I installed Manjaro Ornara 21.0 with KDE Plasma on my laptop a week ago. (This is my first time using a Linux distro, so please be patient with me.)
After installation, I was initially able to play music on my laptop without issues.
However, for the past day, I have been unable to play any sound, regardless of which output device I use. Rebooting does not help either. This problem happened quite suddenly, and I am not sure of the cause.
This is the output after running sudo dmesg | egrep '(snd|sound|sof)'
[ 2.607304] snd_hda_intel 0000:03:00.1: enabling device (0000 -> 0002)
[ 2.607455] snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
[ 2.607629] snd_hda_intel 0000:03:00.6: enabling device (0000 -> 0002)
[ 2.683230] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:03:00.1/sound/card0/input8
[ 2.733858] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC256: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 2.733861] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 2.733862] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 2.733863] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 2.733864] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 2.733865] snd_hda_codec_realtek hdaudioC1D0: Headset Mic=0x19
[ 2.733866] snd_hda_codec_realtek hdaudioC1D0: Internal Mic=0x12
[ 2.798970] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:03:00.6/sound/card1/input9
[ 3.644486] snd_hda_intel 0000:03:00.1: bound 0000:03:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
This is the output for amixer
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 38666 [59%] [on]
Front Right: Playback 38666 [59%] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch cswitch-joined
Limits: Capture 0 - 65536
Front Left: Capture 65536 [100%] [on]
Front Right: Capture 65536 [100%] [on]
This is the output for inix -Fxxx
System: Host: Manjaro Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.4
tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X521IA_M533IA v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X521IA v: 1.0 serial: <superuser required> UEFI: American Megatrends v: X521IA.301
date: 05/22/2020
Battery: ID-1: BAT0 charge: 13.7 Wh (30.0%) condition: 45.6/50.0 Wh (91.1%) volts: 11.9 min: 11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging cycles: 277
CPU: Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2 rev: 1 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31959
Speed: 1395 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 1395 2: 1397 3: 1397 4: 1397 5: 1397
6: 1399 7: 1397 8: 1398
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 3-3:3 chip-ID: 13d3:56a2
class-ID: 0e02 serial: 0x0001
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.56-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: up mac: ac:12:03:fe:ad:30
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 376.43 GiB (78.9%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PCP3512F-AB size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD
serial: 50026B76838B9506 rev: ECFK52.3 temp: 30.9 C scheme: GPT
Partition: ID-1: / size: 451.7 GiB used: 376.43 GiB (83.3%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 16.64 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 37.8 C mobo: 37.0 C gpu: amdgpu temp: 37.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 297 Uptime: 21m wakeups: 8884 Memory: 15.12 GiB used: 2.95 GiB (19.5%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: 1470 pacman: 1461 snap: 9 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Any advice would be much appreciated. Thank you.
