Hello, after updating it does not mount external USB or SSD or HDD, in gnome-disks nothing appears, even the disk that is installed on the OS does not come out. In gparted you can see the OS disk and the other connected usb or ssd, but it does not allow you to mount them. I have tested with the backup SSD OS, without updating two months ago and if everything works. Let’s see how I fix this, I have reinstalled several related packages such as expat dostools xfce4-mount ntfs.3g etc but nothing has worked
solved, thank you
