fbdev" (module does not exist, 0)
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "vesa"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) Warning, couldn't open module vesa
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (EE) Failed to load module "vesa" (module does not exist, 0)
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): using drv /dev/dri/card0
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Creating default Display subsection in Screen section
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: "Default Screen Section" for depth/fbbpp 24/32
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): RGB weight 888
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): Default visual is TrueColor
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Loading sub module "glamoregl"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "glamoregl"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: (II) Module glamoregl: vendor="X.Org Foundation"
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: compiled for 1.21.1.4, module version = 1.0.1
ago 06 18:34:48 spitocco /usr/lib/gdm-x-session[579]: ABI class: X.Org ANSI C Emulation, version 0.4
ago 06 18:34:50 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 5500 (BDW GT2)
ago 06 18:34:50 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): glamor initialized
ago 06 18:34:50 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): VariableRefresh: disabled
ago 06 18:34:50 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): AsyncFlipSecondaries: disabled
ago 06 18:34:50 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output eDP-1 has no monitor section
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output DP-1 has no monitor section
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output HDMI-1 has no monitor section
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID for output eDP-1
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Manufacturer: SDC Model: 4a51 Serial#: 0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Year: 2013 Week: 0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID Version: 1.4
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Digital Display Input
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 6 bits per channel
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Digital interface is undefined
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Gamma: 2.20
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): No DPMS capabilities specified
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): First detailed timing is preferred mode
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Preferred mode is native pixel format and refresh rate
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): redX: 0.575 redY: 0.335 greenX: 0.340 greenY: 0.560
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): blueX: 0.160 blueY: 0.125 whiteX: 0.313 whiteY: 0.329
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Manufacturer's mask: 0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Supported detailed timing:
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): clock: 76.3 MHz Image Size: 344 x 194 mm
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): h_active: 1366 h_sync: 1430 h_sync_end 1478 h_blank_end 1606 h_border: 0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): v_active: 768 v_sync: 770 v_sync_end 775 v_blanking: 792 v_border: 0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): clock: 50.8 MHz Image Size: 344 x 194 mm
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Unknown vendor-specific block 2
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID (in hex):
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 00ffffffffffff004c83514a00000000
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 00170104902213780a71059355578f29
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 20505400000001010101010101010101
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 010101010101ce1d56f0500018304030
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 250058c210000019d81356f050001830
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 4030250058c210000019000000000000
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 00000000000000000000000000000002
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): 000c4cff0a3c64141524640000000002
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Printing probed modes for output eDP-1
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1366x768"x60.0 76.30 1366 1430 1478 1606 768 770 775 792 -hsync -vsync (47.5 kHz eP)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1366x768"x39.9 50.80 1366 1430 1478 1606 768 770 775 792 -hsync -vsync (31.6 kHz e)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID for output DP-1
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID for output HDMI-1
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output eDP-1 connected
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output DP-1 disconnected
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output HDMI-1 disconnected
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Using exact sizes for initial modes
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Output eDP-1 using initial mode 1366x768 +0+0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): DPI set to (96, 96)
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Loading sub module "fb"
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "fb"
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Module "fb" already built-in
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): Backing store enabled
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): Silken mouse enabled
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (==) modeset(0): DPMS enabled
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): [DRI2] Setup complete
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): [DRI2] DRI driver: iris
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): [DRI2] VDPAU driver: va_gl
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension Generic Event Extension
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension SHAPE
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension MIT-SHM
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XInputExtension
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XTEST
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension BIG-REQUESTS
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension SYNC
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XKEYBOARD
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XC-MISC
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension SECURITY
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XFIXES
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension RENDER
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension RANDR
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension COMPOSITE
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension DAMAGE
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension MIT-SCREEN-SAVER
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension DOUBLE-BUFFER
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension RECORD
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension DPMS
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension Present
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension DRI3
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension X-Resource
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XVideo
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XVideo-MotionCompensation
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension GLX
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) AIGLX: Loaded and initialized iris
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) GLX: Initialized DRI2 GL provider for screen 0
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XFree86-VidModeExtension
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XFree86-DGA
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension XFree86-DRI
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) Initializing extension DRI2
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Damage tracking initialized
ago 06 18:34:51 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Setting screen physical size to 361 x 203
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Power Button (/dev/input/event2)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Power Button: Applying InputClass "system-keyboard"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) LoadModule: "libinput"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Module libinput: vendor="X.Org Foundation"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: compiled for 1.21.1.3, module version = 1.2.1
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: Module class: X.Org XInput Driver
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: ABI class: X.Org XInput driver, version 24.4
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'Power Button'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 30 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Power Button: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event2"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event2 - Power Button: is tagged by udev as: Keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event2 - Power Button: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event2 - Power Button: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "xkb_layout" "it"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Video Bus (/dev/input/event8)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Video Bus: Applying InputClass "evdev keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Video Bus: Applying InputClass "system-keyboard"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'Video Bus'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 33 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Video Bus: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event8"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event8 - Video Bus: is tagged by udev as: Keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event8 - Video Bus: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event8 - Video Bus: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event8"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Power Button (/dev/input/event1)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 34 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event1"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event1 - Power Button: is tagged by udev as: Keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event1 - Power Button: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event1 - Power Button: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) No input driver specified, ignoring this device.
