I have had Manjaro for about a year now. Everything has been great and working really well. Last night, I rebooted and it loaded up without detecting any input or output devices, which includes USB and aux input and output. I’ve tried different kernels and various solutions from this site and others with no luck. Other people that have had this same problem seemed to have the problem fixed eventually with a few reboots. So far, I haven’t been that lucky. All audio devices work perfectly on windows.
One thing I did different is try to set up Visual Studio Code with SDL libraries. I downloaded gcc and gdb for compiling purposes. But if there was a conflict, it would have thrown a warning at least.
Some information on my system with ALSA information:
!!ALSA Information Script v 0.4.65
!!################################!!Script ran on: Mon Dec 7 03:05:06 UTC 2020
!!Linux Distribution
!!------------------ID_LIKE=arch
!!DMI Information
!!---------------Manufacturer: Alienware
Product Name: Alienware Aurora R5
Product Version: 1.0.19
Firmware Version: 1.0.19
Board Vendor: Alienware
Board Name: 01NYPT!!ACPI Device Status Information
!!---------------/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT345D:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/MSFT0101:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0501:00/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 15
/sys/bus/acpi/devices/PNP0C02:04/status 3
/sys/bus/acpi/devices/PNP0C02:06/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 9
/sys/bus/acpi/devices/PNP0C0F:01/status 9
/sys/bus/acpi/devices/PNP0C0F:02/status 9
/sys/bus/acpi/devices/PNP0C0F:03/status 9
/sys/bus/acpi/devices/PNP0C0F:04/status 9
/sys/bus/acpi/devices/PNP0C0F:05/status 9
/sys/bus/acpi/devices/PNP0C0F:06/status 9
/sys/bus/acpi/devices/PNP0C0F:07/status 9
/sys/bus/acpi/devices/device:60/status 15
/sys/bus/acpi/devices/device:75/status 11!!Kernel Information
!!------------------Kernel release: 5.8.18-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes!!ALSA Version
!!------------Driver version: k5.8.18-1-MANJARO
Library version: 1.2.3.2
Utilities version: 1.2.3!!Loaded ALSA modules
!!-------------------snd_hda_intel
snd_hda_intel
snd_usb_audio!!Sound Servers on this system
!!----------------------------Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - NoJack:
Installed - Yes (/usr/bin/jackd)
Running - No!!Soundcards recognised by ALSA
!!-----------------------------0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0xdf420000 irq 139
1 [NVidia ]: HDA-Intel - HDA NVidia
HDA NVidia at 0xdf080000 irq 17
2 [AUDIO ]: USB-Audio - USB AUDIO
USB AUDIO at usb-0000:00:14.0-1, full speed!!PCI Soundcards installed in the system
!!--------------------------------------00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
Subsystem: Dell Device [1028:0729]
01:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
Subsystem: Dell Device [1028:119d]!!Loaded sound module options
!!---------------------------!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 0
power_save_controller : N
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1!!Module: snd_hda_intel
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 0
single_cmd : -1
snoop : -1!!Module: snd_usb_audio
autoclock : Y
delayed_register : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
ignore_ctl_error : N
pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
quirk_alias : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
skip_validation : N
use_vmalloc : Y
vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1!!HDA-Intel Codec information
–startcollapse–Codec: Realtek ALC3861
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec0899
Subsystem Id: 0x10280729
Revision Id: 0x100003
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=2, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x411: Stereo
Device: name=“ALC3861 Analog”, type=“Audio”, device=0
Converter: stream=0, channel=0
PCM:
rates [0x5e0]: 44100 48000 88200 96000 192000
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Control: name=“IEC958 Playback Con Mask”, index=16, device=0
Control: name=“IEC958 Playback Pro Mask”, index=16, device=0
Control: name=“IEC958 Playback Default”, index=16, device=0
Control: name=“IEC958 Playback Switch”, index=16, device=0
