No image previews in ranger with manjaro-ranger-settings
Hi, Community!
In Manjaro i3 the ranger file manager is provided by the manjaro-ranger-settings package, which also comes with python-ueberzug instead of w3mimgdisplay.
However, I have no luck getting image previews in ranger with the default configuration.
Has anybody experienced a similar problem?
Which terminal?
rxvt-unicode-256color
Let me test. BRB.
:edit: Working here:
What do you have in ~/.config/ranger/rc.conf:
set preview_images_method ueberzug
I use kitty.
I use alacritty
Sorry for the late reply,
Here's my ~/.config/ranger/rc.conf:
set show_hidden true
set preview_images true
set colorscheme zenburn
set draw_borders both
Also, I've found three different rc.conf files:
/etc/skel/.config/ranger/rc.conf
/usr/share/doc/ranger/config/rc.conf
/usr/lib/python3.8/site-packages/ranger/config/rc.conf
(Actually, the last two are identical, but the first one is different.)
Which one of them should be in use?
UPD
I synced my ~/.config/ranger to /etc/skel/.config/ranger, but still no luck :frowning:
I just tested ranger booting the latest i3 edition ISO image (18.1.5 - 191229) and can confirm that image previews don't work when using ueberzug as the preview method.
You can
1
use w3m as the preview method - in your ~/.config/ranger/rc.conf file add
set preview_images_method w3m
and restart ranger (the package w3m is needed for this to work)
or
2
install ranger-git from the AUR (replacing ranger in your system) and use ueberzug for image previews.
Thanks, replacing ranger with ranger-git from the AUR solved the problem. I hope the Manjaro version of ranger gets updated soon, so I can switch back.
Thanks for the heads up. I'll look into it when I get the opportunity.
Looks like I have -git installed :blush:
I don't know if you remember @Chrysostomus I had problems a while back, on a fresh non-architect install.
aur/ranger-git 1.9.2.333.gfcb01c2c-1 [installed] [143+] [0.37%] [25 Sep 2019]
community/python-pillow 6.2.1-1 [installed]
aur/python-ueberzug-git 18.1.5.a8ac9c3-1 [installed] [4+] [0.85%] [5 Nov 2019]
Is what I have.
I don't know anything about alacritty; that said, I like how I can view images directly from the terminal using kitty.
Ueberzug image previews should also work in tty.
By the way, I also tried alacritty, but it didn't work either. (We now know why, of course - because the problem was in ranger itself.)
I updated now all branches based on ranger-git. We had been using the Arch package. I had not noticed because I was running ranger-git too
