No available connections after installing
Hi all! First time using Manjaro and I just installed it on a new laptop. Thing is, I cannot connect to any wifi because of “No available connections” (either in taskbar menu or in settings)
This laptop does not have ethernet so i’m kinda stuck at what to do next :frowning:
I saw some other forum users paste some kind of device info but idk what that is or how to do it, sorry
output from:
inxi -Fazy
use formatting, click this icon in editor: </> and put the output there
  Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=ef0b4601-4216-45e0-a888-a5c3a9cfd8a6 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X415UA_M415UA
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X415UA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: X415UA.304 date: 08/13/2021
  ID-1: BAT0 charge: 37.4 Wh (100.0%) condition: 37.4/37.1 Wh (100.7%)
    volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging cycles: 1
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
    model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1397 high: 1400 min/max: 1400/4056 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1399 2: 1399
    3: 1397 4: 1400 5: 1398 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
    12: 1397 bogomips: 50321
  Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
    arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
    class-ID: 0300
  Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-3:3 chip-ID: 13d3:5a11 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f7 built: 2020
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
    diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.49-1-MANJARO)
    v: 4.6 Mesa 22.1.2 direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: N/A modules: rtw88_8821ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c821
    class-ID: 0280
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-2:2 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 8.96 GiB (1.9%)
    model: MZVLQ512HALU-00000 size: 476.94 GiB block-size: physical: 512 B
    rev: FXV7101Q temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 8.96 GiB (1.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 39.0 C
  Processes: 262 Uptime: 11m wakeups: 1 Memory: 7.17 GiB
  used: 1.08 GiB (15.1%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1207
  lib: 333 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.19
also output from:
mhwd-kernel -li
Currently running: 5.15.49-1-MANJARO (linux515)
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
   * linux515
so if you are not connected to internet, connect to it using phone and tethering, otherwise you would not be able to install driver for wifi
What is that? Sorry for my inexperience (nvm googled it :slight_smile:
connect your phone to the pc via cable and in your phone enable tetherin so you have internet
And where do I install the driver?
so first install one kernel as a backup, the 5.10:
sudo mhwd-kernel -i linux510
then create this file:
sudo nano /etc/modprobe.d/blacklist.conf
put inside it this line:
blacklist rtw88_8821ce
press ctrl+x to save the file
install headers:
pamac install linux515-headers linux510-headers
install dkms driver:
pamac build rtl8821ce-dkms-git
reboot and test wifi
warning: database file for ‘core’ does not exist (use ‘-Sy’ to download)
warning: database file for ‘extra’ does not exist (use ‘-Sy’ to download)
warning: database file for ‘community’ does not exist (use ‘-Sy’ to download)
warning: database file for ‘multilib’ does not exist (use ‘-Sy’ to download)
Error: Please make sure if the given kernel(s) exist(s).
available kernels:
Am I supposed to get this?
so run this:
sudo pacman -Sy
then continue with the commands above
Rebooting!
WIFI! Thanks a lot!!!
