It is still not fixed
i dont know what exactly did you change when you were trying to fix your bluetooth issue …
try a different kernel, maybe it will help, install the 5.19.1 from system settings/kernel, reboot, select it in grub menu/advanced options during boot and see if that helped …
Just to inform you the issue I mentioned in the question is solved and earphone issue is and was there before the bluetooth issue
so you had this audio playing simultaneously before ?
so switching to kernel could help, so proceed with install …
It didn’t work
I have to sleep now, so I will mark the solution to the original question I asked and make a new question tomorrow. Thank for helping me
