Hi, after the last update the MIDI sound is gone.
Tuxguitar is playing Midi-Files, but there is no sound anymore.
Now I’ve installed Drumstick ALSA Midi Player, it starts the Midi-File, …but also no sound.
Youtube or the VLC Media Player (mp3’s) are playing well…
speaker-test -c 2 -t wav -l 10
is also working fine…
Device-1: AMD Wrestler HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:01.1
Device-2: AMD SBx00 Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:14.2
Sound API: ALSA v: k5.15.94-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: no
How can I track this down?
LF
journalctl -x -p3
Mär 01 14:34:13 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 01 14:34:18 pc nmbd[351]: [2023/03/01 14:34:18.727194, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 01 14:34:18 pc nmbd[351]: nmbd version 4.17.5 started.
Mär 01 14:34:18 pc nmbd[351]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 14:34:18 pc nmbd[351]: [2023/03/01 14:34:18.766217, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 01 14:34:18 pc nmbd[351]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 01 14:34:18 pc nmbd[351]: [2023/03/01 14:34:18.771405, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 01 14:34:18 pc nmbd[351]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 01 14:35:11 pc lightdm[649]: gkr-pam: unable to locate daemon control file
Mär 01 14:35:13 pc ntpd[360]: bind(23) AF_INET6 -%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 14:35:13 pc ntpd[360]: unable to create socket on wlp3s0 (4) for -%2#123
Mär 01 14:35:17 pc bluetoothd[770]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 01 14:35:17 pc bluetoothd[770]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 01 14:35:17 pc bluetoothd[770]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 01 14:35:18 pc smbd[782]: [2023/03/01 14:35:18.186203, 0] ../../source3/smbd/server.c:1741(main)
Mär 01 14:35:18 pc smbd[782]: smbd version 4.17.5 started.
Mär 01 14:35:18 pc smbd[782]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 14:35:50 pc nmbd[351]: [2023/03/01 14:35:50.390788, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 01 14:35:50 pc nmbd[351]: *****
Mär 01 14:35:50 pc nmbd[351]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.17
Mär 01 15:05:04 pc systemd-coredump[1776]: Failed to connect to coredump service: Connection refused
Mär 01 15:05:05 pc nmbd[351]: [2023/03/01 15:05:05.878901, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Mär 01 15:05:05 pc nmbd[351]: Got SIGTERM: going down...
Mär 01 15:05:05 pc pulseaudio[758]: Lost I/O connection in module "module-gsettings"
-- Boot 8631976809004bd19b5afa7db4b1c945 --
Mär 01 16:08:06 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 01 16:08:11 pc nmbd[341]: [2023/03/01 16:08:11.287719, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 01 16:08:11 pc nmbd[341]: nmbd version 4.17.5 started.
Mär 01 16:08:11 pc nmbd[341]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 16:08:11 pc nmbd[341]: [2023/03/01 16:08:11.306558, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 01 16:08:11 pc nmbd[341]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 01 16:08:11 pc nmbd[341]: [2023/03/01 16:08:11.308595, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 01 16:08:11 pc nmbd[341]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 01 16:08:28 pc lightdm[651]: gkr-pam: unable to locate daemon control file
Mär 01 16:08:30 pc ntpd[347]: bind(23) AF_INET6 -:d29%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 16:08:30 pc ntpd[347]: unable to create socket on wlp3s0 (4) for -:d29%2#123
Mär 01 16:08:32 pc smbd[752]: [2023/03/01 16:08:32.083270, 0] ../../source3/smbd/server.c:1741(main)
Mär 01 16:08:32 pc smbd[752]: smbd version 4.17.5 started.
