hey everyone this is my first post on the manjaro forums
so i had this problem quite a while and i couldn’t connect my earbuds (xiaomi) to my laptop apperently i followed some archwiki topics ( bluetooth,bluetooth headsets) but nothing didn’t help
when i ran this command
/usr/lib/bluetooth/bluetoothd -n -d
i got some bluetooth logs and with this at last
D-Bus setup failed: Connection ":1.150" is not allowed to own the service "org.bluez" due to security policies in the configuration file
bluetoothd[31669]: src/main.c:main() Unable to get on D-Bus
i did had bluetooth before hand tho, i guess it’s only when i tried to powersave my battery that this issue occured
( i went to cpu and let the governor policy be powersaving also modifing the max of each thread)
i also ran this command
lsmod | grep bluetooth
outcome
bluetooth 733184 14 btrtl,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic 16384 1 bluetooth
rfkill 32768 11 hp_wmi,bluetooth,cfg80211
crc16 16384 2 bluetooth,ext4
but the rfkill doesn’t show this
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b8dd6e51-3699-44d5-b3e9-2850a0d504de rw quiet apparmor=1
resume=UUID=b8dd6e51-3699-44d5-b3e9-2850a0d504de resume_offset=40679424
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP EliteBook 755 G5 v: DBXEnabled
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83D5 v: KBC Version 08.5E.00 serial: <filter> UEFI: HP
v: Q81 Ver. 01.16.00 date: 04/21/2021
ID-1: BAT0 charge: 51.1 Wh (97.0%) condition: 52.7/56.3 Wh (93.6%)
volts: 12.3 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Discharging cycles: 270
RAM: total: 14.58 GiB used: 2.81 GiB (19.3%)
Info: Quad Core model: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 8101016 cache: L2: 2 MiB bogomips: 35147
Speed: 1396 MHz min/max: 1600/2200 MHz boost: enabled Core speeds (MHz):
1: 1396 2: 1465 3: 1469 4: 1419 5: 1524 6: 1566 7: 1335 8: 1480
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Monitor-2: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.41.0
5.13.13-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3300 bus-ID: 01:00.0
IF: enp1s0f0 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 476.94 GiB used: 219.71 GiB (46.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 type: SSD serial: <filter> rev: AAHA4102 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 316.31 GiB size: 310.28 GiB (98.09%)
used: 219.67 GiB (70.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: b8dd6e51-3699-44d5-b3e9-2850a0d504de
used: 41.7 MiB (43.4%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 6C17-9306
ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: R\xc3\xa9cup\xc3\xa9ration uuid: 7A54175F54171E07
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 160 GiB fs: ntfs label: N/A
uuid: CA62C89D62C88F9D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.2 C mobo: 30.0 C gpu: amdgpu temp: 42.0 C
Processes: 263 Uptime: 8m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1330 lib: 367 flatpak: 0 Shell: Zsh
v: 5.8 running-in: konsole inxi: 3.3.06
i would appreciate ur help
i felltoit
