[rico@H67A-MJRO ~]$ lspci -v
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
Flags: bus master, fast devsel, latency 0
Capabilities:
Kernel driver in use: snb_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff [size=4K]
Memory behind bridge: f9000000-faffffff [size=32M]
Prefetchable memory behind bridge: 00000000d0000000-00000000efffffff [size=512M]
Capabilities:
Kernel driver in use: pcieport
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
Subsystem: Gigabyte Technology Co., Ltd Device 1c3a
Flags: bus master, fast devsel, latency 0, IRQ 38
Memory at fbfff000 (64-bit, non-prefetchable) [size=16]
Capabilities:
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 05) (prog-if 20 [EHCI])
Subsystem: Gigabyte Technology Co., Ltd Device 5006
Flags: bus master, medium devsel, latency 0, IRQ 18
Memory at fbffe000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device a102
Flags: bus master, fast devsel, latency 0, IRQ 40
Memory at fbff4000 (64-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00002000-00002fff [size=4K]
Memory behind bridge: f0000000-f01fffff [size=2M]
Prefetchable memory behind bridge: 00000000f0200000-00000000f03fffff [size=2M]
Capabilities:
00:1c.5 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 6 (rev b5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 26
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000d000-0000dfff [size=4K]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: 00000000fbd00000-00000000fbdfffff [size=1M]
Capabilities:
00:1c.6 PCI bridge: Intel Corporation 82801 PCI Bridge (rev b5) (prog-if 01 [Subtractive decode])
Flags: bus master, fast devsel, latency 0, IRQ 27
Bus: primary=00, secondary=04, subordinate=05, sec-latency=0
I/O behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
Capabilities:
00:1c.7 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 8 (rev b5) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 28
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
Memory behind bridge: fbe00000-fbefffff [size=1M]
Capabilities:
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 05) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at fbffd000 (32-bit, non-prefetchable) [size=1K]
Capabilities:
00:1f.0 ISA bridge: Intel Corporation H67 Express Chipset LPC Controller (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device 5001
Capabilities:
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port Desktop SATA AHCI Controller (rev 05) (prog-if 01 [AHCI 1.0])
Subsystem: Gigabyte Technology Co., Ltd Device b005
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 37
I/O ports at ff00 [size=8]
I/O ports at fe00 [size=4]
I/O ports at fd00 [size=8]
I/O ports at fc00 [size=4]
I/O ports at fb00 [size=32]
Memory at fbffc000 (32-bit, non-prefetchable) [size=2K]
Capabilities:
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 05)
Flags: medium devsel, IRQ 18
Memory at fbffb000 (64-bit, non-prefetchable) [size=256]
I/O ports at 0500 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3281
Flags: bus master, fast devsel, latency 0, IRQ 41
Memory at f9000000 (32-bit, non-prefetchable) [size=16M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at ee000000 (64-bit, prefetchable) [size=32M]
I/O ports at ef00 [size=128]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities:
Kernel driver in use: nouveau
Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at faffc000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
Subsystem: Gigabyte Technology Co., Ltd Onboard Ethernet
I/O ports at de00 [size=256]
Memory at fbdff000 (64-bit, prefetchable) [size=4K]
Memory at fbdf8000 (64-bit, prefetchable) [size=16K]
Capabilities:
Kernel driver in use: r8169
Kernel modules: r8169
04:00.0 PCI bridge: Integrated Technology Express, Inc. IT8892E PCIe to PCI Bridge (rev 10) (prog-if 01 [Subtractive decode])
Flags: fast devsel, IRQ 7
Bus: primary=04, secondary=05, subordinate=05, sec-latency=32
Capabilities:
06:00.0 USB controller: NEC Corporation uPD720200 USB 3.0 Host Controller (rev 04) (prog-if 30 [XHCI])
Subsystem: Gigabyte Technology Co., Ltd Device 5007
Flags: bus master, fast devsel, latency 0, IRQ 19
Memory at fbefe000 (64-bit, non-prefetchable) [size=8K]
Capabilities:
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
