You may want to run sudo mkinitcpio -P and see the output
I’m not 100% sure but this is “normal” when, at the beginning of the update, the kernel and initrd is removed, but then, the update doesn’t finish and no kernel or initrd is put back.
This is also normal when this script is run in chroot
(the text / error message means exactly that)
Do not worry - grub is not your problem.
You need to install a kernel.
mhwd-kernel -l
only lists what is available
to install, use
mhwd-kernel -i linuxXYZ
Linux manjaro 6.10.13-3-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Oct 8 03:24:49 UTC 2024 x86_64 GNU/Linux
core is up to date
extra is up to date
community is up to date
multilib is up to date
error: no targets specified (use -h for help)
What is this supposed to be a reply to?
Install a kernel.
Sorry, yes:
mhwd-kernel -i linux66
Please read carefully and install 6.12 or 6.1 and not 6.6 !
and please provide command + full output ! (not only selected lines)
no, that is not the output when you issue
How about some hardware info to begin with?
inxi -zv8
since the question arose whether you have enough free disk space
core is up to date
extra is up to date
Kernel 6.10.13-3-MANJARO arch x86_64 bits 64 compiler gcc v 14.2.1 clocksource tsc
avail hpet,acpi_pm parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_24 quiet systemd.show_status=1 splash
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Console N/A Distro Manjaro base Arch Linux
Type Laptop System System76 product Serval WS v serw9 serial N/A Chassis type 10 serial N/A
Mobo System76 model Serval WS v serw9 serial N/A uuid 335bfa80-0e00-0000-0000-000000000000
UEFI American Megatrends v 1.05.10RSA1-1 date 07/11/2016
ID-1 BAT0 charge 73.9 Wh (100.0%) condition 73.9/79.9 Wh (92.5%) volts 17.1 min 14.8
model Notebook BAT type Li-ion serial <filter> status full
Device-1 hidpp_battery_0 model Logitech Wireless Mouse M510 serial <filter> charge Normal
status discharging
System RAM total 16 GiB available 15.58 GiB used 4.2 GiB (27.0%)
Array-1 capacity 64 GiB slots 4 modules 2 EC None max-module-size 16 GiB note est.
Device-1 ChannelA-DIMM0 type no module installed
Device-2 ChannelA-DIMM1 type DDR4 detail synchronous size 8 GiB speed 2133 MT/s volts curr 1.2
width (bits) data 64 total 64 manufacturer Samsung part-no M471A1G43DB0-CPB serial <filter>
Device-3 ChannelB-DIMM0 type no module installed
Device-4 ChannelB-DIMM1 type DDR4 detail synchronous size 8 GiB speed 2133 MT/s volts curr 1.2
Slot 3 type PCIe status in use info J_WLAN1 length short volts 3.3 bus-ID 08:01.0
Info model Intel Core i7-6700K socket U3E1 bits 64 type MT MCP arch Skylake-S gen core 6 level v3
note check built 2015 process Intel 14nm family 6 model-id 0x5E (94) stepping 3 microcode 0xF0
Topology cpus 1x dies 1 clusters 4 cores 4 threads 8 tpc 2 smt enabled cache L1 256 KiB
desc d-4x32 KiB; i-4x32 KiB L2 1024 KiB desc 4x256 KiB L3 8 MiB desc 1x8 MiB
Speed (MHz) avg 800 min/max 800/4200 base/boost 4000/8300 scaling driver intel_pstate
governor powersave volts 1.3 V ext-clock 100 MHz cores 1 800 2 800 3 800 4 800 5 800 6 800 7 800
8 800 bogomips 64026
Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Vulnerabilities
Type gather_data_sampling status Vulnerable: No microcode
Type itlb_multihit status KVM: VMX disabled
Type l1tf mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type mds mitigation Clear CPU buffers; SMT vulnerable
Type meltdown mitigation PTI
Type mmio_stale_data mitigation Clear CPU buffers; SMT vulnerable
Type reg_file_data_sampling status Not affected
Type retbleed mitigation IBRS
Type spec_rstack_overflow status Not affected
Type spec_store_bypass mitigation Speculative Store Bypass disabled via prctl
Type spectre_v1 mitigation usercopy/swapgs barriers and __user pointer sanitization
Type spectre_v2 mitigation IBRS; IBPB: conditional; STIBP: conditional; RSB filling;
Type srbds mitigation Microcode
Type tsx_async_abort mitigation TSX disabled
Device-1 NVIDIA GM204M [GeForce GTX 970M] vendor CLEVO/KAPOK driver nvidia v 550.0
non-free 550.xx+ status current (as of 2024-09; EOL~2026--xx) arch Maxwell code GMxxx
process TSMC 28nm built 2014-2019 pcie gen 3 speed 8 GT/s lanes 16 bus-ID 01:00.0
chip-ID 10de:1618 class-ID 0300
Device-2 Bison BisonCam NB Pro driver uvcvideo type USB rev 2.0 speed 480 Mb/s lanes 1 mode 2.0
bus-ID 1-10:4 chip-ID 5986:066d class-ID 0e02 serial <filter>
Display server X.org v 1.21.1.14 with Xwayland v 24.1.4 driver X loaded N/A failed nvidia
gpu nvidia tty 80x40
Monitor-1 Unknown-1 size-res N/A in console modes 1024x768
API EGL v 1.5 platforms device 1 drv swrast gbm drv kms_swrast surfaceless drv swrast
inactive wayland,x11,device-0
API OpenGL v 4.5 vendor mesa v 24.2.7-arch1.1 note console (EGL sourced) renderer llvmpipe
(LLVM 18.1.8 256 bits)
API Vulkan Message No Vulkan data available.