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) This device may have been added with another device file.
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event10)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event11)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event12)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event13)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event14)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event4)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Logitech USB Optical Mouse: Applying InputClass "libinput pointer catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'Logitech USB Optical Mouse'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 35 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Logitech USB Optical Mouse: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event4"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event4 - Logitech USB Optical Mouse: is tagged by udev as: Mouse
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event4 - Logitech USB Optical Mouse: device is a pointer
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event4 - Logitech USB Optical Mouse: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:046D:C077.0001/input/input5/event4"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 9)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "AccelerationScheme" "none"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Logitech USB Optical Mouse: (accel) selected scheme none/0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse0)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event15)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event16)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HP Truevision HD: HP Truevision (/dev/input/event18)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP Truevision HD: HP Truevision: Applying InputClass "evdev keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP Truevision HD: HP Truevision: Applying InputClass "libinput keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP Truevision HD: HP Truevision: Applying InputClass "system-keyboard"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'HP Truevision HD: HP Truevision'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 36 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP Truevision HD: HP Truevision: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event18"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event18 - HP Truevision HD: HP Truevision: is tagged by udev as: Keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event18 - HP Truevision HD: HP Truevision: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event18 - HP Truevision HD: HP Truevision: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input19/event18"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "HP Truevision HD: HP Truevision" (type: KEYBOARD, id 10)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 37 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) AT Translated Set 2 keyboard: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event3"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event3 - AT Translated Set 2 keyboard: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 11)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event9)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 38 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) SynPS/2 Synaptics TouchPad: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event9"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event9 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event9 - SynPS/2 Synaptics TouchPad: device is a touchpad
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event9 - SynPS/2 Synaptics TouchPad: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input8/event9"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 12)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event7)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event17)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'HP WMI hotkeys'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event17 13:81 fd 39 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) HP WMI hotkeys: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event17"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event17 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event17 - HP WMI hotkeys: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event17 - HP WMI hotkeys: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input11/event17"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 13)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) config/udev: Adding input device Wireless hotkeys (/dev/input/event6)
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Wireless hotkeys: Applying InputClass "system-keyboard"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) Using input driver 'libinput' for 'Wireless hotkeys'
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 40 paused 0
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Wireless hotkeys: always reports core events
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "Device" "/dev/input/event6"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event6 - Wireless hotkeys: is tagged by udev as: Keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event6 - Wireless hotkeys: device is a keyboard
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) event6 - Wireless hotkeys: device removed
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input7/event6"
ago 06 18:34:52 spitocco /usr/lib/gdm-x-session[579]: (II) XINPUT: Adding extended input device "Wireless hotkeys" (type: KEYBOARD, id 14)
ago 06 18:34:56 spitocco gnome-session-binary[647]: WARNING: Could not parse desktop file manjaro-app-folder-settings.desktop or it references a not found TryExec binary
ago 06 18:34:56 spitocco gnome-keyring-daemon[656]: discover_other_daemon: 1
ago 06 18:34:56 spitocco gnome-keyring-ssh.desktop[657]: discover_other_daemon: 1
ago 06 18:34:56 spitocco gnome-keyring-pkcs11.desktop[656]: discover_other_daemon: 1
ago 06 18:34:56 spitocco gnome-keyring-secrets.desktop[658]: discover_other_daemon: 1
ago 06 18:34:56 spitocco gnome-keyring-daemon[657]: discover_other_daemon: 1
ago 06 18:34:56 spitocco gnome-keyring-daemon[658]: discover_other_daemon: 1
ago 06 18:34:57 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID vendor "SDC", prod id 19025
ago 06 18:34:57 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Printing DDC gathered Modelines:
ago 06 18:34:57 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1366x768"x0.0 76.30 1366 1430 1478 1606 768 770 775 792 -hsync -vsync (47.5 kHz eP)
ago 06 18:34:57 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1366x768"x0.0 50.80 1366 1430 1478 1606 768 770 775 792 -hsync -vsync (31.6 kHz e)
ago 06 18:34:59 spitocco gnome-shell[662]: ATK Bridge is disabled but a11y has already been enabled.
