I’ve installed a few things in pacman and pamac from a few YouTube vids (only a handful).
I’m assuming the cause of my problem is the installation of intel-ucode as apparently it’s not compatible with my kernel?
(see post: solved-manjaro-kde-unable-to-boot-to-desktop-screen)
anyway, after a reboot, grub passes fine and i’m presented with a black, blank screen (plus some information line reading “/dev/sdb2: clean, 276624/12804096 files, 3440392/51200000 blocks”)
I can logon to a tty and reach a bash prompt. I have no idea what to do from here. is it a simple case of starting the kde desktop? or is there a boot script that isn’t running properly?
I’ve ran pacman -Syyu and nothing changes. pls help.
Without any informations as to what packages you installed, this does tell us nothing.
If there were no problems before installing “a few things” - remove them again to see if the problem is going away.
There is no such thing as an incompatibility between a microcode package and a kernel.
This does indicate a successful boot but with problems regarding graphics drivers and/or display manager.
I don’t think intel-ucode is responsible, but if you’re in doubt, just remove it again.
Since I only have access to the tty, I can’t give screen shots or printouts of logs. I’m using a different computer to post on this forum.
The apps that I installed was from TechHut’s video titled “Top 10 Linux Apps: Essential Software Everyone Needs”. From this vid, I installed: Stacer, SimpleNote and NotePadQQ
From this short list, I “assume” that the only app that would effect booting is Stacer since it tracks/monitors system resources.
I have just installed neofetch so that I can copy/type pc info: (please bear with, as I’m having to type this out… )
[quote=“freggel.doe, post:2, topic:80478”]
[/quote]
Apologies. I did not mean that I shouldn’t have intel-ucode installed. I meant I shouldn’t have the up-to-date version installed. This point is kinda mute tho since according to your opinion, my system has booted but is having issues with the graphical desktop. which makes sense, but I’m still noob.
I really don’t want to have to type out the whole of the printout that i get from running the inxi command!
I will type out some info on request, but I don’t know what info is needed.
Regarding my graphics:
Display: server: X.org 1.20.11 driver: loaded: vesa tty:N/A
How would I start my desktop?
just noticed that I have no drives mounted! That can’t be right, can it? these commands that I’m running are programs on a drive and they all can’t be inside GRUB, right? Have I got to remount some/all of these drives before I can boot normally?
Snippet from inxi command:
After looking at these lines, am I correct in thinking that these are the partitions on my winblows drive that is used because I dual boot? That would mean that this info is useless and I shouldn’t have wasted time typing these out…
I did have timeshift installed before this happened. I restored to a previous point, but I still get a blank screen with that one line at the top. it is from here that I can access tty.
Please tell me what info you need to fix my problem. I just want it to boot like it did after the initial install of Manjaro without having to reinstall the whole OS again.
Although it’s easy to create a video, it’s hard to keep the video updated and you’re on a rolling release model, so any video older than the last update is probably outdated. Anythhing older than 1 year is useless.
copy-paste my-inxi.txt here as that would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
I was doing a bit of experimentation/investigation.
i did sudo kde and was told sudo: kde: command not found
I did sudo startkde and was told sudo: startkde: command not found
I did sudo startx and was told
xauth: file /root/.Xauthority does not exist
X.Org X Server 1.20.11
Build operating System: Linux Manjaro Linux
Current Operating System: Linux unipad 5.4.124-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:16:42 UTC 2021 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID= *not typing this out!* rw quiet udev.log_priority=3
Build Date: 13 April 2021 04:11:08PM
Current version of pixman: 0.40.0
*before reporting blah blah*
Markers: *blah blah*
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Aug 30 17:07:55 2021
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
vesa: Refusing to run on UEFI
(EE) Fatal server error:
(EE) no screens found(EE)
(EE) Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to x server: Connection refused
xinit: server error
I did cat /var/log/Xorg.0.log | less and was given a wall of text!
so I scanned for issues
(==) No Layout section. Using first Screen section.
(==) No screen section available. Using defaults.
(II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
(II) Module vesa: vendor="X.Org Foundation"
compiled for 1.20.9, module version = 2.5.0
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 24.1
(II) VESA: driver for VESA chipsets: vesa
(EE) No devices detected.
from this, I assume that I should not be booting in UEFI mode even tho I installed in UEFI mode. Nani?!
