Same here!
I was running 5.4 kernel happily when i revived a huge update 5.10.2.2
Its crashed after restart, but i was able to bring i it back with a
sudo mhwd-kernel -i linux510
command
No is no Bluetooth no wifi
I tried old kernel too same issue driver was reinstalled
inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=2b0db55f-5483-495a-baa4-5d85d6d58d83 rw quiet apparmor=1
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 info: cairo-dock wm: gnome-shell
dm: GDM 3.38.2.1 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81LL v: IdeaPad L340-17IRH Gaming
serial: <filter> Chassis: type: 10 v: IdeaPad L340-17IRH Gaming
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: BGCN24WW date: 08/19/2019
ID-1: BAT0 charge: 42.3 Wh condition: 42.3/45.0 Wh (94%) volts: 12.8/11.5
model: Celxpert L18C3PF1 type: Li-poly serial: <filter> status: Full
cycles: 54
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 8 MiB
bogomips: 38408
Speed: 1000 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1000 2: 1000
3: 1000 4: 1000 5: 1000 6: 1000 7: 1000 8: 1000
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f91
Device-3: Chicony Integrated Camera (1280x720@30) type: USB driver: uvcvideo
bus ID: 1-8:3 chip ID: 04f2:b604 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell
driver: modesetting,nvidia display ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 128
size: 381x214mm (15.0x8.4") diag: 437mm (17.2")
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 4000
bus ID: 07:00.0 chip ID: 10ec:c821
IF: wlp7s0 state: down mac: <filter>
vendor: Lenovo driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 3000
bus ID: 08:00.0 chip ID: 10ec:8168
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 523.19 GiB (18.7%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
temp: 34.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM003 HN-M201RAD
size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0001
ID-1: / raw size: 294.19 GiB size: 288.57 GiB (98.09%)
used: 205.03 GiB (71.1%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 41 C
Processes: 295 Uptime: 17m wakeups: 3 Memory: 15.52 GiB
used: 2.73 GiB (17.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1640 apt: 0 pacman: 1599 lib: 454 rpm: 0 flatpak: 31 snap: 10
Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.2.01
lspci -v [1]
00:00.0 Host bridge: Intel Corporation 8th Gen Core 4-core Processor Host Bridge/DRAM Registers [Coffee Lake H] (rev 07)
Subsystem: Lenovo Device 380a
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122
Bus: primary=00, secondary=01, subordinate=05, sec-latency=0
I/O behind bridge: 00005000-00005fff [size=4K]
Memory behind bridge: a3000000-a40fffff [size=17M]
Prefetchable memory behind bridge: 0000000090000000-00000000a1ffffff [size=288M]
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Mobile) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 3a2e
Flags: bus master, fast devsel, latency 0, IRQ 139
Memory at a2000000 (64-bit, non-prefetchable) [size=16M]
Memory at b0000000 (64-bit, prefetchable) [size=256M]
I/O ports at 6000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
Subsystem: Lenovo Device 3830
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at a4510000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Subsystem: Lenovo Device 3866
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at a4520000 (64-bit, non-prefetchable) [size=4K]
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
Subsystem: Lenovo Device 3804
Memory at a4521000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10) (prog-if 30 [XHCI])
Subsystem: Lenovo Device 3807
Flags: bus master, medium devsel, latency 0, IRQ 136
Memory at a4500000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
Memory at a451c000 (64-bit, non-prefetchable) [size=8K]
Memory at a4522000 (64-bit, non-prefetchable) [size=4K]
00:15.0 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
Subsystem: Lenovo Device 3805
Memory at 8f800000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #1 (rev 10)
Subsystem: Lenovo Device 380b
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at 8f801000 (64-bit, non-prefetchable) [size=4K]
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
Subsystem: Lenovo Device 3811
Flags: bus master, fast devsel, latency 0, IRQ 137
Memory at a4525000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller (rev 10) (prog-if 01 [AHCI 1.0])
Subsystem: Lenovo Device 3801
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 126
Memory at a451e000 (32-bit, non-prefetchable) [size=8K]
Memory at a452a000 (32-bit, non-prefetchable) [size=256]
I/O ports at 6080 [size=8]
I/O ports at 6088 [size=4]
I/O ports at 6060 [size=32]
Memory at a4529000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: a4400000-a44fffff [size=1M]
Prefetchable memory behind bridge: [disabled]
00:1d.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #13 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 00004000-00004fff [size=4K]
Memory behind bridge: a4300000-a43fffff [size=1M]
00:1d.5 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #14 (rev f0) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 125
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: a4200000-a42fffff [size=1M]
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
Subsystem: Lenovo Device 3810
Flags: bus master, fast devsel, latency 0, IRQ 20
Memory at 8f802000 (64-bit, non-prefetchable) [size=4K]
00:1f.0 ISA bridge: Intel Corporation HM470 Chipset LPC/eSPI Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10) (prog-if 80)
Subsystem: Lenovo Device 3815
Flags: bus master, fast devsel, latency 32, IRQ 141
Memory at a4518000 (64-bit, non-prefetchable) [size=16K]
Memory at a4100000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
Subsystem: Lenovo Device 3816
Flags: medium devsel, IRQ 16
Memory at a4527000 (64-bit, non-prefetchable) [size=256]
I/O ports at 6040 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
Subsystem: Lenovo Device 3803
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 142
Memory at a3000000 (32-bit, non-prefetchable) [size=16M]
Memory at 90000000 (64-bit, prefetchable) [size=256M]
Memory at a0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 5000 [size=128]
Expansion ROM at a4080000 [virtual] [disabled] [size=512K]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 (prog-if 02 [NVM Express])
Subsystem: Samsung Electronics Co Ltd Device a801
Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0
Memory at a4400000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
07:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
Subsystem: Lenovo Device c024
Flags: bus master, fast devsel, latency 0, IRQ 140
I/O ports at 4000 [size=256]
Memory at a4300000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: rtw_8821ce
Kernel modules: rtw88_8821ce, rtw_8821ce
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
Subsystem: Lenovo Device 38cf
Flags: bus master, fast devsel, latency 0, IRQ 138
I/O ports at 3000 [size=256]
Memory at a4204000 (64-bit, non-prefetchable) [size=4K]
Memory at a4200000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: r8168
Kernel modules: r8169, r8168
Pls somebody help me