Control: name=“IEC958 Default PCM Playback Switch”, index=0, device=0
Device: name=“ALC3861 Digital”, type=“SPDIF”, device=1
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name=“Capture Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name=“Capture Switch”, index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x27 0x27]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x24
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name=“Capture Volume”, index=1, device=0
Control: name=“Capture Switch”, index=1, device=0
Device: name=“ALC3861 Alt Analog”, type=“Audio”, device=2
Amp-In vals: [0x80 0x80]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name=“Capture Volume”, index=2, device=0
Control: name=“Capture Switch”, index=2, device=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Audio Input] wcaps 0x100791: Stereo Digital
SDI-Select: 0
Digital:
PCM:
rates [0x570]: 32000 44100 48000 96000 192000
formats [0x1]: PCM
Unsolicited: tag=00, enabled=0
Connection: 1
0x1f
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name=“Front Mic Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name=“Front Mic Playback Switch”, index=0, device=0
Control: name=“Rear Mic Playback Volume”, index=0, device=0
Control: name=“Rear Mic Playback Switch”, index=0, device=0
Control: name=“Line Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name=“Line Playback Switch”, index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Front Playback Volume”, index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x3c 0x3c]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Surround Playback Volume”, index=0, device=0
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Center Playback Volume”, index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name=“LFE Playback Volume”, index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Side Playback Volume”, index=0, device=0
Connection: 2
0x05 0x0b
Node 0x10 [Audio Output] wcaps 0x611: Stereo Digital
Digital:
PCM:
formats [0x1]: PCM
Node 0x11 [Pin Complex] wcaps 0x400701: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x40028000: [N/A] Line Out at Ext N/A
Conn = 1/4, Color = Purple
DefAssociation = 0x0, Sequence = 0x0
Pin-ctls: 0x40: OUT
Connection: 1
0x10
Node 0x12 [Pin Complex] wcaps 0x400401: Stereo
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name=“Front Playback Switch”, index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0001003c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name=“Surround Playback Switch”, index=0, device=0
Pincap 0x0000003c: IN OUT HP Detect
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Unsolicited: tag=06, enabled=1
Connection: 5
0x0c 0x0d* 0x0e 0x0f 0x26
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name=“Center Playback Switch”, index=0, device=0
Control: name=“LFE Playback Switch”, index=0, device=0
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Unsolicited: tag=07, enabled=1
Connection: 5
0x0c 0x0d 0x0e* 0x0f 0x26
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name=“Side Playback Switch”, index=0, device=0
Pin Default 0x01012014: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Grey
DefAssociation = 0x1, Sequence = 0x4
Pin-ctls: 0x40: OUT
Unsolicited: tag=08, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name=“Rear Mic Boost Volume”, index=0, device=0
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Amp-Out vals: [0x80 0x80]
Pincap 0x0000373c: IN OUT HP Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19030: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x3, Sequence = 0x0
Pin-ctls: 0x21: IN VREF_50
Unsolicited: tag=03, enabled=1
Connection: 5
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name=“Front Mic Boost Volume”, index=0, device=0
Pin Default 0x02a19031: [Jack] Mic at Ext Front
DefAssociation = 0x3, Sequence = 0x1
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name=“Line Boost Volume”, index=0, device=0
Pin Default 0x0181303f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x3, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name=“Headphone Playback Switch”, index=0, device=0
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x0221401f: [Jack] HP Out at Ext Front
DefAssociation = 0x1, Sequence = 0xf
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f 0x26*
Node 0x1c [Pin Complex] wcaps 0x400481: Stereo
