No built-in microphone detected Acer laptop
Hello! I have problem with my built-in mirchophone on laptop is not detected.
inxi -Fxxz:
  Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Acer product: Aspire A515-45 v: V1.05
    serial: <superuser required>
  Mobo: LN model: Calla_LC v: V1.05 serial: <superuser required>
    UEFI: INSYDE v: 1.05 date: 05/19/2021
  ID-1: BAT1 charge: 34.1 Wh (64.5%) condition: 52.9/53.0 Wh (99.8%)
    volts: 16.4 min: 15.4 model: PANASONIC AP19B5L serial: <filter>
    status: Charging
  Info: 8-core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
  Speed (MHz): avg: 1567 high: 2283 min/max: 1400/4370 boost: enabled
    cores: 1: 1469 2: 1673 3: 1522 4: 1658 5: 1554 6: 1694 7: 1640 8: 1397
    9: 2283 10: 1411 11: 1444 12: 1641 13: 1480 14: 1420 15: 1397 16: 1398
    bogomips: 57506
  Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
    v: kernel bus-ID: 05:00.0 chip-ID: 1002:164c
  Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-4:3
    chip-ID: 0408:a061
  Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
  Device-1: AMD vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
    bus-ID: 05:00.1 chip-ID: 1002:1637
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Acer Incorporated ALI driver: N/A bus-ID: 05:00.5
    chip-ID: 1022:15e2
  Device-3: AMD Family 17h HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
  Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
    vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 2000
    bus-ID: 03:00.0 chip-ID: 10ec:8168
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
    chip-ID: 8086:2723
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-3:3 chip-ID: 8087:0029
  Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 15.39 GiB (3.2%)
  ID-1: /dev/nvme0n1 vendor: Micron model: 2210 MTFDHBA512QFD
    size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 34.9 C
  ID-1: / size: 250.56 GiB used: 15.39 GiB (6.1%) fs: ext4
    dev: /dev/nvme0n1p8
  ID-2: /boot/efi size: 511 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p6
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p7
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
  Processes: 384 Uptime: 11h 0m Memory: 18.96 GiB used: 4.96 GiB (26.1%)
  Init: systemd v: 249 Compilers: gcc: N/A Packages: 1222 pacman: 1215
  flatpak: 7 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.11
pactl list sources:
Source #8
        State: RUNNING
        Description: Monitor of Renoir Radeon High Definition Audio Controller Digital Stereo (HDMI)
        Driver: module-alsa-card.c
        Sample Specification: s16le 2ch 44100Hz
        Channel Map: front-left,front-right
        Owner Module: 6
        Mute: no
        Volume: front-left: 65532 / 100% / -0.00 dB,   front-right: 65532 / 100% / -0.00 dB
                balance 0.00
        Base Volume: 65536 / 100% / 0.00 dB
        Monitor of Sink: alsa_output.pci-0000_05_00.1.hdmi-stereo
        Latency: 0 usec, configured 40000 usec
        Flags: DECIBEL_VOLUME LATENCY
        Properties:
                device.description = "Monitor of Renoir Radeon High Definition Audio Controller Digital Stereo (HDMI)"
                device.class = "monitor"
                alsa.card = "0"
                alsa.card_name = "HD-Audio Generic"
                alsa.long_card_name = "HD-Audio Generic at 0xd04c8000 irq 93"
                device.bus_path = "pci-0000:05:00.1"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:05:00.1/sound/card0"
                device.bus = "pci"
                device.vendor.id = "1002"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
                device.product.id = "1637"
                device.product.name = "Renoir Radeon High Definition Audio Controller"
                device.string = "0"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        Formats:
                pcm
Source #11
        State: RUNNING
        Description: Monitor of Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo
        Owner Module: 7
        Mute: no
        Volume: front-left: 65533 / 100% / -0.00 dB,   front-right: 65533 / 100% / -0.00 dB
                balance 0.00
        Monitor of Sink: alsa_output.pci-0000_05_00.6.analog-stereo
        Properties:
                device.description = "Monitor of Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo"
                alsa.card = "1"
                alsa.long_card_name = "HD-Audio Generic at 0xd04c0000 irq 94"
                device.bus_path = "pci-0000:05:00.6"
                sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:05:00.6/sound/card1"
                device.bus = "pci"
                device.vendor.id = "1022"
                device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
                device.product.id = "15e3"
                device.product.name = "Family 17h (Models 10h-1fh) HD Audio Controller"
                device.string = "1"
        Formats:
                pcm
Thank you! Problem solved. :sunglasses:
How exactly?
Which one did you install (manjaro-pipewire would be my guess)?
I’ve got manjaro-pulse on my kde machine and still see those 2 sound servers as enabled in inxi output (probably due to pipewire being a dependency of kwin and manjaro-kde-settings).
Doesn’t cause any problems though.
Yes, i just installed manjaro-pipewire. When i was installing manjaro-pipewire it asked me some question about manjaro-pulse i sad yes on every one of them. Now everything work when i run inxi -Fxxz i get:
Sound Server-3: PulseAudio v: 15.0 running: no
Thanks for clarifying: essentially the switch from pulseaudio to pipewire fixed your issue.
