I’m having a real problem here. My Manjaro installation got corrupted so I decided to reinstall with the latest version. However I discovered that I have no internet on either the live cd or after I install. I have the dreaded Realtek 8111 chip, so I think that’s the problem. The question is, how do I fix this? I have access to another computer that I can download something onto a USB key if need be, but I don’t know what to do.
Oddly enough, before my installation corrupted itself everything was working fine and I was up to date with the latest kernel so I don’t know what happened.
I managed to restore my system from an old backup I had and the internet is working again. It’s not the driver because it’s using the latest one which is the version that supposedly doesn’t work (r8169). Perhaps my router didn’t like me reinstalling the OS?
Hi @tempest2084,
Please, post the output of the terminal command inxi -Fazy here.
Meanwhile, you could take a look at this post in the forum.
‘No Ethernet with RTL8125 - #2 by bogdancovaciu’
Read inside the post which includes your realtek 8169 card.
You could also search for another solutions in the forum typing realtek 8169.
Hope it helps, regards
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=38bf1d9c-d4fd-4d72-b6cb-8407756db8fd ro quiet udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Type: Desktop Mobo: EVGA model: 141-BL-E757 v: Tylersburg serial: <filter>
BIOS: Phoenix v: 6.00 PG date: 08/25/2011
Device-1: hidpp_battery_0 model: Logitech M510 serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Quad Core model: Intel Core i7 920 bits: 64 type: MT MCP arch: Nehalem
family: 6 model-id: 1A (26) stepping: 5 microcode: 1D cache: L2: 8 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 42466
Speed: 1592 MHz min/max: 1596/2661 MHz boost: enabled Core speeds (MHz):
1: 1592 2: 1592 3: 1592 4: 1592 5: 1591 6: 1592 7: 1591 8: 1592
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Device-1: AMD Cape Verde XT [Radeon HD 7770/8760 / R7 250X]
vendor: Hightech Information System driver: radeon v: kernel
alternate: amdgpu bus-ID: 02:00.0 chip-ID: 1002:683d class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: DVI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: AMD VERDE (DRM 2.50.0 5.10.19-1-MANJARO LLVM 11.1.0)
v: 4.5 Mesa 20.3.4 direct render: Yes
Device-1: Intel 82801JI HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Hightech Information System driver: snd_hda_intel v: kernel
bus-ID: 02:00.1 chip-ID: 1002:aab0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.22 running: no
driver: r8169 v: kernel port: de00 bus-ID: 06:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.25 TiB used: 385.93 GiB (30.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD5001AALS-00L3B2
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
serial: <filter> rev: 3B01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 71E0 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 EVO 500GB
rotation: SSD serial: <filter> rev: 4B6Q
ID-1: / raw-size: 111.79 GiB size: 109.53 GiB (97.98%)
used: 51.68 GiB (47.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 26.0 C mobo: N/A gpu: radeon temp: 31.0 C
Processes: 232 Uptime: 10m wakeups: 26 Memory: 11.69 GiB
used: 972.3 MiB (8.1%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1513 lib: 449 flatpak: 0 Shell: Bash v: 5.1.0
running-in: gnome-terminal inxi: 3.3.02
Hi @tempest2084 ,
In the following post it is said that you have to build the driver from source. The reasons are at the end of the post.
https://forum.manjaro.org/t/r8125b-still-not-runninng/54201/5´
Hope it help, regards,
But why is it working now after I restored my system? I know I never did anything like building a driver from scratch.
Hi @tempest2084 ,
I apologize for the previous post, I understood you have problems with your wifi card and not with your ethernet one.
Regards,
I dont have a wifi card, just the built in ethernet
Hi @tempest2084,
Please read what @megavolt wrote on the following post in order to see what is happening to your ethernet adapter.
‘Ethernet disappeared after trying to update’
You could try this since it is the same chip-id there (10ec:8168).
Manjaro Settings Manager GUI can install linux510-r8168
and create a file /etc/modprobe.d/r8169_blacklist.conf to blacklist the r8169 driver
Network-8168 and network-8169 works really bad with my computer
Or this command
sudo mhwd --install pci network-r8168