Pincap 0x00000024: IN Detect
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x4025e601: [N/A] HP Out at Ext N/A
Conn = Optical, Color = White
DefAssociation = 0x0, Sequence = 0x1
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400701: Stereo Digital
Pin Default 0x014b6120: [Jack] SPDIF Out at Ext Rear
Conn = Comb, Color = Orange
DefAssociation = 0x2, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Pin Complex] wcaps 0x400681: Stereo Digital
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=28
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 11
0x18 0x19 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 11
Node 0x24 [Audio Selector] wcaps 0x300101: Stereo
Connection: 12
0x18 0x19* 0x1a 0x1b 0x1c 0x1d 0x14 0x15 0x16 0x17 0x0b 0x12
Node 0x25 [Audio Output] wcaps 0x411: Stereo
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010f: Stereo Amp-In Amp-Out
Control: name=“Headphone Playback Volume”, index=0, device=0
Connection: 2
0x25 0x0b
Codec: Intel Skylake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x80862809
Subsystem Id: 0x80860101
Revision Id: 0x100000
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Digital: Enabled KAE
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x08 [Vendor Defined Widget] wcaps 0xf00000: Mono
Codec: Nvidia GPU 83 HDMI/DP
Address: 0
Vendor Id: 0x10de0083
Subsystem Id: 0x1028119d
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 1, ELDV = 1, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x0a 0x0b 0x0c 0x0d
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x0a 0x0b 0x0c 0x0d
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
0x0a 0x0b 0x0c 0x0d
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=0d, enabled=1
Devices: 4
Connection: 4
0x0a 0x0b 0x0c 0x0d
Node 0x08 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin Default 0x585600f0: [N/A] Digital Out at Int HDMI
Pin-ctls: 0x00:
Devices: 4
Connection: 4
0x0a 0x0b 0x0c 0x0d
Node 0x09 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
0x0a 0x0b 0x0c 0x0d
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0c [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0d [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
–endcollapse–!!USB Mixer information
–startcollapse–USB Mixer: usb_id=0x11301620, ctrlif=0, ctlerr=0
Card: USB AUDIO at usb-0000:00:14.0-1, full speed
Unit: 2
Control: name=“PCM Playback Volume”, index=0
Info: id=2, control=2, cmask=0x3, channels=2, type=“S16”
Volume: min=0, max=17152, dBmin=0, dBmax=6700
Unit: 2
Control: name=“PCM Playback Switch”, index=0
Info: id=2, control=1, cmask=0x0, channels=1, type=“INV_BOOLEAN”
Volume: min=0, max=1, dBmin=0, dBmax=0
–endcollapse–!!ALSA Device nodes
!!-----------------crw-rw---- 1 root audio 116, 22 Dec 6 21:44 /dev/snd/controlC0
crw-rw---- 1 root audio 116, 10 Dec 6 21:44 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 24 Dec 6 21:44 /dev/snd/controlC2
crw-rw---- 1 root audio 116, 20 Dec 6 21:44 /dev/snd/hwC0D0
crw-rw---- 1 root audio 116, 21 Dec 6 21:44 /dev/snd/hwC0D2
crw-rw---- 1 root audio 116, 9 Dec 6 21:44 /dev/snd/hwC1D0
crw-rw---- 1 root audio 116, 12 Dec 6 21:44 /dev/snd/pcmC0D0c
crw-rw---- 1 root audio 116, 11 Dec 6 21:44 /dev/snd/pcmC0D0p
crw-rw---- 1 root audio 116, 19 Dec 6 21:44 /dev/snd/pcmC0D10p
crw-rw---- 1 root audio 116, 13 Dec 6 21:44 /dev/snd/pcmC0D1p
crw-rw---- 1 root audio 116, 14 Dec 6 21:44 /dev/snd/pcmC0D2c
crw-rw---- 1 root audio 116, 15 Dec 6 21:44 /dev/snd/pcmC0D3p
crw-rw---- 1 root audio 116, 16 Dec 6 21:44 /dev/snd/pcmC0D7p
crw-rw---- 1 root audio 116, 17 Dec 6 21:44 /dev/snd/pcmC0D8p
crw-rw---- 1 root audio 116, 18 Dec 6 21:44 /dev/snd/pcmC0D9p
crw-rw---- 1 root audio 116, 6 Dec 6 21:44 /dev/snd/pcmC1D10p
crw-rw---- 1 root audio 116, 7 Dec 6 21:44 /dev/snd/pcmC1D11p
crw-rw---- 1 root audio 116, 8 Dec 6 21:44 /dev/snd/pcmC1D12p
crw-rw---- 1 root audio 116, 2 Dec 6 21:44 /dev/snd/pcmC1D3p
crw-rw---- 1 root audio 116, 3 Dec 6 21:44 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 4 Dec 6 21:44 /dev/snd/pcmC1D8p
crw-rw---- 1 root audio 116, 5 Dec 6 21:44 /dev/snd/pcmC1D9p
crw-rw---- 1 root audio 116, 23 Dec 6 21:44 /dev/snd/pcmC2D0p
crw-rw---- 1 root audio 116, 1 Dec 6 21:44 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Dec 6 21:44 /dev/snd/timer/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root 60 Dec 6 21:54 .
