This may or may not actually be an issue but I would like very much if someone could confirm if it is or not. ( I am currently troubleshooting other display issues and would like to rule this out.)
The output of mhwd -lh is not returning any reference to the gpu nor has an x11 gpu config.
~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=967fbe57-dccb-4c21-97c3-6538726a1c72 rw
cryptdevice=UUID=27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8:luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8
root=/dev/mapper/luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8 apparmor=1
security=apparmor
resume=/dev/mapper/luks-5abbce8b-5d41-49dd-85ee-585f050a6573
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX TRX40-XE GAMING v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 1402 date: 01/15/2021
RAM: total: 125.66 GiB used: 14.98 GiB (11.9%)
Info: 24-Core (3-Die) model: AMD Ryzen Threadripper 3960X bits: 64
type: MT MCP MCM arch: Zen 2 family: 17 (23) model-id: 31 (49) stepping: 0
microcode: 8301039 cache: L2: 12 MiB bogomips: 374547
Speed: 3900 MHz min/max: 2200/3900 MHz boost: disabled Core speeds (MHz):
1: 3900 2: 3900 3: 3900 4: 3900 5: 3900 6: 3900 7: 3900 8: 3900 9: 3900
10: 3900 11: 3900 12: 3900 13: 3900 14: 3900 15: 3900 16: 3900 17: 3900
18: 3900 19: 3900 20: 3900 21: 3900 22: 3900 23: 3900 24: 3900 25: 3898
26: 3900 27: 3900 28: 3900 29: 3900 30: 3900 31: 3900 32: 3900 33: 3895
34: 3900 35: 3900 36: 3900 37: 3900 38: 3900 39: 3900 40: 3900 41: 3900
42: 3900 43: 3900 44: 3900 45: 3900 46: 3900 47: 3900 48: 3900
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6900 XT] vendor: XFX Limited driver: amdgpu
v: kernel bus-ID: 03:00.0 chip-ID: 1002:73af class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60
OpenGL: renderer: AMD Radeon RX 6900 XT (SIENNA_CICHLID DRM 3.41.0
5.13.1-3-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.4 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: N/A
alternate: snd_hda_intel bus-ID: 22:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sennheiser EPOS GSA 70 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-2.1:5 chip-ID: 1395:0300
class-ID: 0300 serial: <filter>
Device-4: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-6:7 chip-ID: 0b05:1917
class-ID: 0300
Sound Server-1: ALSA v: k5.13.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 1.82 TiB used: 139.24 GiB (7.5%)
model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: 613000WD scheme: GPT
ID-1: / raw-size: 1.68 TiB size: 1.66 TiB (98.37%) used: 139.24 GiB (8.2%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8 label: N/A
uuid: 967fbe57-dccb-4c21-97c3-6538726a1c72
used: 440 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 9F26-5C4D
ID-1: swap-1 type: partition size: 138.3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-5abbce8b-5d41-49dd-85ee-585f050a6573 label: N/A
uuid: fc800bb8-e5cb-4537-a792-053289270b01
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 1.68 TiB fs: <superuser required>
label: N/A uuid: 27fdcc04-1c50-4f1e-8d76-a7df28ed5ac8
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 138.3 GiB fs: <superuser required>
label: N/A uuid: 5abbce8b-5d41-49dd-85ee-585f050a6573
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-2:2 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b2d class-ID: 0300
serial: <filter>
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 7-4:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-8: 7-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 7-5.3:5 info: NZXT USB Device type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1e71:2007
Device-2: 7-6:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-9: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 9-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-11: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-12: 9-2:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Device-1: 9-2.1:5 info: Sennheiser EPOS GSA 70 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 96mA chip-ID: 1395:0300 class-ID: 0300
serial: <filter>
Device-2: 9-4:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:1872 class-ID: 0300 serial: <filter>
Device-3: 9-5:6 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Device-4: 9-6:7 info: ASUSTek USB Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0b05:1917 class-ID: 0300
Hub-13: 10-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-14: 10-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 49.2 C mobo: 41.0 C gpu: amdgpu temp: 58.0 C
mem: 60.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1567 fan-3: 3400 fan-5: 0 fan-6: 0
fan-7: 1192 gpu: amdgpu fan: 495
Processes: 784 Uptime: 3d 22h 48m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1237 pacman: 1228 lib: 329
flatpak: 4 snap: 5 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
~]$ sudo mhwd-gpu --status
:: status
warning: could not find '/etc/X11/xorg.conf.d/90-mhwd.conf'!