ago 06 18:35:05 spitocco geoclue[709]: Failed to connect to avahi service: Daemon not running
ago 06 18:35:09 spitocco kernel: kauditd_printk_skb: 1 callbacks suppressed
ago 06 18:35:14 spitocco gnome-shell[662]: Some code accessed the property 'SecondaryMonitorDisplay' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
ago 06 18:35:16 spitocco pulseaudio[708]: stat('/etc/pulse/default.pa.d'): File o directory non esistente
ago 06 18:35:16 spitocco gnome-shell[662]: Some code accessed the property 'ThumbnailsBox' on the module 'workspacesView'. That property was defined with 'let' or 'const' inside the module. This was previously supported, but is not correct according to the ES6 standard. Any symbols to be exported from a module must be defined with 'var'. The property access will work as previously for the time being, but please fix your code anyway.
ago 06 18:35:17 spitocco gnome-shell[662]: st_widget_get_theme_node called on the widget [0x55cde58f24b0 StBin:insensitive ("")] which is not in the stage.
ago 06 18:35:17 spitocco gnome-shell[662]: st_widget_get_theme_node called on the widget [0x55cde58e7360 Gjs_ui_panel_AppMenuButton.panel-button:insensitive ("")] which is not in the stage.
ago 06 18:35:17 spitocco gnome-shell[662]: st_widget_get_theme_node called on the widget [0x55cde58f3830 StBin:insensitive "appMenu" ("")] which is not in the stage.
ago 06 18:35:17 spitocco gnome-shell[662]: st_widget_get_theme_node called on the widget [0x55cde58f3cb0 StBoxLayout.panel-status-menu-box:insensitive ("")] which is not in the stage.
ago 06 18:35:17 spitocco gnome-shell[662]: st_widget_get_theme_node called on the widget [0x55cde58f91f0 Gjs_ui_animation_Spinner:insensitive] which is not in the stage.
ago 06 18:35:19 spitocco gnome-session-binary[647]: WARNING: Could not retrieve current screensaver active state: È stato raggiunto il timeout
ago 06 18:35:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:20 spitocco gsd-usb-protect[860]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
ago 06 18:35:20 spitocco gsd-color[840]: cd_client_find_device_by_property: assertion 'priv->proxy != NULL' failed
ago 06 18:35:20 spitocco gsd-media-keys[852]: Failed to grab accelerator for keybinding settings:rotate-video-lock
ago 06 18:35:20 spitocco gsd-media-keys[852]: Failed to grab accelerator for keybinding settings:playback-random
ago 06 18:35:20 spitocco gsd-media-keys[852]: Failed to grab accelerator for keybinding settings:hibernate
ago 06 18:35:20 spitocco gsd-media-keys[852]: Failed to grab accelerator for keybinding settings:playback-repeat
ago 06 18:35:22 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): EDID vendor "SDC", prod id 19025
ago 06 18:35:22 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Printing DDC gathered Modelines:
ago 06 18:35:22 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1366x768"x0.0 76.30 1366 1430 1478 1606 768 770 775 792 -hsync -vsync (47.5 kHz eP)
ago 06 18:35:22 spitocco /usr/lib/gdm-x-session[579]: (II) modeset(0): Modeline "1366x768"x0.0 50.80 1366 1430 1478 1606 768 770 775 792 -hsync -vsync (31.6 kHz e)
ago 06 18:35:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:42 spitocco nautilus[1143]: Could not delete '.meta.isrunning': File o directory non esistente
ago 06 18:35:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:35:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:35:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:33 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 18:36:33 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde68cab20] is on because it needs an allocation.
ago 06 18:36:33 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cea40] is on because it needs an allocation.
ago 06 18:36:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:36:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:36:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:20 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 18:37:20 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde68cb6f0] is on because it needs an allocation.
ago 06 18:37:20 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cea40] is on because it needs an allocation.
ago 06 18:37:24 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 18:37:24 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde68cbae0] is on because it needs an allocation.
ago 06 18:37:24 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cea40] is on because it needs an allocation.
ago 06 18:37:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:37:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:37:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:48 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 18:38:48 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde8851ee0] is on because it needs an allocation.
ago 06 18:38:48 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cf140] is on because it needs an allocation.
