I have installed MATE for the first time. But there is no grub menu, only login screen when I boot. My grub menu looks like this
I have remove the hashtag from GRUB_TERMINAL_OUTPUT=“console” from the grub menu.
Then -
sudo update-grub
Genererer en grub-konfigurationsfil …
Fandt tema: /usr/share/grub/themes/manjaro/theme.txt
Fandt linux-aftryk: /boot/vmlinuz-5.9-x86_64
Fandt initrd-aftryk: /boot/intel-ucode.img /boot/initramfs-5.9-x86_64.img
Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
Fandt linux-aftryk: /boot/vmlinuz-5.4-x86_64
Fandt initrd-aftryk: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
Adding boot menu entry for UEFI Firmware Settings …
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
But the grub menu does not pop up when I boot. Login screen only
I use SSD hardisk