Device-1 Intel 100 Series/C230 Series Family HD Audio vendor CLEVO/KAPOK driver snd_hda_intel
v kernel bus-ID 00:1f.3 chip-ID 8086:a170 class-ID 0403
Device-2 NVIDIA GM204 High Definition Audio vendor CLEVO/KAPOK driver snd_hda_intel v kernel
pcie gen 3 speed 8 GT/s lanes 16 bus-ID 01:00.1 chip-ID 10de:0fbb class-ID 0403
API ALSA v k6.10.13-3-MANJARO status kernel-api with aoss type oss-emulator
tools alsactl,alsamixer,amixer
Server-1 JACK v 1.9.22 status off tools N/A
Server-2 PipeWire v 1.2.7 status off with wireplumber status off tools pw-cli,wpctl
Server-3 PulseAudio v 17.0 status off with pulseaudio-alsa type plugin tools pacat,pactl
Device-1 Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor CLEVO/KAPOK driver alx v kernel
pcie gen 1 speed 2.5 GT/s lanes 1 port d000 bus-ID 3b:00.0 chip-ID 1969:e0a1 class-ID 0200
IF enp59s0 state up speed 100 Mbps duplex full mac <filter>
IP v4 <filter> type dynamic noprefixroute scope global broadcast <filter>
IP v6 <filter> type noprefixroute scope link
Device-2 Intel Wireless 3165 driver iwlwifi v kernel pcie gen 1 speed 2.5 GT/s lanes 1
bus-ID 3d:00.0 chip-ID 8086:3165 class-ID 0280
IF wlp61s0 state down mac <filter>
Info services No services found.
WAN IP <filter>
Device-1 Intel Bluetooth wireless interface driver btusb v 0.8 type USB rev 2.0 speed Mb/s
lanes 1 mode 1.1 bus-ID 1-11:5 chip-ID 8087:0a2a class-ID e001
Report rfkill ID hci0 rfk-id 0 state down bt-service N/A rfk-block hardware no software no
address see --recommends
Message No logical block device data found.
Message No RAID data found.
Local Storage total 933.44 GiB used 90.42 GiB (9.7%)
ID-1 /dev/sda maj-min 8:0 vendor Western Digital model WDS500G2B0B-00YS70 family WD Blue / Red
/ Green SSDs size 465.76 GiB block-size physical 5 B logical 5 B sata 3.3 speed 6.0 Gb/s
tech SSD serial <filter> fw-rev 20WD temp 38 C
SMART yes state enabled health PASSED on 239d 0h cycles 1046
ID-2 /dev/sdb maj-min 8:16 vendor Western Digital model WD Blue SA510 M.2 2280 500GB
size 465.76 GiB block-size physical 5 B logical 5 B type USB rev 3.1 spd 5 Gb/s lanes 1
mode 3.2 gen-1x1 sata 3.2 speed 6.0 Gb/s tech SSD serial <filter> fw-rev 52008100 temp 29 C
SMART yes state enabled health PASSED cycles 44 read 33 KiB written 11 KiB
ID-3 /dev/sdc maj-min 8:32 vendor SanDisk model U3 Cruzer Micro size 1.91 GiB block-size
physical 5 B logical 5 B type USB rev 2.0 spd 480 Mb/s lanes 1 mode 2.0 tech N/A
serial <filter> fw-rev 3.27
SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
Message No optical or floppy data found.
ID-1 / raw-size 456.66 GiB size 448.43 GiB (98.20%) used 90.42 GiB (20.2%) fs ext4
block-size 4096 B dev /dev/sda2 maj-min 8:2 label N/A uuid a9d356d9-c6fd-490a-a0ec-715fb2226731
ID-2 /boot/efi raw-size 300 MiB size 299.4 MiB (99.80%) used 3 KiB (0.1%) fs vfat
block-size 5 B dev /dev/sda1 maj-min 8:1 label N/A uuid FB45-2C31
Alert No swap data was found.