~]$ mhwd -lh
> PCI devices:
TYPE BUS CLASS VENDOR DEVICE CONFIGS
Serial bus controller 0000:46:00.3 0c03 1022 149c 0
Display controller 0000:03:00.0 0300 1002 73af 3
Bridge 0000:60:07.0 0600 1022 1482 0
Bridge 0000:20:00.0 0600 1022 1480 0
Generic system peripheral 0000:60:00.2 0806 1022 1481 0
Bridge 0000:00:08.0 0600 1022 1482 0
Serial bus controller 0000:05:00.3 0c03 1022 148c 0
Bridge 0000:20:08.1 0604 1022 1484 0
Bridge 0000:42:04.0 0604 1022 57a3 0
Bridge 0000:00:18.3 0600 1022 1493 0
Bridge 0000:40:05.0 0600 1022 1482 0
Serial bus controller 0000:22:00.3 0c03 1022 148c 0
Serial bus controller 0000:46:00.1 0c03 1022 149c 0
Network controller 0000:43:00.0 0200 10ec 8125 0
Bridge 0000:20:03.0 0600 1022 1482 0
Bridge 0000:60:00.0 0600 1022 1480 0
Bridge 0000:40:08.0 0600 1022 1482 0
Bridge 0000:00:18.1 0600 1022 1491 0
Bridge 0000:02:00.0 0604 1002 1479 0
Bridge 0000:60:08.1 0604 1022 1484 0
Encryption controller 0000:22:00.1 1080 1022 1486 0
Bridge 0000:00:01.0 0600 1022 1482 0
Mass storage controller 0000:49:00.0 0108 15b7 5011 0
Bridge 0000:60:03.0 0600 1022 1482 0
Bridge 0000:00:04.0 0600 1022 1482 0
Bridge 0000:00:14.3 0601 1022 790e 0
Bridge 0000:40:01.0 0600 1022 1482 0
Non-Essential Instrumentation 0000:4b:00.0 1300 1022 1485 0
Bridge 0000:01:00.0 0604 1002 1478 0
Mass storage controller 0000:48:00.0 0106 1022 7901 0
Bridge 0000:00:07.0 0600 1022 1482 0
Bridge 0000:20:07.1 0604 1022 1484 0
Serial bus controller 0000:03:00.3 0c80 1002 73a4 0
Bridge 0000:40:04.0 0600 1022 1482 0
Generic system peripheral 0000:00:00.2 0806 1022 1481 0
Bridge 0000:00:18.6 0600 1022 1496 0
Bridge 0000:20:02.0 0600 1022 1482 0
Bridge 0000:41:00.0 0604 1022 57ad 0
Non-Essential Instrumentation 0000:4a:00.0 1300 1022 148a 0
Bridge 0000:42:06.0 0604 1022 57a3 0
Multimedia controller 0000:03:00.1 0403 1002 ab28 0
Bridge 0000:40:07.0 0600 1022 1482 0
Bridge 0000:60:07.1 0604 1022 1484 0
Bridge 0000:00:00.0 0600 1022 1480 0
Mass storage controller 0000:47:00.0 0106 1022 7901 0
Generic system peripheral 0000:40:00.2 0806 1022 1481 0
Bridge 0000:00:08.1 0604 1022 1484 0
Bridge 0000:20:05.0 0600 1022 1482 0
Bridge 0000:00:18.4 0600 1022 1494 0
Multimedia controller 0000:22:00.4 0403 1022 1487 0
Bridge 0000:60:02.0 0600 1022 1482 0
Bridge 0000:42:09.0 0604 1022 57a4 0
Bridge 0000:00:03.0 0600 1022 1482 0
Bridge 0000:40:00.0 0600 1022 1480 0
Bridge 0000:20:08.0 0600 1022 1482 0
Bridge 0000:40:08.1 0604 1022 1484 0
Bridge 0000:00:18.2 0600 1022 1492 0
Bridge 0000:60:05.0 0600 1022 1482 0
Bridge 0000:00:01.1 0604 1022 1483 0
Bridge 0000:40:01.3 0604 1022 1483 0
Non-Essential Instrumentation 0000:46:00.0 1300 1022 1485 0