ago 06 18:38:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:38:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:38:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:39:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:39:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:40:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:40:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:41:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:41:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:42:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:42:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:43:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:43:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:44:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:44:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:45:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:45:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:14 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:14 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:19 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:19 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:24 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:24 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:29 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:29 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:34 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:34 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:39 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:39 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:44 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:44 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:49 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:49 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:54 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:54 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:46:59 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:46:59 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:04 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:04 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:09 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:09 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:47:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:47:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:48:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:48:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:49:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:49:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:50:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:50:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:51:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:51:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:52:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:52:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:53:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:53:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:54:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:54:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:55:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:55:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:56:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:56:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:57:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:57:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:58:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:58:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 18:59:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 18:59:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:00:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:00:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:01:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:01:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:02:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:02:55 spitocco gnome-shell[662]: Timelines with detached actors are not supported. <panel>[<Gjs_ui_panel_Panel>:0x55cde58e65a0] in animation of duration 250ms but not on stage.
ago 06 19:02:56 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 19:02:56 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde8851ee0] is on because it needs an allocation.
ago 06 19:02:56 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cf140] is on because it needs an allocation.
ago 06 19:02:56 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde68cb300] is on because it needs an allocation.
ago 06 19:02:56 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cedc0] is on because it needs an allocation.
ago 06 19:02:57 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 19:02:57 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde8851ee0] is on because it needs an allocation.
ago 06 19:02:57 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cf140] is on because it needs an allocation.
ago 06 19:02:57 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde68cb300] is on because it needs an allocation.
ago 06 19:02:57 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cedc0] is on because it needs an allocation.
ago 06 19:03:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:07 spitocco nautilus[2132]: Could not delete '.meta.isrunning': File o directory non esistente
ago 06 19:03:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:03:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:03:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:04:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:04:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:05:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:05:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:06:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:06:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:40 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowGroup>:0x55cde4e6e370] is on because it needs an allocation.
ago 06 19:07:40 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x55cde4a4eb30] is on because it needs an allocation.
ago 06 19:07:40 spitocco gnome-shell[662]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x55cde68cf840] is on because it needs an allocation.
ago 06 19:07:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:07:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:07:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating blue bg color. Using rgb(32,32,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating red bg color. Using rgb(32,28,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating dark fg color. Using rgb(237,237,236)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating orange bg color. Using rgb(32,32,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating gray bg color. Using rgb(32,32,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating purple fg color. Using rgb(229,203,236)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating yellow fg color. Using rgb(251,247,210)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating yellow bg color. Using rgb(32,32,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating purple bg color. Using rgb(32,32,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating red fg color. Using rgb(237,191,194)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating green bg color. Using rgb(32,32,32)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating orange fg color. Using rgb(255,229,204)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating blue fg color. Using rgb(198,220,247)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating green fg color. Using rgb(208,247,223)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating gray fg color. Using rgb(237,237,236)
ago 06 19:08:41 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating dark bg color. Using rgb(32,32,32)
ago 06 19:08:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:50 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:50 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:55 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:08:55 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating purple fg color. Using rgb(229,203,236)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating dark fg color. Using rgb(237,237,236)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating yellow bg color. Using rgb(32,32,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating orange fg color. Using rgb(255,229,204)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating gray fg color. Using rgb(237,237,236)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating purple bg color. Using rgb(32,32,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating green bg color. Using rgb(32,32,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating blue fg color. Using rgb(198,220,247)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating red fg color. Using rgb(237,191,194)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating dark bg color. Using rgb(32,32,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating gray bg color. Using rgb(32,32,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating orange bg color. Using rgb(32,32,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating yellow fg color. Using rgb(251,247,210)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating red bg color. Using rgb(32,28,32)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating green fg color. Using rgb(208,247,223)
ago 06 19:08:59 spitocco org.gnome.Nautilus[2423]: Recursion depth exceeded calculating blue bg color. Using rgb(32,32,32)
ago 06 19:09:00 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:00 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:05 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:05 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:10 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:10 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:15 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:15 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:20 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:20 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:25 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:25 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:25 spitocco gnome-shell[662]: Object .Gjs_ui_messageTray_Notification (0x55cde4cfcb60), has been already disposed — impossible to emit any signal on it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
ago 06 19:09:25 spitocco gnome-shell[662]: Object .Gjs_ui_messageTray_Notification (0x55cde4cfcb60), has been already disposed — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
ago 06 19:09:25 spitocco gnome-shell[662]: ../glib/gobject/gsignal.c:2731: instance '0x55cde7079c60' has no handler with id '91692'
ago 06 19:09:25 spitocco gnome-shell[662]: ../glib/gobject/gsignal.c:2731: instance '0x55cde7079c60' has no handler with id '91693'
ago 06 19:09:30 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:30 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:35 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:35 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:40 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:40 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
ago 06 19:09:45 spitocco touchegg.desktop[964]: Error connecting to Touchégg daemon: Could not connect: Connection refused
ago 06 19:09:45 spitocco touchegg.desktop[964]: Reconnecting in 5 seconds...
