Hello manjaro community,
I recently added a GeForce GT 1030 which I want to use as my sole output card for my monitors.
The GeForece RTX 3080 I already had in my system I want to use only for heavy cuda computation. Therefore, I also added the simple GT 1030 so rendering does not impede the potential performance of my 3080 at all.
I’m opening this thread now since unfortunately I was not lucky to get any output from the GT 1030 by now after fiddling with it for several hours. There seem to be no hardware issue (gpu or motherboard), as the card is detected and also working out of the box on windows - no configuration or anything needed. I can also simply switch the HDMI/DisplayPort and the output is adjusted to the card in use.
In manajro I don’t get any output from the GT 1030 at all.
What am I missing of have wrongly set in the xorg.conf
? It seems to me the card is correctly recognized by the system and there are also no errors reported by the kernel.
I also tried to adjust my bios and select slot 2 as default without any success - still no output. At least not as long as in grub/bios/manjaro.
Thank you in advance for any direct help or hint!
Cheers,
K.
In the following some system information and outputs while still using the RTX 3080 for output. Let me know if I should add more stuff.
Hardware (desktop):
- Board: ASUS B550E
- CPU: Ryzen 9 3900x
- RAM: 32GB DDR4 3600
- GPU1 (slot1): RTX 3080
- GPU2 (slot2): GT 1030
> uname -a
Linux manjaro 5.10.42-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:37:11 UTC 2021 x86_64 GNU/Linux
> lspci | grep VGA
07:00.0 VGA compatible controller: NVIDIA Corporation GA102 [GeForce RTX 3080] (rev a1)
08:00.0 VGA compatible controller: NVIDIA Corporation GP108 [GeForce GT 1030] (rev a1)
> inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=48d236cb-e71f-49d8-9634-800d6d752896 ro quiet
cryptdevice=UUID=3d14fa8a-0a8a-4493-bfdf-cbffcfe35c88:luks-3d14fa8a-0a8a-4493-bfdf-cbffcfe35c88
root=/dev/mapper/luks-3d14fa8a-0a8a-4493-bfdf-cbffcfe35c88 splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop System: ASUS product: N/A v: N/A serial: N/A
Mobo: ASUSTeK model: ROG STRIX B550-E GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 0805 date: 07/01/2020
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
status: Discharging
RAM: total: 31.3 GiB used: 1.55 GiB (4.9%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM_A1 size: No Module Installed
Device-2: DIMM_A2 size: 16 GiB speed: 3600 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Corsair part-no: CMW32GX4M2D3600C18 serial: N/A
Device-3: DIMM_B1 size: No Module Installed
Device-4: DIMM_B2 size: 16 GiB speed: 3600 MT/s type: DDR4
Info: 12-Core model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP
arch: Zen 2 family: 17 (23) model-id: 71 (113) stepping: 0
microcode: 8701021 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB bogomips: 182119
Speed: 2194 MHz min/max: 2200/3800 MHz base/boost: 3800/4650 boost: enabled
volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 2194 2: 2192 3: 2161
4: 2763 5: 2193 6: 2192 7: 2192 8: 2193 9: 2192 10: 2193 11: 2192 12: 2193
13: 2196 14: 2198 15: 2190 16: 2187 17: 2196 18: 2195 19: 2193 20: 2194
21: 2195 22: 2194 23: 2194 24: 2136
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: CardExpert driver: nvidia
v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 07:00.0 chip-ID: 10de:2206
class-ID: 0300
Device-2: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1d01 class-ID: 0300
Device-3: Sunplus Innovation FHD Camera Microphone type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1:2 chip-ID: 1bcf:28c4
class-ID: 0102 serial: <filter>
Display: server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nvidia note: n/a (using device driver) unloaded: nvidia
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31
direct render: Yes
Device-1: NVIDIA vendor: CardExpert driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fb8
class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-4: Sunplus Innovation FHD Camera Microphone type: USB
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 3-4:4 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci1 rfk-id: 2 state: down bt-service: disabled rfk-block:
hardware: no software: no address: N/A
Local Storage: total: 1.36 TiB used: 99.88 GiB (7.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 rotation: SSD serial: <filter> rev: 2B2QGXA7 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3 500G
rotation: SSD serial: <filter> rev: 20RL scheme: GPT
ID-1: / raw-size: 930.53 GiB size: 914.93 GiB (98.32%)
used: 99.85 GiB (10.9%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-3d14fa8a-0a8a-4493-bfdf-cbffcfe35c88 label: N/A
uuid: 48d236cb-e71f-49d8-9634-800d6d752896
used: 30.8 MiB (6.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 197A-A37B
ID-1: /dev/nvme0n1p3 maj-min: 259:2 size: 930.54 GiB fs: N/A label: N/A
uuid: 3d14fa8a-0a8a-4493-bfdf-cbffcfe35c88
ID-2: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sda2 maj-min: 8:2 size: 465.75 GiB fs: ntfs label: N/A
uuid: ECE21D76E21D466C
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-7.1:6 info: Cooler Master AMD SR4 lamplight Control
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 2516:0051 class-ID: 0300
Hub-3: 1-9:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-9.1:7 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-9.2:8 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-1:2 info: Sunplus Innovation FHD Camera Microphone
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
serial: <filter>
Device-2: 3-2:3 info: Razer USA DeathAdder 2013 type: Mouse,HID,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 1532:0037 class-ID: 0301
Device-3: 3-4:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.4 C mobo: 0 C gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 35%
Processes: 455 Uptime: 1m wakeups: 2 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.0 Packages: 1367 pacman: 1339
lib: 368 flatpak: 28 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.04
> cat /etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 465.31
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
Screen 1 "Screen1" RightOf "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL S2721DS"
HorizSync 115.0 - 115.0
VertRefresh 48.0 - 75.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "Monitor1"
ModelName "DELL U2414H"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 76.0
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 3080"
BusID "PCI:7:0:0"
EndSection
Section "Device"
Identifier "Device0 (1)"
Driver "nvidia"
BusID "PCI:7:0:0"
Screen 1
EndSection
Section "Device"
Identifier "Device0 (2)"
Driver "nvidia"
BusID "PCI:7:0:0"
Screen 2
EndSection
Section "Device"
Identifier "Device0 (3)"
Driver "nvidia"
BusID "PCI:7:0:0"
Screen 3
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BoardName "NVIDIA GeForce GT 1030"
BusID "PCI:8:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "AllowEmptyInitialConfiguration" "True"
Option "Coolbits" "28"
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-1"
Option "metamodes" "2560x1440_75 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen0 (1)"
Device "Device0 (1)"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen0 (2)"
Device "Device0 (2)"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen0 (3)"
Device "Device0 (3)"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Screen"
# Removed Option "metamodes" "nvidia-auto-select +0+0 {AllowGSYNC=Off}"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Option "Stereo" "0"
Option "metamodes" "1920x1080 +0+0 {rotation=left, AllowGSYNC=Off}"
Option "SLI" "Off"
Depth 24
EndSubSection
EndSection
> cat /etc/modprobe.d/blacklist.conf
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
blacklist nv
options nouveau modeset=0
> nvidia-smi
Sun Jun 27 19:09:07 2021
| NVIDIA-SMI 465.31 Driver Version: 465.31 CUDA Version: 11.3 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:07:00.0 On | N/A |
| 0% 56C P8 35W / 320W | 652MiB / 10014MiB | 14% Default |
| | | N/A |
| 1 NVIDIA GeForce ... Off | 00000000:08:00.0 Off | N/A |
| 35% 34C P8 N/A / 19W | 6MiB / 2001MiB | 0% Default |
| | | N/A |
> sudo dmesg | grep NVRM
[ 6.256393] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 465.31 Thu May 13 22:24:36 UTC 2021
