Hey Everyone I am using wireless headphones and have some weird problem. While playing music or videos evertyhing seems to be ok and notifications(such as facebook, messenger) have sound but as soon as I stop playing music/video notifications sound goes away as well; I tried looking for problem solution in AlsaMixer and PulseAudio but no use;
Sometimes I hear notifications sound only if I get several messages at the same time or one after another in a very short of a time I mean milliseconds
pacmd list-sinks
2 sink(s) available.
index: 1
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 1
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 1837,50 ms
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 26
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC236 Analog"
alsa.id = "ALC236 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x4000108000 irq 150"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9dc8"
device.product.name = "Cannon Point-LP High Definition Audio Controller"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC236"
alsa.components = "HDA:10ec0236,103c8538,00100002 HDA:8086280b,80860101,00100000"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
* index: 2
driver: <module-bluez5-device.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9050
balance 0,00
volume steps: 65537
muted: no
max request: 2 KiB
max rewind: 0 KiB
monitor source: 3
sample spec: s16le 2ch 44100Hz
Stereo
used by: 0
linked by: 1
fixed latency: 39,51 ms
card: 1 <bluez_card.B2_1E_AC_44_7F_67>
module: 29
properties:
bluetooth.protocol = "a2dp_sink"
device.description = "KD"
device.string = "B2:1E:AC:44:7F:67"
device.api = "bluez"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_B2_1E_AC_44_7F_67"
bluez.class = "0x340404"
bluez.alias = "KD"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <headset-output>