Bridge 0000:40:03.0 0600 1022 1482 0
Non-Essential Instrumentation 0000:05:00.0 1300 1022 1485 0
Bridge 0000:00:18.0 0600 1022 1490 0
Bridge 0000:60:08.0 0600 1022 1482 0
Non-Essential Instrumentation 0000:22:00.0 1300 1022 1485 0
Bridge 0000:20:01.0 0600 1022 1482 0
Bridge 0000:40:01.1 0604 1022 1483 0
Bridge 0000:42:05.0 0604 1022 57a3 0
Bridge 0000:42:0a.0 0604 1022 57a4 0
Bridge 0000:00:07.1 0604 1022 1484 0
Network controller 0000:45:00.0 0200 8086 2723 0
Bridge 0000:20:04.0 0600 1022 1482 0
Non-Essential Instrumentation 0000:62:00.0 1300 1022 1485 0
Bridge 0000:60:01.0 0600 1022 1482 0
Bridge 0000:42:08.0 0604 1022 57a4 0
Non-Essential Instrumentation 0000:04:00.0 1300 1022 148a 0
Bridge 0000:00:02.0 0600 1022 1482 0
Bridge 0000:00:18.7 0600 1022 1497 0
Non-Essential Instrumentation 0000:21:00.0 1300 1022 148a 0
Bridge 0000:20:07.0 0600 1022 1482 0
Serial bus controller 0000:03:00.2 0c03 1002 73a6 0
Bridge 0000:40:07.1 0604 1022 1484 0
Serial bus controller 0000:00:14.0 0c05 1022 790b 0
Bridge 0000:60:04.0 0600 1022 1482 0
Generic system peripheral 0000:20:00.2 0806 1022 1481 0
Bridge 0000:00:05.0 0600 1022 1482 0
Network controller 0000:44:00.0 0200 8086 1539 0
Bridge 0000:00:18.5 0600 1022 1495 0
Bridge 0000:40:02.0 0600 1022 1482 0
Non-Essential Instrumentation 0000:61:00.0 1300 1022 148a 0
> USB devices:
Multimedia controller 9-2.1:1.4 0401 1395 0300 0
Hub 6-0:1.0 10a00 1d6b 0003 0
Unclassified device 9-5:1.2 0000 0b05 18f3 0
Hub 9-1:1.0 10a00 05e3 0610 0
Unclassified device 9-6:1.6 0000 0b05 1917 0
Mouse 3-2:1.1 10503 1b1c 1b2d 0
Hub 3-0:1.0 10a00 1d6b 0002 0
Hub 7-0:1.0 10a00 1d6b 0002 0
Bluetooth Device 7-6:1.1 11500 8087 0029 0
Mouse 7-4:1.0 10503 046d c077 0
Hub 9-2:1.0 10a00 174c 2074 0
Unclassified device 7-5.3:1.0 0000 1e71 2007 0
Hub 10-0:1.0 10a00 1d6b 0003 0
Unclassified device 9-2.1:1.5 0000 1395 0300 0
Hub 4-0:1.0 10a00 1d6b 0003 0
Hub 8-0:1.0 10a00 1d6b 0003 0
Hub 7-5:1.0 10a00 05e3 0610 0
Hub 1-0:1.0 10a00 1d6b 0002 0
Keyboard 3-2:1.0 10800 1b1c 1b2d 0
Hub 5-0:1.0 10a00 1d6b 0002 0
Hub 9-0:1.0 10a00 1d6b 0002 0
Unclassified device 9-4:1.0 0000 0b05 1872 0
Hub 10-2:1.0 10a00 174c 3074 0
Hub 2-0:1.0 10a00 1d6b 0003 0
~]$ xrandr
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
DisplayPort-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
2560x1440R 59.95*+
640x480 59.94
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
Expected behavior: gpu info and config in mhwd. However the gpu is working fine and can be seen elsewhere in the system such as in the inxi output provided, games work fine. I would just expect mhwd to have… something, right?
Any insight would be greatly appreciated.
