Hi,
I am running 5.11.6-1-MANJARO KDE Plasma on a Lenovo thinkpad carbon x1 Gen 7 . Since a few months (maybe since upgrading to Kernel 5.8 or something) I have problems with connecting any usbc / thunderbolt / charger. When the system is running no device will be detected plugged into the usbc ports of the laptop. Does not matter what: keyboard, mouse, display, tb device, … even the charger will not be recognized. However, as soon as I suspend, or reboot the device is promptly detected. Also all devices connected while starting the system are detected. Just not while running. Does anyone have ideas, or similar issues?
I checked, and in the bios the problem is not present.; charger is detected. And any device will work properly once connected to the system. Also thunderbolt devices. And the other USB ports work fine.
I updated to the latest firmware via fwupd. No changes.
I attach some journal log output from when I am disconnecting a thunderbolt display and then trying to reconnect. But there is nothing at all in the log. I don’t know where to start.
Here is the output from journalctl:
Mar 19 17:12:04 thinkpad kernel: pcieport 0000:06:01.0: pciehp: Slot(1): Link Down
Mar 19 17:12:04 thinkpad kernel: pcieport 0000:06:01.0: pciehp: Slot(1): Card not present
Mar 19 17:12:04 thinkpad kernel: xhci_hcd 0000:0a:00.0: remove, state 1
Mar 19 17:12:04 thinkpad kernel: usb usb4: USB disconnect, device number 1
Mar 19 17:12:04 thinkpad kernel: usb 4-1: USB disconnect, device number 2
Mar 19 17:12:04 thinkpad kernel: usb 4-1.4: USB disconnect, device number 3
Mar 19 17:12:04 thinkpad kernel: usb 4-1.4.3: USB disconnect, device number 4
Mar 19 17:12:04 thinkpad kernel: xhci_hcd 0000:0a:00.0: xHCI host controller not responding, assume dead
Mar 19 17:12:04 thinkpad kernel: xhci_hcd 0000:0a:00.0: USB bus 4 deregistered
Mar 19 17:12:04 thinkpad kernel: usb usb3: USB disconnect, device number 1
Mar 19 17:12:04 thinkpad kernel: usb 3-1: USB disconnect, device number 2
Mar 19 17:12:04 thinkpad kernel: usb 3-1.4: USB disconnect, device number 3
Mar 19 17:12:04 thinkpad kernel: usb 3-1.4.1: USB disconnect, device number 4
Mar 19 17:12:04 thinkpad kernel: usb 3-1.4.2: USB disconnect, device number 5
Mar 19 17:12:04 thinkpad kernel: xhci_hcd 0000:0a:00.0: Host halt failed, -19
Mar 19 17:12:04 thinkpad kernel: xhci_hcd 0000:0a:00.0: Host not accessible, reset failed.
Mar 19 17:12:04 thinkpad kernel: xhci_hcd 0000:0a:00.0: USB bus 3 deregistered
Mar 19 17:12:04 thinkpad kernel: pci 0000:0a:00.0: Removing from iommu group 17
Mar 19 17:12:04 thinkpad kernel: pci_bus 0000:0a: busn_res: [bus 0a] is released
Mar 19 17:12:04 thinkpad kernel: pci 0000:09:01.0: Removing from iommu group 17
Mar 19 17:12:04 thinkpad kernel: pci_bus 0000:09: busn_res: [bus 09-0a] is released
Mar 19 17:12:04 thinkpad kernel: pci 0000:08:00.0: Removing from iommu group 17
Mar 19 17:12:04 thinkpad plasmashell[1317]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:153: TypeError: Cannot read property 'ports' of undefined
Mar 19 17:12:04 thinkpad plasmashell[1317]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-LG_Electronics_Inc._USB_Audio-00.analog-stereo"
Mar 19 17:12:04 thinkpad kscreen_backend_launcher[1285]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Mar 19 17:12:04 thinkpad kscreen_backend_launcher[1285]: kscreen.xcb.helper: Output: 68
Mar 19 17:12:04 thinkpad kscreen_backend_launcher[1285]: kscreen.xcb.helper: Property: EDID
Mar 19 17:12:04 thinkpad kscreen_backend_launcher[1285]: kscreen.xcb.helper: State (newValue, Deleted): 1
Mar 19 17:12:04 thinkpad plasmashell[1317]: org.kde.plasma.pulseaudio: No object for name "alsa_input.usb-LG_Electronics_Inc._USB_Audio-00.mono-fallback"
Mar 19 17:12:05 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: XRandROutput 67 update
m_connected: 0
m_crtc XRandRCrtc(0x556281e851f0)
CRTC: 63
MODE: 73
Connection: 0
Primary: true
Mar 19 17:12:05 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: Output 67 : connected = true , enabled = true
m_connected: 0
CRTC: 63
MODE: 73
Connection: 0
Primary: true
m_connected: 0
CRTC: 63
MODE: 73
Connection: 0
Primary: true
Mar 19 17:12:05 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: XRandROutput 68 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
Mar 19 17:12:05 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: Output 68 : connected = false , enabled = false
m_connected: 0
CRTC: 63
MODE: 73
Connection: 0
Primary: true
Mar 19 17:12:06 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: Output 67 : connected = true , enabled = true
Mar 19 17:12:06 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: XRandROutput 68 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Primary: false
Mar 19 17:12:06 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: Output 68 : connected = false , enabled = false
Mar 19 17:12:06 thinkpad kernel: filter_write: 191 callbacks suppressed
Mar 19 17:12:06 thinkpad kernel: msr: Write to unrecognized MSR 0x1a2 by python3 (pid: 1125).
Mar 19 17:12:06 thinkpad kernel: msr: See https://git.kernel.org/pub/scm/linux/kernel/git/tip/tip.git/about for details.
Mar 19 17:12:06 thinkpad kscreen_backend_launcher[1285]: kscreen.xrandr: Emitting configChanged()
Mar 19 17:12:36 thinkpad kernel: filter_write: 42 callbacks suppressed
Mar 19 17:12:36 thinkpad kernel: msr: Write to unrecognized MSR 0x64b by python3 (pid: 1125).
Mar 19 17:12:36 thinkpad kernel: msr: See https://git.kernel.org/pub/scm/linux/kernel/git/tip/tip.git/about for details.
CRTC: 63
MODE: 73
Connection: 0
Primary: true
