Trying to get wifi up and running and so far it does not show up in the KDE/Manjaro Network Interfaces interface.
The card is "Fenvi WiFi Card Dual Band Wireless-AC 9260 PC PCIE 2030Mbps BT5.0 802.11ac 2.4Ghz 5Ghz MU-MIMO Desktop WLAN PC BT 5.0 Network Adapter "
We tried downloading and copying the 9260 drivers from here:
www .intel.com/content/www/us/en/support/articles/000005511/network-and-i-o/wireless.html
into /lib/firmware but that didn’t work.
We also tried running the steps from the community intel page to install. This got us to where we’re at now.
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git
cd backport-iwlwifi/
sudo su
make defconfig-iwlwifi-public
sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config
make -j4
sudo make install
Now we have this - but still no wifi options:
[marie@msfdesktop iwlwifi-9260-th-b0-jf-b0-34.618819]$ sudo dmesg | grep iwlwifi
[ 3.283977] Loading modules backported from iwlwifi
[ 3.283979] iwlwifi-stack-public:master:8794:f51dd362
[ 3.720345] iwlwifi 0000:06:00.0: enabling device (0000 -> 0002)
[ 3.721932] iwlwifi 0000:06:00.0: WRT: Overriding region id 0
[ 3.721934] iwlwifi 0000:06:00.0: WRT: Overriding region id 1
[ 3.721935] iwlwifi 0000:06:00.0: WRT: Overriding region id 2
[ 3.721935] iwlwifi 0000:06:00.0: WRT: Overriding region id 3
[ 3.721936] iwlwifi 0000:06:00.0: WRT: Overriding region id 4
[ 3.721937] iwlwifi 0000:06:00.0: WRT: Overriding region id 6
[ 3.721937] iwlwifi 0000:06:00.0: WRT: Overriding region id 8
[ 3.721938] iwlwifi 0000:06:00.0: WRT: Overriding region id 9
[ 3.721939] iwlwifi 0000:06:00.0: WRT: Overriding region id 10
[ 3.721939] iwlwifi 0000:06:00.0: WRT: Overriding region id 11
[ 3.721940] iwlwifi 0000:06:00.0: WRT: Overriding region id 15
[ 3.721940] iwlwifi 0000:06:00.0: WRT: Overriding region id 16
[ 3.721941] iwlwifi 0000:06:00.0: WRT: Overriding region id 18
[ 3.721942] iwlwifi 0000:06:00.0: WRT: Overriding region id 19
[ 3.721942] iwlwifi 0000:06:00.0: WRT: Overriding region id 20
[ 3.721943] iwlwifi 0000:06:00.0: WRT: Overriding region id 21
[ 3.721945] iwlwifi 0000:06:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.721946] iwlwifi 0000:06:00.0: Found debug configuration: 0
[ 3.722144] iwlwifi 0000:06:00.0: loaded firmware version 46.8902351f.0 9260-th-b0-jf-b0-46.ucode op_mode iwlmvm
[ 4.275635] iwlwifi 0000:06:00.0: Detected Intel(R) Wireless-AC 9260, REV=0x324
[marie@msfdesktop iwlwifi-9260-th-b0-jf-b0-34.618819]$ inxi -Fazy
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=69d95ada-0473-441c-96ec-d7c0eb4cfa23 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4 serial: <filter>
UEFI: American Megatrends v: P1.10 date: 06/09/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 3072 KiB
bogomips: 86270
Speed: 2195 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2194 2: 2196 3: 2053 4: 3593 5: 2191 6: 2052 7: 2051 8: 3585 9: 2195
10: 2197 11: 2193 12: 2050
conditional, RSB filling
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Micro-Star MSI
driver: nvidia v: 455.28 alternate: nouveau,nvidia_drm bus ID: 09:00.0
chip ID: 10de:13c2
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.4x11.1")
s-diag: 727mm (28.6")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97 size: 673x284mm (26.5x11.2")
diag: 730mm (28.8")
OpenGL: renderer: GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 455.28
direct render: Yes
Device-1: NVIDIA GM204 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 10de:0fbb
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 0b:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Intel Wireless-AC 9260 driver: iwlwifi
v: iwlwifi-stack-public:master:8794:f51dd362 modules: wl bus ID: 06:00.0
chip ID: 8086:2526
vendor: ASRock driver: r8168 v: 8.048.03-NAPI modules: r8169 port: f000
bus ID: 07:00.0 chip ID: 10ec:8168
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.36 TiB used: 11.07 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-07M2NA1
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw size: 123.05 GiB size: 120.62 GiB (98.02%)
used: 11.05 GiB (9.2%) fs: ext4 dev: /dev/nvme0n1p5
System Temperatures: cpu: 45.6 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 277 Uptime: 15m Memory: 15.56 GiB used: 1.67 GiB (10.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1189 lib: 320
flatpak: 0 snap: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Appreciate any suggestions.
Edit: also:
lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
Subsystem: ASRock Incorporation Device ffff
Kernel driver in use: piix4_smbus
Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Subsystem: Samsung Electronics Co Ltd Device a801
Kernel driver in use: nvme
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43ee
Subsystem: ASMedia Technology Inc. Device 1142
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] Device 43eb
Subsystem: ASMedia Technology Inc. Device 1062
Kernel driver in use: ahci
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43e9
03:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
03:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
03:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
06:00.0 Network controller: Intel Corporation Wireless-AC 9260 (rev 29)
Subsystem: Intel Corporation Device 0014
Kernel driver in use: iwlwifi
Kernel modules: wl, iwlwifi
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
Subsystem: ASRock Incorporation Motherboard (one of many)
Kernel driver in use: r8168
Kernel modules: r8169, r8168
09:00.0 VGA compatible controller: NVIDIA Corporation GM204 [GeForce GTX 970] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3161
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
09:00.1 Audio device: NVIDIA Corporation GM204 High Definition Audio Controller (rev a1)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
0a:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
0b:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Subsystem: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
Kernel driver in use: ccp
Kernel modules: ccp
0b:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
0b:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Subsystem: ASRock Incorporation Device 1204
