Then from software perspective all looks good and maybe something is broken physically.
As a last resort you could try: ethtool -s eno1 speed 100
Reason: 100Mbps just needs two wire pairs, whilst 1Gbps needs all four. Means if one wire needed for 1Gbps has a problem, 100Mbps might still work.
That did nothing… until I pulled the cable out and plugged it in again. Now it finds the connection
Thank you so much!
Is there anything I can set so I don’t have ot run that command on every boot?
Usually the ethtool speed command triggers an auto-negotiation and re-plugging the cable isn’t needed. This leaves one question: What is your link partner, and has it auto-negotiation enabled? Not that your link partner is fixed at 100Mbps. Output of ethtool eno1 may help.
On the other end of the cable the router is directly connected. Auto-negotiation IIRC didn’t work correctly with my old PC (but it does for everything else in the house) or I just had a slower connection, so it was actually disabled in the UI.
However back then it definitely did show the connection, here it didn’t even recognize there was a cable plugged in (no LED blinking on the port or anything)
$ ethtool eno1
Settings for eno1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
2500baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 100baseT/Half 100baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Auto-negotiation: off
master-slave cfg: preferred slave
master-slave status: slave
Port: MII
PHYAD: 0
Transceiver: external
netlink error: Operation not permitted
Link detected: yes
Maybe the old PC supported max. 100Mbps. Best should be to re-enable auto-negotiation in your router and use the USB network adapter with the old PC if needed. With auto-negotiation in the router re-enabled, do you have 1Gbps after reboot of your system?
Everything is good for something: You got an idea how to analyze network problems. So you don’t have to believe any longer the people who immediately say (w/o having seen any log): the driver is crap.
My router apparently doesn’t support auto-negotiation, I can only switch between 100Mbit and 1Gbit.
Edit: after setting it to 1Gbit however the connection works automatically