Mär 01 16:08:32 pc smbd[752]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 16:08:34 pc bluetoothd[901]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 01 16:08:34 pc bluetoothd[901]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 01 16:08:34 pc bluetoothd[901]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 01 16:09:04 pc nmbd[341]: [2023/03/01 16:09:04.790696, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 01 16:09:04 pc nmbd[341]: *****
Mär 01 16:09:04 pc nmbd[341]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 172.18.10.228
Mär 01 16:10:01 pc kernel: usb 3-1: device descriptor read/64, error -62
Mär 01 16:10:02 pc kernel: usb 3-1: device descriptor read/64, error -62
Mär 01 16:10:03 pc kernel: usb 3-1: device not accepting address 5, error -62
Mär 01 16:10:03 pc kernel: usb 3-1: device not accepting address 6, error -62
Mär 01 16:10:03 pc kernel: usb usb3-port1: unable to enumerate USB device
Mär 01 16:10:31 pc colord-sane[1443]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Mär 01 16:10:33 pc colord-sane[1468]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Mär 01 16:10:36 pc colord-sane[1510]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Mär 01 16:14:09 pc systemd-coredump[1757]: Failed to connect to coredump service: Connection refused
Mär 01 16:14:11 pc nmbd[341]: [2023/03/01 16:14:11.448356, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Mär 01 16:14:11 pc nmbd[341]: Got SIGTERM: going down...
-- Boot dfb78be448bf4842843c3bc246afc790 --
Mär 01 19:51:50 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 01 19:51:54 pc nmbd[339]: [2023/03/01 19:51:54.795561, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 01 19:51:54 pc nmbd[339]: nmbd version 4.17.5 started.
Mär 01 19:51:54 pc nmbd[339]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 19:51:54 pc nmbd[339]: [2023/03/01 19:51:54.826332, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 01 19:51:54 pc nmbd[339]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 01 19:51:54 pc nmbd[339]: [2023/03/01 19:51:54.827704, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 01 19:51:54 pc nmbd[339]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 01 19:53:24 pc systemd[1]: Failed to start Samba NMB Daemon.
░░ Subject: A start job for unit nmb.service has failed
░░ Defined-By: systemd
░░ A start job for unit nmb.service has finished with a failure.
░░ The job identifier is 107 and the job result is failed.
Mär 01 19:53:24 pc smbd[649]: [2023/03/01 19:53:24.841725, 0] ../../source3/smbd/server.c:1741(main)
Mär 01 19:53:24 pc smbd[649]: smbd version 4.17.5 started.
Mär 01 19:53:24 pc smbd[649]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 20:35:12 pc lightdm[642]: gkr-pam: unable to locate daemon control file
Mär 01 20:35:16 pc ntpd[350]: bind(23) AF_INET6 -:d29%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 20:35:16 pc ntpd[350]: unable to create socket on wlp3s0 (4) for -:d29%2#123
Mär 01 20:35:18 pc bluetoothd[934]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 01 20:35:18 pc bluetoothd[934]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 01 20:35:18 pc bluetoothd[934]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 01 20:41:51 pc systemd-coredump[1848]: Failed to connect to coredump service: Connection refused
-- Boot 3fa1ba0bda7c4e03a88397cb415b932a --
Mär 01 21:40:00 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 01 21:40:04 pc nmbd[346]: [2023/03/01 21:40:04.860215, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 01 21:40:04 pc nmbd[346]: nmbd version 4.17.5 started.
Mär 01 21:40:04 pc nmbd[346]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 21:40:04 pc nmbd[346]: [2023/03/01 21:40:04.888956, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 01 21:40:04 pc nmbd[346]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 01 21:40:04 pc nmbd[346]: [2023/03/01 21:40:04.890698, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 01 21:40:04 pc nmbd[346]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 01 21:40:32 pc lightdm[643]: gkr-pam: unable to locate daemon control file
Mär 01 21:40:34 pc ntpd[353]: bind(23) AF_INET6 -:d29%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 21:40:34 pc ntpd[353]: unable to create socket on wlp3s0 (4) for -:d29%2#123
Mär 01 21:40:37 pc bluetoothd[768]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 01 21:40:37 pc bluetoothd[768]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 01 21:40:37 pc bluetoothd[768]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 01 21:41:22 pc ntpd[353]: bind(23) AF_INET6 -:d29%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 21:41:22 pc ntpd[353]: unable to create socket on wlp3s0 (6) for -:d29%2#123
Mär 01 21:41:30 pc smbd[1215]: [2023/03/01 21:41:30.530587, 0] ../../source3/smbd/server.c:1741(main)
Mär 01 21:41:30 pc smbd[1215]: smbd version 4.17.5 started.
