Hey, i’m trying to get an output on my primary display (GTX 1050) but instead get an output on my integrated graphics (Intel HD 630). I’m probably missing something obvious but i’m too dumb to figure that out. The only thing that shows up on my primary display is TTY.
Please post the output of inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=e2bbde26-02e1-4a86-9979-12ce2a243343 ro quiet intel_iommu=on
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
serial: <filter>
Mobo: ASUSTeK model: H110M-R v: Rev X.0x serial: <filter>
UEFI [Legacy]: American Megatrends v: 3202 date: 02/09/2017
Info: Dual Core model: Intel Core i3-7100 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 3 MiB
bogomips: 31211
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5912 class ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1c81 class ID: 0300
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: intel resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
class ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:818b class ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: c000 bus ID: 04:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Local Storage: total: 1.52 TiB used: 11.47 GiB (0.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD3200AAKX-753CA1
size: 298.09 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1H19 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD3200AVVS-63L2B0 size: 298.09 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 3A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-00MFCA0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Ultra
size: 28.64 GiB block size: physical: 512 B logical: 512 B serial: <filter>
rev: 1.00 scheme: MBR
ID-1: / raw size: 28.63 GiB size: 28.06 GiB (97.99%) used: 11.47 GiB (40.9%)
fs: ext4 dev: /dev/sdd1 maj-min: 8:49
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 32.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 980
Processes: 225 Uptime: 1m wakeups: 0 Memory: 7.65 GiB used: 1.62 GiB (21.2%)
Init: systemd v: 247 Compilers: gcc: N/A Packages: pacman: 1252 lib: 377
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.3.01
Linux 5.9 has reached its end of life, so I suggest switching to 5.10 or 5.4 (both LTS editions). After that, reinstall the mhwd-db
package: sudo pacman -Syu mhwd-db
, then run sudo mhwd -a pci nonfree 0300
, and then reboot.