The Manjaro telepathy module is still under heavy development by the Manjaro team and therefore our ability to link our brains directly to your computer is severely limited for the moment. Therefore, If you don’t know, we don’t know either…
I assume that I’m currently in tty4. I don’t know how to get to tty2.
running startx in tty4 fails.
here’s the log file from Xorg.0.log:
[ 5281.057] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 5281.060]
[ 5281.064] Build Operating System: Linux Manjaro Linux
[ 5281.065] Current Operating System: Linux unipad 5.4.124-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:16:42 UTC 2021 x86_64
[ 5281.065] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=1a27c761-4de5-469f-8198-e9a86fb14fd4 rw quiet udev.log_priority=3
[ 5281.067] Build Date: 13 April 2021 04:11:08PM
[ 5281.068]
[ 5281.069] Current version of pixman: 0.40.0
[ 5281.071] Before reporting problems, check http://wiki.x.org
[ 5281.071] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5281.074] (==) Log file: "/home/rece/.local/share/xorg/Xorg.0.log", Time: Mon Aug 30 18:35:04 2021
[ 5281.074] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5281.076] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5281.076] (==) No Layout section. Using the first Screen section.
[ 5281.076] (==) No screen section available. Using defaults.
[ 5281.076] (**) |-->Screen "Default Screen Section" (0)
[ 5281.076] (**) | |-->Monitor "<default monitor>"
[ 5281.076] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 5281.076] (**) | |-->Device "Device0"
[ 5281.076] (==) No monitor specified for screen "Default Screen Section".
[ 5281.076] (==) Automatically adding devices
[ 5281.076] (==) Automatically enabling devices
[ 5281.076] (==) Automatically adding GPU devices
[ 5281.076] (==) Automatically binding GPU devices
[ 5281.076] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5281.076] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5281.076] Entry deleted from font path.
[ 5281.076] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5281.076] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5281.076] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5281.076] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 5281.076] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5281.076] (**) Extension "Composite" is enabled
[ 5281.076] (**) Extension "RENDER" is enabled
[ 5281.076] (II) The server relies on udev to provide the list of input devices.
[ 5281.076] (II) Module ABI versions:
[ 5281.076] X.Org ANSI C Emulation: 0.4
[ 5281.076] X.Org Video Driver: 24.1
[ 5281.076] X.Org XInput driver : 24.1
[ 5281.076] X.Org Server Extension : 10.0
[ 5281.077] (++) using VT number 4
[ 5281.079] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 5281.080] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5281.080] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 5281.082] (--) PCI:*(0@0:2:0) 8086:1616:17aa:503e rev 9, Mem @ 0xf0000000/16777216, 0xe0000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 5281.082] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5281.082] (II) LoadModule: "glx"
[ 5281.082] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5281.083] (II) Module glx: vendor="X.Org Foundation"
[ 5281.083] compiled for 1.20.11, module version = 1.0.0
[ 5281.083] ABI class: X.Org Server Extension, version 10.0
[ 5281.083] (II) LoadModule: "vesa"
[ 5281.083] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 5281.083] (II) Module vesa: vendor="X.Org Foundation"
[ 5281.083] compiled for 1.20.9, module version = 2.5.0
[ 5281.083] Module class: X.Org Video Driver
[ 5281.083] ABI class: X.Org Video Driver, version 24.1
[ 5281.083] (II) VESA: driver for VESA chipsets: vesa
[ 5281.084] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 5281.084] vesa: Refusing to run on UEFI
[ 5281.084] (EE) No devices detected.
[ 5281.084] (EE)
Fatal server error:
[ 5281.084] (EE) no screens found(EE)
[ 5281.084] (EE)
for help.
[ 5281.084] (EE) Please also check the log file at "/home/rece/.local/share/xorg/Xorg.0.log" for additional information.
[ 5281.084] (EE)
[ 5281.102] (EE) Server terminated with error (1). Closing log file.
so, i assume, installing the other video modes caused a conflict so Xserver shrugged it’s shoulders say “…well I dunno what you want to load cos you’ve got all of them! which one is correct?”
