I’m having an ongoing issue on my wife’s computer. Two issues actually.
First I can’t make the notification sound to work, no matter what I do. I just updated to Plasma 5.20.3, hoping that would fix it, but it didn’t.
Mistake 2: I decided to uninstall the pulse and reinstall it, hoping that might do the trick. Not only that didn’t change anything, but I also lost my audio icon audio in the system setting . How ever, I can still access and open the audio from the system tray icon.
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: KDE Plasma 5.20.3 Distro: Manjaro Linux
Type: Desktop Mobo: Gigabyte model: B85M-DS3H-A v: x.x
serial: <filter> BIOS: American Megatrends v: F2 date: 08/10/2015
Info: Quad Core model: Intel Core i7-4771 bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 8192 KiB
bogomips: 55900
Speed: 954 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 954 2: 878
3: 875 4: 861 5: 876 6: 876 7: 990 8: 866
Device-1: AMD Caicos PRO [Radeon HD 7450] vendor: ASUSTeK
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,radeon
unloaded: modesetting resolution: 1: 1920x1080~60Hz 2: 1440x900~60Hz
OpenGL:
renderer: AMD CAICOS (DRM 2.50.0 / 5.8.18-1-MANJARO LLVM 11.0.0)
v: 3.3 Mesa 20.2.2 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.8.18-1-MANJARO
Any ideas appreciated.