Mär 01 21:41:30 pc smbd[1215]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 01 21:42:03 pc nmbd[346]: [2023/03/01 21:42:03.142460, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 01 21:42:03 pc nmbd[346]: *****
Mär 01 21:42:03 pc nmbd[346]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 172.18.10.228
Mär 01 21:43:43 pc nmbd[346]: [2023/03/01 21:43:43.231997, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mär 01 21:43:43 pc nmbd[346]: reload_interfaces: No subnets to listen to. Waiting..
Mär 01 21:45:06 pc ntpd[353]: bind(23) AF_INET6 -:d29%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 21:45:06 pc ntpd[353]: unable to create socket on wlp3s0 (11) for -:d29%2#123
Mär 01 21:45:41 pc ntpd[353]: bind(25) AF_INET6 -%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 21:45:41 pc ntpd[353]: unable to create socket on wlp3s0 (14) for -%2#123
Mär 01 21:45:44 pc nmbd[346]: [2023/03/01 21:45:44.918009, 0] ../../source3/nmbd/nmbd.c:359(reload_interfaces)
Mär 01 21:45:44 pc nmbd[346]: reload_interfaces: No subnets to listen to. Waiting..
Mär 01 21:46:35 pc ntpd[353]: bind(25) AF_INET6 -%2#123 flags 0x11 failed: Cannot assign requested address
Mär 01 21:46:35 pc ntpd[353]: unable to create socket on wlp3s0 (18) for -%2#123
Mär 01 21:47:06 pc nmbd[346]: [2023/03/01 21:47:06.977076, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 01 21:47:06 pc nmbd[346]: *****
Mär 01 21:47:06 pc nmbd[346]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.100
Mär 01 22:21:44 pc systemd-coredump[2712]: Failed to connect to coredump service: Connection refused
Mär 01 22:21:45 pc nmbd[346]: [2023/03/01 22:21:45.823890, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Mär 01 22:21:45 pc nmbd[346]: Got SIGTERM: going down...
-- Boot 8ea6162aa46547b79dab129e2a338a91 --
Mär 02 11:10:40 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 02 11:10:44 pc nmbd[350]: [2023/03/02 11:10:44.391186, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 02 11:10:44 pc nmbd[350]: nmbd version 4.17.5 started.
Mär 02 11:10:44 pc nmbd[350]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 02 11:10:44 pc nmbd[350]: [2023/03/02 11:10:44.447406, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 02 11:10:44 pc nmbd[350]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 02 11:10:44 pc nmbd[350]: [2023/03/02 11:10:44.449167, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 02 11:10:44 pc nmbd[350]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 02 11:10:54 pc lightdm[648]: gkr-pam: unable to locate daemon control file
Mär 02 11:10:56 pc ntpd[357]: bind(23) AF_INET6 -%2#123 flags 0x11 failed: Cannot assign requested address
Mär 02 11:10:56 pc ntpd[357]: unable to create socket on wlp3s0 (4) for -%2#123
Mär 02 11:10:59 pc smbd[765]: [2023/03/02 11:10:59.544768, 0] ../../source3/smbd/server.c:1741(main)
Mär 02 11:10:59 pc smbd[765]: smbd version 4.17.5 started.
Mär 02 11:10:59 pc smbd[765]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 02 11:11:00 pc bluetoothd[817]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 02 11:11:00 pc bluetoothd[817]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 02 11:11:00 pc bluetoothd[817]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 02 11:11:32 pc nmbd[350]: [2023/03/02 11:11:32.261548, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 02 11:11:32 pc nmbd[350]: *****
Mär 02 11:11:32 pc nmbd[350]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.17
Mär 02 11:28:53 pc systemd-coredump[1736]: Failed to connect to coredump service: Connection refused
Mär 02 11:28:54 pc nmbd[350]: [2023/03/02 11:28:54.587276, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Mär 02 11:28:54 pc nmbd[350]: Got SIGTERM: going down...
Mär 02 11:28:54 pc pulseaudio[757]: Lost I/O connection in module "module-gsettings"
-- Boot 40837546fbe1446f94c3b2ae64837143 --
Mär 02 17:37:06 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 02 17:37:11 pc nmbd[350]: [2023/03/02 17:37:11.254749, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 02 17:37:11 pc nmbd[350]: nmbd version 4.17.5 started.