ID-1 /dev/sda3 maj-min 8:3 size 8.8 GiB fs swap label swap
uuid c486fea8-8963-4f54-8ecc-1a5c6cbf64f8
ID-2 /dev/sdb1 maj-min 8:17 size 3.87 GiB fs N/A label N/A uuid N/A
ID-3 /dev/sdb2 maj-min 8:18 size 4 MiB fs N/A label MISO_EFI uuid 8BF0-EDB3
ID-4 /dev/sdc1 maj-min 8:33 size 1.91 GiB fs N/A label N/A uuid 56AE-017D
Hub-1 1-0:1 info hi-speed hub with single TT ports 16 rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1
mode 2.0 chip-ID 1d6b:0002 class-ID 0900
Device-1 1-1:7 info SanDisk Cruzer Micro U3 type mass storage driver usb-storage interfaces 1
rev 2.0 speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 power 200mA chip-ID 0781:5406 class-ID 0806
serial <filter>
Device-2 1-2:2 info LighTuning ES603 Swipe Fingerprint Sensor type <vendor specific> driver N/A
interfaces 1 rev 1.1 speed Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 100mA chip-ID 1c7a:0603
class-ID 0000
Device-3 1-6:3 info Logitech Unifying Receiver type keyboard,mouse,HID
driver logitech-djreceiver,usbhid interfaces 3 rev 2.0 speed Mb/s (1.4 MiB/s) lanes 1 mode 1.1
power 98mA chip-ID 046d:c52b class-ID 0300
Device-4 1-10:4 info Bison BisonCam NB Pro type video driver uvcvideo interfaces 2 rev 2.0
speed 480 Mb/s (57.2 MiB/s) lanes 1 mode 2.0 power 500mA chip-ID 5986:066d class-ID 0e02
serial <filter>
Device-5 1-11:5 info Intel Bluetooth wireless interface type bluetooth driver btusb
interfaces 2 rev 2.0 speed Mb/s (1.4 MiB/s) lanes 1 mode 1.1 power 100mA chip-ID 8087:0a2a
class-ID e001
Hub-2 2-0:1 info super-speed hub ports 10 rev 3.0 speed 5 Gb/s (596.0 MiB/s) lanes 1
mode 3.2 gen-1x1 chip-ID 1d6b:0003 class-ID 0900
Device-1 2-5:2 info ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153 3Gb/s ASM1153E bridge
type mass storage driver uas interfaces 1 rev 3.1 speed 5 Gb/s (596.0 MiB/s) lanes 1
mode 3.2 gen-1x1 chip-ID 174c:55aa class-ID 0806 serial <filter>
System Temperatures cpu 39.0 C mobo N/A
Fan Speeds (rpm) N/A
Packages pm pacman pkgs 1785 libs 498 tools pamac,yay pm flatpak pkgs 0
Active pacman repo servers in /etc/pacman.d/mirrorlist
1 https: //mirror.telepoint.bg/manjaro/stable/$repo/$arch
2 http: //ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
3 https: //mirrors.dotsrc.org/manjaro/stable/$repo/$arch
4 https: //mirror.bouwhuis.network/manjaro/stable/$repo/$arch
5 https: //bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
Message No process data available.
Processes 0 Power uptime 2h 2m states freeze,mem,disk suspend deep avail s2idle wakeups 0
hibernate platform avail shutdown, reboot, suspend, test_resume image 6.19 GiB Init systemd v 256
default graphical tool systemctl
Compilers clang 18.1.8 gcc 14.2.1 alt 13 Client systemd inxi 3.3.36
Please include the command, so we can tell what went wrong.
Anyway try running sudo mkinitcpio -P
the entire output:
mhwd-kernel -i linux611
core is up to date
extra is up to date
[manjaro /]#
How do I get the forum to stop cutting off the first part of my pasted text?
I guess this was the culprit, 6.10 has been removed from repositories after being quite a while EOL. An EOL kernel must be replaces with another one BEFORE it got removed. Another reason to follow Announcements before updating.
sudo mkinitcpio -P
sudo: unable to find terminal name for device 136, 3
==> Building image from preset: /etc/mkinitcpio.d/linux611.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.11-x86_64 -g /boot/initramfs-6.11-x86_64.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-6.11-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux611.preset: 'fallback'
-> -k /boot/vmlinuz-6.11-x86_64 -g /boot/initramfs-6.11-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-6.6-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'fallback'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64-fallback.img -S autodetect
Removing dead kernels is what started this.
I attempted to remove the no longer supported.
And, attempted to go from 11 to 12. But it failed because of nvida drivers.
After t hat no boot.
You need to take care on EOL kernels before updating.
I thought I was doing that.
You wrote “no kernel after update” in the topic title.
