External monitors are not working with X11 or Wayland. Have tried with optimus-manager and without. Monitors work when booted into Windows 10 partition so I know its not a hardware issue. The external monitor works during boot and in the SDDM then looses connection after login. I have tried things in similar issues, but nothing seems to work for me.
System configuration:
inxi --full --admin --verbosity=7 --filter --no-host INT ✘
Kernel: 5.15.76-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=89bc5f7f-7a9c-4d98-8330-bba6cda21814 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Precision 3571 v: N/A
Mobo: Dell model: 03KRMT v: A00 serial: <superuser required> UEFI: Dell
v: 1.8.0 date: 09/13/2022
ID-1: BAT0 charge: 91.6 Wh (94.4%) condition: 97.0/97.0 Wh (100.0%)
volts: 13.3 min: 11.4 model: SMP DELL 05RGWK9 type: Li-poly serial: <filter>
status: charging
RAM: total: 31.04 GiB used: 3.51 GiB (11.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x423
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 551 high: 1100 min/max: 400/4800:3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 461 2: 464 3: 513 4: 505
5: 426 6: 871 7: 517 8: 431 9: 551 10: 1100 11: 735 12: 546 13: 552
14: 415 15: 400 16: 462 17: 576 18: 544 19: 478 20: 475 bogomips: 112160
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 off: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A1000 Laptop GPU] vendor: Dell
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25b9 class-ID: 0302
Device-3: Microdia Integrated_Webcam_FHD type: USB driver: uvcvideo
bus-ID: 3-6:5 chip-ID: 0c45:6740 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: kwin_x11 driver: X: loaded: modesetting dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-1 note: disabled
model: ViewSonic TD2240 Series serial: <filter> built: 2013 res: N/A
dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
ratio: 16:9 modes: max: 1920x1080 min: 720x240
Monitor-2: eDP-1 pos: primary model: ChiMei InnoLux 0x1529 built: 2020
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.1 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Sound API: ALSA v: k5.15.76-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1e class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:8
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 278.53 GiB (58.4%)
model: PC SN740 NVMe WD 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 73103012 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 180 GiB size: 176.12 GiB (97.84%) used: 43.91 GiB (24.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 89bc5f7f-7a9c-4d98-8330-bba6cda21814
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 127.3 MiB (25.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: C06A-A02D
ID-3: /mnt/win raw-size: 289.39 GiB size: 289.39 GiB (100.00%)
used: 234.5 GiB (81.0%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: Local Disk uuid: A452AE3652AE0CDC
ID-1: swap-1 type: partition size: 6.52 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 6d7e5bc2-1103-4bfe-994e-94b1b31bd755
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 530 MiB fs: ntfs label: N/A
uuid: 1E4A9F3B4A9F0EA1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-4: 3-3:2 info: Microchip (formerly SMSC) USB2137 ports: 7 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2137 class-ID: 0900
Device-1: 3-3.1:4 info: Dell KB212-B Quiet Key Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 413c:2107 class-ID: 0301
Device-2: 3-3.7:6 info: ILI ILITEK Multi-Touch type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 200mA chip-ID: 222a:003d class-ID: 0300
Device-3: 3-4:3 info: MosArt Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4102 class-ID: 0301
Device-4: 3-6:5 info: Microdia Integrated_Webcam_FHD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-5: 3-8:7 info: Broadcom 58200 type: N/A driver: N/A interfaces: 1
rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 0a5c:5843 class-ID: fe00
serial: <filter>
Device-6: 3-10:8 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 363 Uptime: 22m wakeups: 22 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1342 pm: dpkg pkgs: 0 pm: pacman pkgs: 1337 libs: 368 tools: pamac
pm: flatpak pkgs: 5 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.23
Any ideas for a solution?
