2 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9049
volume: front-left: 13107 / 20% / -41,94 dB, front-right: 13107 / 20% / -41,94 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
card: 0 <alsa_card.usb-DisplayLink_LAPDOCK_U3D2338335653-02>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "LAPDOCK"
alsa.long_card_name = "DisplayLink LAPDOCK at usb-0000:00:14.0-1.4, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:1.4:1.2"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.4/1-1.4:1.2/sound/card1"
udev.id = "usb-DisplayLink_LAPDOCK_U3D2338335653-02"
device.bus = "usb"
device.vendor.id = "17e9"
device.vendor.name = "DisplayLink"
device.product.id = "4307"
device.product.name = "LAPDOCK"
device.serial = "DisplayLink_LAPDOCK_U3D2338335653"
device.string = "front:1"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "LAPDOCK Analog Stereo"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB17e9:4307"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
ports:
analog-output: Analoge Ausgabe (priority 9900, latency offset 0 usec, available: unknown)
properties:
active port: <analog-output>
index: 1
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 35808 / 55% / -15,75 dB, front-right: 35808 / 55% / -15,75 dB
balance 0,00
volume steps: 65537
muted: no
max request: 0 KiB
max rewind: 0 KiB
monitor source: 2
sample spec: s16le 2ch 44100Hz
Stereo
used by: 0
linked by: 0
card: 1 <alsa_card.pci-0000_00_1f.3>
module: 7
properties:
device.api = "alsa"
alsa.name = "ALC236 Analog"
alsa.id = "ALC236 Analog"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xd1220000 irq 129"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "9d70"
device.product.name = "Sunrise Point-LP HD Audio"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.description = "Internes Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC236"
alsa.components = "HDA:10ec0236,17aa3845,00100002 HDA:80862809,80860101,00100000"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Lautsprecher (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Kopfhörer (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