drwxr-xr-x 4 root root 580 Dec 6 21:54 …
lrwxrwxrwx 1 root root 12 Dec 6 21:44 usb-1130_USB_AUDIO-00 -> …/controlC2/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 Dec 6 21:54 .
lrwxrwxrwx 1 root root 12 Dec 6 21:44 pci-0000:00:14.0-usb-0:1:1.0 -> …/controlC2
lrwxrwxrwx 1 root root 12 Dec 6 21:44 pci-0000:00:1f.3 -> …/controlC0
lrwxrwxrwx 1 root root 12 Dec 6 21:44 pci-0000:01:00.1 -> …/controlC1!!Aplay/Arecord output
!!--------------------APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC3861 Analog [ALC3861 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC3861 Digital [ALC3861 Digital]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
card 2: AUDIO [USB AUDIO], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC3861 Alt Analog [ALC3861 Alt Analog]
Subdevices: 2/2
Subdevice #1: subdevice #1!!Amixer output
!!-------------!!-------Mixer controls for card PCH
Card hw:0 ‘PCH’/‘HDA Intel PCH at 0xdf420000 irq 139’
Mixer name : ‘Realtek ALC3861’
Components : ‘HDA:10ec0899,10280729,00100003 HDA:80862809,80860101,00100000’
Controls : 88
Simple ctrls : 28
Simple mixer control ‘Master’,0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 60 [69%] [-20.25dB] [on]
Simple mixer control ‘Headphone’,0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘Front’,0
Mono:
Simple mixer control ‘Front Mic’,0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control ‘Front Mic Boost’,0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control ‘Surround’,0
Mono:
Simple mixer control ‘Center’,0
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control ‘LFE’,0
Simple mixer control ‘Side’,0
Mono:
Simple mixer control ‘Line’,0
Mono:
Simple mixer control ‘Line Boost’,0
Limits: 0 - 3
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control ‘IEC958 Default PCM’,0
Mono: Playback [on]
Simple mixer control ‘IEC958’,1
Mono: Playback [on]
Simple mixer control ‘IEC958’,2
Mono: Playback [on]
Simple mixer control ‘IEC958’,3
Mono: Playback [on]
Simple mixer control ‘IEC958’,4
Mono: Playback [on]
Simple mixer control ‘IEC958’,16
Mono: Playback [off]
Simple mixer control ‘Capture’,0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control ‘Capture’,1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control ‘Capture’,2
Simple mixer control ‘Auto-Mute Mode’,0
Capabilities: enum
Items: ‘Disabled’ ‘Enabled’
Item0: ‘Enabled’
Simple mixer control ‘Input Source’,0
Capabilities: cenum
Items: ‘Front Mic’ ‘Rear Mic’ ‘Line’
Item0: ‘Front Mic’
Simple mixer control ‘Input Source’,1
Capabilities: cenum
Item0: ‘Front Mic’
Simple mixer control ‘Input Source’,2
Capabilities: cenum
Item0: ‘Front Mic’
Simple mixer control ‘Loopback Mixing’,0
Capabilities: enum
Item0: ‘Disabled’
Simple mixer control ‘Rear Mic’,0
Mono:
Simple mixer control ‘Rear Mic Boost’,0
Limits: 0 - 3
Front Right: 0 [0%] [0.00dB]!!-------Mixer controls for card NVidia
Card hw:1 ‘NVidia’/‘HDA NVidia at 0xdf080000 irq 17’
Mixer name : ‘Nvidia GPU 83 HDMI/DP’
Components : ‘HDA:10de0083,1028119d,00100100’
Controls : 49
Simple ctrls : 7
Simple mixer control ‘IEC958’,5
Simple mixer control ‘IEC958’,6
Mono: Playback [off]!!-------Mixer controls for card AUDIO
Card hw:2 ‘AUDIO’/‘USB AUDIO at usb-0000:00:14.0-1, full speed’
Mixer name : ‘USB Mixer’
Components : ‘USB1130:1620’
Controls : 4
Simple ctrls : 1
Simple mixer control ‘PCM’,0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 8576
Mono:
Front Left: Playback 0 [0%] [0.00dB] [on]
Front Right: Playback 0 [0%] [0.00dB] [on]!!Alsactl output
!!--------------–startcollapse–
state.PCH {
control.1 {
iface MIXER
name ‘Front Playback Volume’
value.0 87
value.1 87
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.2 {
iface MIXER
name ‘Front Playback Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.3 {
iface MIXER
name ‘Surround Playback Volume’
value.0 87
value.1 87
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name ‘Surround Playback Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.5 {
iface MIXER
name ‘Center Playback Volume’
value 87
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 0
control.6 {
iface MIXER
name ‘LFE Playback Volume’
value 87
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name ‘Center Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.8 {
iface MIXER
name ‘LFE Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.9 {
