No Boot after Manjaro update: Failed to mount NFSD configuration filesystem
Hi there,
I’m running Manjaro XFCE with LVM & LUKS. After an automatic update yesterday evening after shutdown, the system does not boot anymore.
The boot screen is showing …
Enter passphrase for /dev/sda5:
/dev/mapper/lvm_desktop1-root: clean, 1143466/3932160 files, 12015177/15728640 blocks
[FAILED] Failed to mount NFSD configuration filesystem.
[DEPEND] Dependency failed for NFS server and services.
[DEPEND] Dependency failed for NFSv4 ID-name mapping service.
[DEPEND] Dependency failed for NFS Mount Daemon.
[DEPEND] Dependency failed for NFSv4 Client Tracking Daemon.
[FAILED] to mount /boot/efi.
[DEPEND] Dependency failed for Local File Systems.
[FAILED] Failed to mount RPC Pipe File System.
[DEPEND] Dependency failed for rpc_pipefs.target.
[DEPEND] Dependency failed for RPC security service for NFS client and server.
[FAILED] Failed to start Cryptography Setup for hd_data01.
[DEPEND] Dependency failed for Local Encrypted Volumes.
[DEPEND] Dependency failed for /dev/mapper/hd_data01
[DEPEND] Dependency failed for File System Check on /dev/mapper/hd_data01.
[DEPEND] Dependency failed for /home/wolf/hd_data01.
[FAILED] Failed to mount /windows.
You are in emergency mode. After logging in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot or "exit" to continue bootup.
Booting does not work. Even if I type “exit”.
Same problem with Kernel 5.15.140-1-MANJARO x64 and 6.1.64-1-MANJARO x64.
What can I do to get my system running again?
Hello @exaveal :wink:
Better later than never.
NFS needs a network connection. Keep sure that the nfs mount is running after a network connection was established.
You could try to boot with “fallback”-initrd :man_shrugging:
I chrooted in the system and die “update-grub” - everything works no again.
No idea, i do not have an entry in fstab regarding nfs. So there shouldn’t be any need for network connection.
Topic can be closed. Thanks for your answer. :slight_smile:
