Hello,
i’am trying to get remote access to my manjaro host-system.
I used the following steps to configure vnc headless. (5 Running Xvnc with XDMCP for on demand sessions)
But after i used systemctl enable xvnc.sockets at next reboot i don’t get a Login-screen on tty1. (only blinking cursor) tty2 without graphical interface works fine and after i connect with vnc to the system tty1 with login-screen works fine as well.
Alternatively i tried to use xrdp but there i got black screen after login with rdp session.
I checked the logs and i searched so much, but i can’t find the issue.
I hope anyone can help me please let me know which logs i should upload.
I’ve seen that any vnc service already use port 5901 and i don’t know which vnc service is it. So maybe there is a dependency to my described issue?
[ 3.981] (II) Initializing extension DAMAGE
[ 3.981] (II) Initializing extension MIT-SCREEN-SAVER
[ 3.981] (II) Initializing extension DOUBLE-BUFFER
[ 3.981] (II) Initializing extension RECORD
[ 3.981] (II) Initializing extension DPMS
[ 3.981] (II) Initializing extension Present
[ 3.981] (II) Initializing extension DRI3
[ 3.981] (II) Initializing extension X-Resource
[ 3.981] (II) Initializing extension XVideo
[ 3.981] (II) Initializing extension XVideo-MotionCompensation
[ 3.981] (II) Initializing extension GLX
[ 3.981] (II) Indirect GLX disabled.
[ 3.981] (II) GLX: Another vendor is already registered for screen 0
[ 3.981] (II) Initializing extension XFree86-VidModeExtension
[ 3.981] (II) Initializing extension XFree86-DGA
[ 3.981] (II) Initializing extension XFree86-DRI
[ 3.981] (II) Initializing extension DRI2
[ 3.981] (II) Initializing extension VNC
[ 3.982] (EE)
Fatal server error:
[ 3.982] (EE) vncExtInit: failed to bind socket: Address already in use (98)
[ 3.982] (EE)
[ 3.982] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 3.982] (EE)
[ 4.100] (EE) Server terminated with error (1). Closing log file.
It looks like any vnc service use Port 5901 already but i don’t know how i can disable this at reboot.
I can’t find any corresponding Services with systemctl.