iface MIXER
name ‘Side Playback Volume’
value.0 87
value.1 87
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.10 {
iface MIXER
name ‘Side Playback Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.11 {
iface MIXER
name ‘Headphone Playback Volume’
value.0 87
value.1 87
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.12 {
iface MIXER
name ‘Headphone Playback Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.13 {
iface MIXER
name ‘Loopback Mixing’
value Disabled
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.14 {
iface MIXER
name ‘Front Mic Playback Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 31’
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name ‘Front Mic Playback Switch’
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.16 {
iface MIXER
name ‘Rear Mic Playback Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 31’
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
name ‘Rear Mic Playback Switch’
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.18 {
iface MIXER
name ‘Line Playback Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 31’
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.19 {
iface MIXER
name ‘Line Playback Switch’
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.20 {
iface MIXER
name ‘Auto-Mute Mode’
value Enabled
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.21 {
iface MIXER
name ‘Input Source’
value ‘Front Mic’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 ‘Front Mic’
item.1 ‘Rear Mic’
item.2 Line
control.22 {
iface MIXER
name ‘Input Source’
index 1
value ‘Front Mic’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 ‘Front Mic’
item.1 ‘Rear Mic’
item.2 Line
control.23 {
iface MIXER
name ‘Input Source’
index 2
value ‘Front Mic’
comment {
access ‘read write’
type ENUMERATED
count 1
item.0 ‘Front Mic’
item.1 ‘Rear Mic’
item.2 Line
control.24 {
iface MIXER
name ‘Capture Volume’
value.0 39
value.1 39
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 63’
dbmin -1725
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.25 {
iface MIXER
name ‘Capture Switch’
value.0 true
value.1 true
comment {
access ‘read write’
type BOOLEAN
count 2
control.26 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 63’
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.27 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.28 {
iface MIXER
index 2
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 63’
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.29 {
iface MIXER
index 2
value.0 false
value.1 false
comment {
access ‘read write’
type BOOLEAN
count 2
control.30 {
iface MIXER
name ‘Front Mic Boost Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 3’
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.31 {
iface MIXER
name ‘Rear Mic Boost Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 3’
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.32 {
iface MIXER
name ‘Line Boost Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 3’
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.33 {
iface MIXER
name ‘IEC958 Playback Con Mask’
index 16
value ‘0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
name ‘IEC958 Playback Pro Mask’
index 16
value ‘0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access read
type IEC958
count 1
control.35 {
iface MIXER
name ‘IEC958 Playback Default’
index 16
value ‘0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
access ‘read write’
type IEC958
count 1
control.36 {
iface MIXER
name ‘IEC958 Playback Switch’
index 16
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.37 {
iface MIXER
name ‘IEC958 Default PCM Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.38 {
iface MIXER
name ‘Master Playback Volume’
value 60
comment {
access ‘read write’
type INTEGER
count 1
range ‘0 - 87’
dbmin -6525
dbmax 0
dbvalue.0 -2025
control.39 {
iface MIXER
name ‘Master Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.40 {
iface CARD
name ‘Front Mic Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface CARD
name ‘Rear Mic Jack’
value true
comment {
access read
type BOOLEAN
count 1
control.42 {
iface CARD
name ‘Line Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.43 {
iface CARD
name ‘Line Out Front Jack’
value true
comment {
access read
type BOOLEAN
count 1
control.44 {
iface CARD
