No Batteries Available
I have had Manjaro since March on my Dell XPS 9300 and have had no problems with power management on my laptop. However, a couple of days ago I noticed that there was no percentage displayed on the battery widget on my panel. After some searching, I didn’t find any simple solution for this. I can see the battery percentage by using upower -d so there isn’t a problem there. I did have porblems updating electron4 about the same time, but I don’t know if its related at all…
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:innocent:
Not OP, but I have the same problem:
System:    Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=77d17f8d-b607-4a58-9221-af84aed01c5e rw quiet
           cryptdevice=UUID=650afc93-222f-475c-a65f-ae208eb860cf:luks-650afc93-222f-475c-a65f-ae208eb860cf
           root=/dev/mapper/luks-650afc93-222f-475c-a65f-ae208eb860cf
           resume=/dev/mapper/luks-a4229639-0095-4d49-866e-219d5df32552 udev.log_priority=3
           Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Latitude 5480 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Dell model: 0DD5XR v: A00 serial: <filter> UEFI: Dell v: 1.17.1 date: 01/07/2020
Battery:   ID-1: BAT0 charge: 25.3 Wh condition: 56.1/68.0 Wh (83%) volts: 7.5/7.6 model: LGC-LGC8.820 DELL DV9NT74
           type: Li-ion serial: <filter> status: Discharging
Memory:    RAM: total: 7.64 GiB used: 3.74 GiB (48.9%)
CPU:       Topology: Quad Core model: Intel Core i5-7440HQ bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
           stepping: 9 microcode: D6 L2 cache: 6144 KiB bogomips: 22408
           Speed: 800 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
           clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
           flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
           invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
           pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
           smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
           tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
           Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics:  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
           Device-2: NVIDIA GM108M [GeForce 930MX] vendor: Dell driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm
           bus ID: 02:00.0 chip ID: 10de:134e
           Device-3: Realtek Integrated Webcam HD type: USB driver: uvcvideo bus ID: 1-11:3 chip ID: 0bda:568c
           serial: <filter>
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting,nvidia
           alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
           OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio:     Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
           Sound Server: ALSA v: k5.8.6-1-MANJARO
Network:   Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: 3.2.6-k port: f040 bus ID: 00:1f.6
           chip ID: 8086:15e3
           IF: enp0s31f6 state: down mac: <filter>
           Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0 chip ID: 8086:24fd
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           IP v6: <filter> type: noprefixroute scope: global
Drives:    Local Storage: total: 238.47 GiB used: 30.82 GiB (12.9%)
           ID-1: /dev/sda vendor: SanDisk model: X400 M.2 2280 256GB size: 238.47 GiB block size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 2012 scheme: GPT
RAID:      Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060 bus ID: 00:17.0 chip ID: 8086.2822
           rev: 31
Partition: ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%) used: 30.66 GiB (13.6%) fs: ext4 dev: /dev/dm-0 label: N/A
           uuid: 77d17f8d-b607-4a58-9221-af84aed01c5e
           ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 424 KiB (0.1%) fs: vfat dev: /dev/sda1
           label: N/A uuid: 84A0-7780
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.80 GiB used: 161.4 MiB (1.8%) priority: -2 dev: /dev/dm-1 label: N/A
           uuid: ad1a083c-f34b-4d6d-81a0-9a6d476dcfb9
Unmounted: ID-1: /dev/sda2 size: 229.37 GiB fs: crypto_luks label: N/A uuid: 650afc93-222f-475c-a65f-ae208eb860cf
           ID-2: /dev/sda3 size: 8.80 GiB fs: crypto_luks label: N/A uuid: a4229639-0095-4d49-866e-219d5df32552
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-6:2 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
           speed: 12 Mb/s chip ID: 8087:0a2b
           Device-2: 1-11:3 info: Realtek Integrated Webcam HD type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s chip ID: 0bda:568c serial: <filter>
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 41.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 268 Uptime: 4d 18h 42m Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 6 Packages: pacman: 1240
           lib: 308 Shell: Zsh v: 5.8 running in: yakuake inxi: 3.1.05
Weird…
  1. Output of:
    sudo tlp-stat --battery
    Please?
