No audio with WirePlumber 0.5.17 — downgrading to 0.5.14 fixed it for me
I lost audio from PipeWire applications after the last update. YouTube, VLC had no sound, youtube load took forever and anything that needed a system sound completely froze (like during unsaved warnings and stuff). Did speaker-test - which worked normally. Then checked pw-play which produced no sound and hanged indefinitely.
  • PipeWire: 1.6.8
  • WirePlumber: 0.5.17
  • Sound card: HDA Intel PCH / Realtek ALC3204
  • KDE Plasma + Wayland
Downgrading WirePlumber to 0.5.14 (with matching libwireplumber) from cached packages fixed the issue, at least on my machine.
I’m definitely no expert, and I did this short term solution to be ready for a job interview tomorrow - so I’m definitely not suggesting anyone do this without more research.
Happy to provide diagnostic output/logs if useful to anyone.
Provide the diagnostics regardless. Someone might even advise on a solution to your problem
of course. I’m not sure what to provide though, could you guide me?
Tips and Tricks
How to Request Support
Resources
Beyond the mandatory reading advised by @Aragorn, post the output of the journal :
journalctl --user -u wireplumber -u pipewire -p err..warning --no-pager
For instance, this was mine when I had troubles with wireplumber :
set 05 05:25:49 ovidio pipewire\[1138996\]:
**spa.alsa: 'hdmi:0,1': playback open failed: Device or resource busy**
**pw.node: (alsa_output.pci-0000_04_00.1.hdmi-stereo-extra1-92) suspended -> error (Start error: Device or resource busy)**
set 05 05:25:50 ovidio pipewire\[1138996\]:
**mod.adapter: 0x556ebcf35050: can't get format: Device or resource busy**
set 05 05:25:50 ovidio wireplumber\[1138997\]:
**s-monitors: Failed to create ALSA node alsa_output.pci-0000_04_00.1.hdmi-stereo-extra1: Object activation aborted: PipeWire proxy destroyed**
**wplua: \[string "alsa.lua"\]:446: attempt to call a nil value (method 'store_managed_pending')**
Latest version of WirePlumber is available from unstable branch
0.5.17-2: Provide wireplumber-system-services (3b7bf435) · Commits · Arch Linux/Packaging/Packages/wireplumber