Mär 02 17:37:11 pc nmbd[350]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 02 17:37:11 pc nmbd[350]: [2023/03/02 17:37:11.281197, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 02 17:37:11 pc nmbd[350]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 02 17:37:11 pc nmbd[350]: [2023/03/02 17:37:11.281858, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 02 17:37:11 pc nmbd[350]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 02 17:37:21 pc lightdm[640]: gkr-pam: unable to locate daemon control file
Mär 02 17:37:23 pc ntpd[354]: bind(23) AF_INET6 -:d29%2#123 flags 0x11 failed: Cannot assign requested address
Mär 02 17:37:23 pc ntpd[354]: unable to create socket on wlp3s0 (4) for -:d29%2#123
Mär 02 17:37:25 pc smbd[747]: [2023/03/02 17:37:25.068362, 0] ../../source3/smbd/server.c:1741(main)
Mär 02 17:37:25 pc smbd[747]: smbd version 4.17.5 started.
Mär 02 17:37:25 pc smbd[747]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 02 17:37:27 pc bluetoothd[895]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 02 17:37:27 pc bluetoothd[895]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 02 17:37:27 pc bluetoothd[895]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 02 17:37:57 pc nmbd[350]: [2023/03/02 17:37:57.807589, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 02 17:37:57 pc nmbd[350]: *****
Mär 02 17:37:57 pc nmbd[350]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 172.18.10.228
Mär 02 17:55:26 pc nmbd[350]: [2023/03/02 17:55:26.695392, 0] ../../source3/nmbd/nmbd.c:59(terminate)
Mär 02 17:55:26 pc nmbd[350]: Got SIGTERM: going down...
Mär 02 17:55:26 pc nmbd[350]: [2023/03/02 17:55:26.695683, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Mär 02 17:55:26 pc nmbd[350]: Packet send failed to -(138) ERRNO=Das Netzwerk ist nicht erreichbar
Mär 02 17:55:26 pc nmbd[350]: [2023/03/02 17:55:26.710062, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
-- Boot b04b9d16eb514223b55a4fe0bb92078f --
Mär 03 09:22:49 pc kernel: __common_interrupt: 1.55 No irq handler for vector
Mär 03 09:22:54 pc nmbd[344]: [2023/03/03 09:22:54.215231, 0] ../../source3/nmbd/nmbd.c:901(main)
Mär 03 09:22:54 pc nmbd[344]: nmbd version 4.17.5 started.
Mär 03 09:22:54 pc nmbd[344]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 03 09:22:54 pc nmbd[344]: [2023/03/03 09:22:54.229167, 0] ../../lib/util/become_daemon.c:150(daemon_status)
Mär 03 09:22:54 pc nmbd[344]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
Mär 03 09:22:54 pc nmbd[344]: [2023/03/03 09:22:54.229783, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
Mär 03 09:22:54 pc nmbd[344]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
Mär 03 09:23:06 pc lightdm[651]: gkr-pam: unable to locate daemon control file
Mär 03 09:23:09 pc smbd[756]: [2023/03/03 09:23:09.911424, 0] ../../source3/smbd/server.c:1741(main)
Mär 03 09:23:09 pc smbd[756]: smbd version 4.17.5 started.
Mär 03 09:23:09 pc smbd[756]: Copyright Andrew Tridgell and the Samba Team 1992-2022
Mär 03 09:23:11 pc ntpd[347]: bind(24) AF_INET6 -2b61:27f1#123 flags 0x11 failed: Cannot assign requested address
Mär 03 09:23:11 pc ntpd[347]: unable to create socket on wlp3s0 (5) for -2b61:27f1#123
Mär 03 09:23:12 pc bluetoothd[903]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mär 03 09:23:12 pc bluetoothd[903]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mär 03 09:23:12 pc bluetoothd[903]: src/plugin.c:plugin_init() Failed to init bap plugin
Mär 03 09:23:42 pc nmbd[344]: [2023/03/03 09:23:42.610689, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
Mär 03 09:23:42 pc nmbd[344]: *****
Mär 03 09:23:42 pc nmbd[344]: Samba name server PC is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.17