name ‘Line Out Surround Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.45 {
iface CARD
name ‘Line Out CLFE Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.46 {
iface CARD
name ‘Line Out Side Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.47 {
iface CARD
name ‘Front Headphone Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.48 {
iface CARD
name ‘SPDIF Phantom Jack’
value true
comment {
access read
type BOOLEAN
count 1
control.49 {
iface PCM
name ‘Playback Channel Map’
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access read
type INTEGER
count 8
range ‘0 - 36’
control.50 {
iface PCM
name ‘Capture Channel Map’
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.51 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.52 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.53 {
iface PCM
device 2
index 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.54 {
iface CARD
name ‘HDMI/DP,pcm=3 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.55 {
iface MIXER
comment {
access read
type IEC958
count 1
control.56 {
iface MIXER
comment {
access read
type IEC958
count 1
control.57 {
iface MIXER
comment {
access ‘read write’
type IEC958
count 1
control.58 {
iface MIXER
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.59 {
iface PCM
device 3
name ELD
value ‘’
comment {
access ‘read volatile’
type BYTES
count 0
control.60 {
iface CARD
name ‘HDMI/DP,pcm=7 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.61 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.62 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.63 {
iface MIXER
index 1
comment {
access ‘read write’
type IEC958
count 1
control.64 {
iface MIXER
index 1
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.65 {
iface PCM
device 7
name ELD
value ‘’
comment {
type BYTES
count 0
control.66 {
iface CARD
name ‘HDMI/DP,pcm=8 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.67 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.68 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.69 {
iface MIXER
index 2
comment {
access ‘read write’
type IEC958
count 1
control.70 {
iface MIXER
index 2
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.71 {
iface PCM
device 8
name ELD
value ‘’
comment {
type BYTES
count 0
control.72 {
iface CARD
name ‘HDMI/DP,pcm=9 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.73 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.74 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.75 {
iface MIXER
index 3
comment {
access ‘read write’
type IEC958
count 1
control.76 {
iface MIXER
index 3
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.77 {
iface PCM
device 9
name ELD
value ‘’
comment {
type BYTES
count 0
control.78 {
iface CARD
name ‘HDMI/DP,pcm=10 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.79 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.80 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.81 {
iface MIXER
index 4
comment {
access ‘read write’
type IEC958
count 1
control.82 {
iface MIXER
index 4
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.83 {
iface PCM
device 10
name ELD
value ‘’
comment {
type BYTES
count 0
control.84 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.85 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.86 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.87 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.88 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
state.NVidia {
control.1 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access ‘read write’
type IEC958
count 1
control.5 {
iface MIXER
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ‘100008006d100001000200000000000006b3b224524f47205047323438510a20200907010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
type BYTES
count 95
control.7 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access ‘read write’
type IEC958
count 1
control.11 {
iface MIXER
index 1
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ‘’
comment {
type BYTES
count 0
control.13 {
iface CARD
value true
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access ‘read write’
type IEC958
count 1
control.17 {
iface MIXER
index 2
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ‘100008006d140001001000000000000006b3b124524f47205047323438510a20200907010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000’
comment {
