Hey Folks,
got in trouble again with my attempt to fix wifi and network connection.
I noticed rtw8852be recommends to use rtw89.
So I tried to switch but without success. Now I have no internet-connection with this device. I am writing this from a second device, and copy stuff from there via usb-sticks.
So i have a rough idea from this issue how to fix it:
, also from this comment on AUR
Roughly I would like to
git clone https://aur.archlinux.org/rtw89-dkms-git.git
cd rtw89-dkms-git
then do the changes mentioned here (AUR rtw89-dkms-git comment)
unclesam commented on 2022-12-15 11:11 (UTC)
For those who need rtw_8852be: You need to modify dkms.conf and PKGBUILD as follows.
dkms.conf: change module names 2 and 3 to rtw_8852b and rtw_8852be (or add them as index 4 and 5). mportant: put the make command in single quotes, i.e. change make to ‘make’ Delete version specifier
PKGBUILD: change sha256sum for dkms.conf to ‘SKIP’ or insert the correct value.
Afterwards you can build and install the package. It worked (at least) for me (for kernel 5.15, 6.0 and 6.1)
You can find the code here:
dkms: dkms.conf for rtw89-dkms-git in AUR (9eg7zs71) - PasteCode.io pkgbuild: PKGBUILD for rtw89-dkms-git (1supvft9) - PasteCode.io
Hopefully, this helps with 8852be…
and then do
makepkg -sri
But, how can I manage this when being offline? Not sure about the dependencies either.
I tried going back to 8852be but currently also without success.
The second Device is running KDE Neon. Could I build there?
inxi -Nazy
vendor: Lenovo driver: N/A modules: r8169, r8168 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek vendor: Lenovo driver: N/A modules: 8852be, rtw_8852be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
chip-ID: 10ec:b852 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 2-1.3:4 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
sudo modprobe -v 8852be #This loads the module
insmod /lib/modules/5.18.19-3-MANJARO/kernel/drivers/net/wireless/8852be.ko
modprobe: ERROR: could not insert '8852be': Invalid argument
b@thinkpad ~ [1]> sudo modprobe -v rtw_8852be #This loads the module
insmod /lib/modules/5.18.19-3-MANJARO/kernel/drivers/net/wireless/realtek/rtw89/rtw89core.ko.xz
modprobe: ERROR: could not insert 'rtw_8852be': Invalid argument
inxi --admin --verbosity=7 --filter --width
Kernel: 5.18.19-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=86fb53be-c8f5-4e7e-9dcd-1d24c1ea8dc5 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 21EES00100 v: ThinkPad E15 Gen 4
Mobo: LENOVO model: 21EES00100 v: ThinkPad serial: <superuser required>
UEFI: LENOVO v: R20ET26W (1.06 ) date: 02/18/2022
ID-1: BAT0 charge: 53.7 Wh (99.6%) condition: 53.9/57.0 Wh (94.5%)
volts: 12.8 min: 11.5 model: SMP LNV-5B11C73244 type: Li-poly
serial: <filter> status: not charging cycles: 33
RAM: total: 14.47 GiB used: 2.14 GiB (14.8%)
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1395 high: 1397 min/max: 1600/4547 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1393 2: 1396
3: 1395 4: 1396 5: 1397 6: 1396 7: 1395 8: 1396 9: 1397 10: 1395 11: 1396
12: 1396 13: 1395 14: 1395 15: 1397 16: 1396 bogomips: 63916
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 36.0 C
Device-2: Sunplus Innovation FHD Camera Microphone type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.4:5 chip-ID: 1bcf:28c4
class-ID: 0102 serial: <filter>
Device-3: Acer Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 5986:2146 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x151e built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.2.4 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.46 5.18.19-3-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 1-1.4:5 chip-ID: 1bcf:28c4 pcie:
class-ID: 0102 gen: 3 speed: 8 GT/s serial: <filter> lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Sunplus Innovation FHD Camera Microphone type: USB
Sound API: ALSA v: k5.18.19-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
IF: enp4s0f3u1u3 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 484.19 GiB used: 323.76 GiB (66.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MGE1QDQ size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 1.3Q0630 temp: 19.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Sony model: Storage Media
size: 7.25 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 323.76 GiB (69.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 86fb53be-c8f5-4e7e-9dcd-1d24c1ea8dc5
label: NO_LABEL uuid: BF4B-0245
ID-1: /dev/sda1 maj-min: 8:1 size: 7.25 GiB fs: vfat label: N/A
uuid: 7C6A-B021
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-3: 1-1.2:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-1.2.2:6 info: Genesys Logic microSD Card Reader
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 98mA chip-ID: 05e3:0751 class-ID: 0806
Device-2: 1-1.2.3:8 info: Genesys Logic microSD Card Reader
Device-3: 1-1.4:5 info: Sunplus Innovation FHD Camera Microphone
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
serial: <filter>
Device-4: 1-1.5:7 info: VIA Labs USB Billboard Device type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 2109:8888 class-ID: 1100 serial: <filter>
Device-5: 1-3:3 info: Acer Integrated RGB Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-4: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 2-1.3:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 288mA
Device-2: 2-2:3 info: Sony Storage Media type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 504mA
chip-ID: 054c:09c2 class-ID: 0806 serial: <filter>
Hub-6: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: FPC Sensor Controller L:0001 FW:16.26.23.14
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 480 Mb/s
power: 100mA chip-ID: 10a5:9800 class-ID: 0000
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:4853
Hub-7: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 296 Uptime: 29m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2119
pm: pacman pkgs: 2115 libs: 422 tools: pamac pm: flatpak pkgs: 0 pm: snap
pkgs: 4 Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.24
Any help is appreciated. Just need a working connection, no matter if only wifi or only LAN. Can then wait for Kernel 6.2 for integration of the module (was mentioned in above linked github issue)
thanks.
