I recently updated my Manjaro xfce, which previously was working perfectly. Now, I get “No Network Connection”. Also, when I try to go to the Manjaro Settings Manager to check my kernel, clicking on the icon does nothing.
I tried to follow the suggestions from previous similar questions and updated my kernel to 5.18, still no luck.
Here is the output from inxi:
Kernel: 5.18.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=af6e9556-9497-44c7-9394-c36f170b83be rw quiet
resume=UUID=901d3b19-129a-4655-8afe-88eede779744
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel, plank
wm: xfwm v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Microsoft product: Surface Pro 3 v: 1
serial: <superuser required>
Mobo: Microsoft model: Surface Pro 3 v: 1 serial: <superuser required>
UEFI: American Megatrends v: 3.11.2650 date: 04/30/2019
RAM: total: 7.67 GiB used: 1.01 GiB (13.2%)
RAM Report:
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
gen: core 4 built: 2013-15 process: Intel 22nm family: 6 model-id: 0x45 (69)
stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1539 high: 1898 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1101 2: 1896 3: 1264
4: 1898 bogomips: 19961
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Microsoft
driver: i915 v: kernel arch: Gen7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: Microsoft LifeCam Front type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 045e:07be class-ID: 0e02
Device-3: Microsoft LifeCam Rear type: USB driver: uvcvideo bus-ID: 1-8:5
chip-ID: 045e:07bf class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.48x15.00")
s-diag: 686mm (27.03")
Monitor-1: eDP-1 model: Seiko Epson 0x3542 built: 2013 res: 2160x1440
hz: 60 dpi: 216 gamma: 1.2 size: 254x169mm (10x6.65") diag: 305mm (12")
ratio: 3:2 modes: 2160x1440
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Microsoft driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.18.3-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.0 running: yes
Sound Server-5: PipeWire v: 0.3.52 running: no
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless vendor: SafeNet
driver: mwifiex_pcie v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 11ab:2b38 class-ID: 0200
WAN IP: No WAN IP found. Connected to web? SSL issues?
Local Storage: total: 245.93 GiB used: 111.6 GiB (45.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZMTE256HMHP-000MV
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1M0Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Fit
size: 7.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 33.42 GiB (70.0%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: af6e9556-9497-44c7-9394-c36f170b83be
used: 284 KiB (0.1%) fs: vfat dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: DF47-39D3
ID-3: /home raw-size: 129.95 GiB size: 126.85 GiB (97.62%)
used: 78.18 GiB (61.6%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: faf8ce46-ffc1-4d56-8c9e-e60f4548b6fd
ID-1: swap-1 type: partition size: 9.77 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: 901d3b19-129a-4655-8afe-88eede779744
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: Recovery
uuid: FC8CCEC28CCE7724
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: C6CF-8486
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 48.83 GiB fs: ntfs label: N/A
uuid: 44A2C706A2C6FC04
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-1:2 info: SanDisk Cruzer Fit type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5571 class-ID: 0806 serial: <filter>
Device-2: 1-3:3 info: Microsoft Surface Type Cover type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.1 speed: 12 Mb/s
power: 100mA chip-ID: 045e:07dc class-ID: 0303 serial: <filter>
Device-3: 1-7:4 info: Microsoft LifeCam Front type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 250mA chip-ID: 045e:07be
class-ID: 0e02
Device-4: 1-8:5 info: Microsoft LifeCam Rear type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 250mA chip-ID: 045e:07bf
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 58.0 C mobo: N/A
Processes: 176 Uptime: 1m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1649
lib: 469 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.17
That worked. Thank you very much - I thought I had checked everything, but clearly missed that.
system
Closed
17 June 2022 03:01
5
