I have installed 3 kernel in Manjaro KDE. , still during boot up, there is no selection of kernel.
$ mhwd-kernel -li Currently running: 5.12.9-1-MANJARO (linux512) The following kernels are installed in your system: * linux510 * linux512 * linux54
What is your GRUB_TIMEOUT_STYLE option?
Look under the file,
/etc/default/grub
By default, it boots straight into the latest kernel, unless you interrupt the process with LEFT-SHIFT quickly enough. Otherwise, you need to change the value of the following options and sudo update-grub once again:
sudo update-grub
GRUB_TIMEOUT_STYLE GRUB_TIMEOUT
An example might look like:
GRUB_TIMEOUT_STYLE=menu GRUB_TIMEOUT=10
Got it done. Thanks
