Immediately after the update the wifi worked, after the next reboot it didn’t work.
This is my inxi -Fxx output:
System: Host: dylan-laptop Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2 tk: Gtk 3.24.20
wm: xfwm4 dm: LightDM Distro: Manjaro Linux
Machine: Type: Laptop System: ASUSTeK product: UX331UN v: 1.0 serial: <superuser/root required>
Mobo: ASUSTeK model: UX331UN v: 1.0 serial: <superuser/root required> UEFI: American Megatrends v: UX331UN.308
date: 04/17/2019
Battery: ID-1: BAT0 charge: 39.7 Wh condition: 41.3/50.1 Wh (83%) volts: 15.9/15.9 model: ASUSTeK ASUS Battery serial: N/A
status: Charging
CPU: Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
Speed: 1100 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 1070 2: 1000 3: 1001 4: 1000 5: 1000 6: 1000 7: 1000
8: 1001
Graphics: Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:1d12
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus ID: 1-5:2 chip ID: 13d3:5a09
Display: x11 server: X.Org 1.20.8 driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0 chip ID: 8086:24fd
Drives: Local Storage: total: 476.94 GiB used: 15.27 GiB (3.2%)
ID-1: /dev/sda vendor: SanDisk model: SD8SN8U512G1002 size: 476.94 GiB speed: 6.0 Gb/s serial: 175112420043
Partition: ID-1: / size: 40.62 GiB used: 15.24 GiB (37.5%) fs: ext4 dev: /dev/sda5
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 41 C
Fan Speeds (RPM): cpu: 2200
Info: Processes: 227 Uptime: 19m Memory: 7.63 GiB used: 654.6 MiB (8.4%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1168 pacman: 1161 snap: 7 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
This is my sudo rfkill list output:
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
