Hello, I was trying to fix my monitor dpi and I believe I made an error in my config file in /etc/X11/xorg.conf.d/90-monitor.conf Now when I boot I am stuck on the following error:
To set it for one time, press e when the grub entry for Manjaro is selected. Then literally delete the word quiet from the line starting with linux.
To make it permanent, edit /etc/default/grub, and delete the word quiet from GRUB_CMDLINE_LINUX_DEFAULT, save the changes, and then run sudo update-grub
ACPI error: needed type [reference], found [integer] 00000000a618a808 (20210730/exresop-66)
ACPI error: AE_AML_OPERAND_TYPE, while resolving operands for [store] (20210730/dswexec-431)
ACPI error: aborting method \_PR.CPU0._PCD due to previous error AE_AML_OPERAND_TYPE (20210730/psparse=529)
I just thought of how you can edit /etc/X11/xorg.conf.d/90-monitor.conf. Press e on the Manjaro entry in Grub. Type single at the end of the line starting with linux. Press Ctrl+x to continue. This should get you to a TTY prompt, from where you should run
nano /etc/X11/xorg.conf.d/90-monitor.conf
Undo whatever changes you made to the file. Then press Ctrl+x. It will ask you to save. Press y. Then press enter without changing the filename. Once you are back to the TTY prompt, type systemctl reboot. See if it reboots normally.