  2. If you press the battery icon in the panel, do you get something like this:
    2020-09-26_16-34
  3. If you create a new user and log in there, does it have the same problem???
:question:
This is what my widget looked like:
Screenshot_20200927_144528 Screenshot_20200927_144551
I rebooted my laptop, and It’s now working again:
Screenshot_20200927_155502
I’ll include the output of tlp-stat anyway, in case it helps track down the bug (note: this is the output after reboot):
--- TLP 1.3.1 --------------------------------------------
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi    = inactive (laptop not supported)
tpacpi-bat = inactive (laptop not supported)
tp-smapi   = inactive (laptop not supported)
+++ Battery Status: BAT0
/sys/class/power_supply/BAT0/manufacturer                   = LGC-LGC8.820
/sys/class/power_supply/BAT0/model_name                     = DELL DV9NT74
/sys/class/power_supply/BAT0/cycle_count                    = (not supported)
/sys/class/power_supply/BAT0/charge_full_design             =   8947 [mAh]
/sys/class/power_supply/BAT0/charge_full                    =   7131 [mAh]
/sys/class/power_supply/BAT0/charge_now                     =   3809 [mAh]
/sys/class/power_supply/BAT0/current_now                    =    952 [mA]
/sys/class/power_supply/BAT0/status                         = Discharging
Charge                                                      =   53.4 [%]
Capacity                                                    =   79.7 [%]
As the OP did not come back, and you confirm a reboot solves the issue, that’s the solution then!
:grin:
P.S. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
(as that makes our life much easier so you get helped more quickly and efficiently)
:innocent:
$ inxi --full --verbosity=7 --filter --no-host
System:    Kernel: 5.4.64-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0
Machine:   Type: Laptop System: Dell product: Latitude E7470 v: N/A serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 0T6HHJ v: A00 serial: <filter> UEFI [Legacy]: Dell v: 1.22.8 date: 10/08/2019
Battery:   ID-1: BAT0 charge: 32.4 Wh condition: 44.0/55.0 Wh (80%) volts: 7.7/7.6 model: Samsung SDI DELL 1W2Y26A
           type: Li-poly serial: <filter> status: Discharging
Memory:    RAM: total: 7.59 GiB used: 1.22 GiB (16.1%)
CPU:       Topology: Dual Core model: Intel Core i7-6600U bits: 64 type: MT MCP arch: Skylake rev: 3 L2 cache: 4096 KiB
           bogomips: 22408
           Speed: 500 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 500 2: 500 3: 500 4: 500
Graphics:  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell Latitude E7470 driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:1916
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting alternate: fbdev,intel,vesa
           resolution: 1920x1080 s-dpi: 96
           OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell Latitude E7470 driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:9d70
           Sound Server: ALSA v: k5.4.64-1-MANJARO
Network:   Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0 chip ID: 8086:24f3
           Device-2: Intel driver: N/A port: f040 bus ID: 02:00.0 chip ID: 8086:093c
Drives:    Local Storage: total: 267.50 GiB used: 12.23 GiB (4.6%)
           ID-1: /dev/mmcblk0 vendor: SanDisk model: SL32G size: 29.03 GiB serial: <filter> scheme: MBR
           ID-2: /dev/nvme0n1 vendor: Toshiba model: THNSN5256GPU7 NVMe 256GB size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
           serial: <filter> rev: 57DA4103 scheme: MBR
RAID:      Message: No RAID data was found.
Partition: ID-1: / size: 225.06 GiB used: 12.23 GiB (5.4%) fs: ext4 dev: /dev/nvme0n1p1 label: N/A
           uuid: f522c942-6c24-4067-bc07-6d99e20a6e94
Swap:      ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p2 label: N/A
           uuid: 6f2f966f-aa1d-4403-8982-85dab59f4073
Unmounted: ID-1: /dev/mmcblk0p1 size: 29.02 GiB fs: vfat label: N/A uuid: AEB1-64D0
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-7:2 info: Broadcom 5880 type: Smart Card driver: N/A interfaces: 4 rev: 1.1 speed: 12 Mb/s
           chip ID: 0a5c:5834 serial: <filter>
           Device-2: 1-9:3 info: Elan Micro Touchscreen type: HID driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
           speed: 12 Mb/s chip ID: 04f3:2247
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 37.0 C mobo: N/A
Info:      Processes: 163 Uptime: 1h 27m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1207 Shell: Bash
           v: 5.0.18 running in: yakuake inxi: 3.1.05
Same issue but the battery is clearly there.
$ sudo tlp-stat --battery
/sys/class/power_supply/BAT0/manufacturer                   = Samsung SDI
/sys/class/power_supply/BAT0/model_name                     = DELL 1W2Y26A
/sys/class/power_supply/BAT0/charge_full_design             =   7236 [mAh]
/sys/class/power_supply/BAT0/charge_full                    =   5791 [mAh]
/sys/class/power_supply/BAT0/charge_now                     =   4222 [mAh]
/sys/class/power_supply/BAT0/current_now                    =   1574 [mA]
Charge                                                      =   72.9 [%]
Capacity                                                    =   80.0 [%]
This looks like a bug. I am running a Dell E7470, I also run a Dell E6410, both with Kernel 5.4.64-1 LTS, getting the same issue.
If the solution in this thread does not provide the solution you’re seeking, please create a new topic and link to this one if it provides context.