type BYTES
count 95
control.19 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access ‘read write’
type IEC958
count 1
control.23 {
iface MIXER
index 3
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ‘’
comment {
type BYTES
count 0
control.25 {
iface CARD
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access ‘read write’
type IEC958
count 1
control.29 {
iface MIXER
index 4
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ‘’
comment {
type BYTES
count 0
control.31 {
iface CARD
name ‘HDMI/DP,pcm=11 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access ‘read write’
type IEC958
count 1
control.35 {
iface MIXER
index 5
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ‘’
comment {
type BYTES
count 0
control.37 {
iface CARD
name ‘HDMI/DP,pcm=12 Jack’
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access ‘read write’
type IEC958
count 1
control.41 {
iface MIXER
index 6
value false
comment {
access ‘read write’
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ‘’
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access ‘read write’
type INTEGER
count 8
range ‘0 - 36’
state.AUDIO {
control.1 {
iface PCM
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range ‘0 - 36’
control.2 {
iface MIXER
name ‘PCM Playback Switch’
value true
comment {
access ‘read write’
type BOOLEAN
count 1
control.3 {
iface MIXER
name ‘PCM Playback Volume’
value.0 0
value.1 0
comment {
access ‘read write’
type INTEGER
count 2
range ‘0 - 8576’
dbmin 0
dbmax 6700
dbvalue.0 0
dbvalue.1 0
control.4 {
iface CARD
name ‘Keep Interface’
value false
comment {
access ‘read write’
type BOOLEAN
count 1
–endcollapse–!!All Loaded Modules
!!------------------8250_dw
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
alienware_wmi
alx
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cec
cfg80211
cmac
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dcdbas
dell_smbios
dell_wmi
dell_wmi_descriptor
drm
drm_kms_helper
ecc
ecdh_generic
ee1004
evdev
ext4
fat
fb_sys_fops
ff_memless
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_sony
i2c_algo_bit
i2c_i801
i2c_smbus
i915
iTCO_vendor_support
iTCO_wdt
idma64
input_leds
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_uncore
intel_wmi_thunderbolt
ip_tables
ipmi_devintf
ipmi_msghandler
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
libarc4
mac80211
mac_hid
mbcache
mc
mdio
mei
mei_hdcp
mei_me
mousedev
mxm_wmi
nls_cp437
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
pcspkr
rapl
rc_core
rfcomm
rfkill
rng_core
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_rawmidi
snd_seq
snd_seq_device
snd_seq_dummy
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
sparse_keymap
syscopyarea
sysfillrect
sysimgblt
tpm
tpm_crb
tpm_tis
tpm_tis_core
uas
uinput
usb_storage
usbhid
vboxdrv
vboxnetadp
vboxnetflt
vfat
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci!!Sysfs Files
!!-----------/sys/class/sound/hwC0D0/init_pin_configs:
0x11 0x40028000
0x12 0x411111f0
0x14 0x01014010
0x15 0x01011012
0x16 0x01016011
0x17 0x01012014
0x18 0x01a19030
0x19 0x02a19031
0x1a 0x0181303f
0x1b 0x0221401f
0x1c 0x411111f0
0x1d 0x4025e601
0x1e 0x014b6120
0x1f 0x411111f0/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
0x08 0x585600f0
0x09 0x585600f0/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
Let me know if you need any other information and I appreciate the help.
Edit: When going to the pulseaudio volume controller, it is perpecutally stuck on “Establishing connection to PulseAudio. Please wait…”. So I tried to enable PulseAudio and check the status in the terminal. This is what is came back with:
[ginrai@Midgar ~]$ systemctl --user enable pulseaudio.service
[ginrai@Midgar ~]$ systemctl --user status pulseaudio.service
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; vend>
Active: failed (Result: exit-code) since Mon 2020-12-07 16:45:16 EST; 4>
TriggeredBy: ● pulseaudio.socket
Main PID: 6271 (code=exited, status=1/FAILURE)Dec 07 16:45:16 Midgar systemd[965]: Failed to start Sound Service.
Dec 07 16:45:16 Midgar systemd[965]: pulseaudio.service: Scheduled restart j>
Dec 07 16:45:16 Midgar systemd[965]: Stopped Sound Service.
Dec 07 16:45:16 Midgar systemd[965]: pulseaudio.service: Start request repea>
Dec 07 16:45:16 Midgar systemd[965]: pulseaudio.service: Failed with result >
lines 1-12/12 (END)
